The OTA package for Jetson Thor is too large
I am using the Jetson AGX Thor (JP 7.1) with A/B partitioning and am trying to generate an OTA package for the system. I used the following command to create the package:
sudo ROOTFS_AB=1 -E ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh --external-device nvme0n1 jetson-agx-thor-devkit R38-4
The issue is that this command has been running for nearly three hours, and the generated bootloader/system.img has already grown to over 460 GB. Is there a way to make it smaller?
Additionally, the MFI package for Jetson Thor is massive; in JP6 and earlier versions, an MFI package combined with JetPack totaled just over 10 GB, whereas in JP7.1, it reaches nearly 100 GB—which is staggering.
hello jackp,
that should due to it’s creating a single OTA payload with multi board specs.
please see-also developer guide, Multiple Board Specs Customization. please revise ota_board_specs.conf to comment out unused board spec.
it may shorten the time needed to generate the OTA payload package and decrease the size of the resulting package.
Hi @jackp
I haven’t tested myself the Thor OTA generation package but I have some insights that may help at your case:
For reference build for customers, I noticed the OTA payload takes ~6GB and according to documentation here Software Packages and the Update Mechanism — NVIDIA Jetson Linux Developer Guide the expected size should be ~2.5GB.
From your information I suppose something is wrong causing the huge image size, some details I can share for our reference Thor build, we only use the board specs for a single board (the one we use) and a Yocto build which uses a custom rootfs size.
I would suggest to check if your rootfs size is also huge and only use the specs board for your specific machine to reduce the OTA package size.
