We use mmapi at jetpack3.3. We set the peak bit rate to deal with large dynamic motion
picture, but no matter how we set the peak bit rate, the encoding rate can never be improved.
-MinQpI Specify minimum Qp Value for I frame
-MaxQpI Specify maximum Qp Value for I frame
-MinQpP Specify minimum Qp Value for P frame
-MaxQpP Specify maximum Qp Value for P frame
I think the QP range and the peak bitrate are two different things, just like the ffmpeg does not need to set QP range, and the peak bitrate is also valid.
We also try to tune QP range, it can’t cope with the general situation.
Hi zcs,
We have the qp-range property in R21, R23, R24, R27, and R28, R31. If you need different SW design, please contact NVIDIA salesperson to have further cooperation.
