Hello!
I have a question while using the TK1 board, so I’m leaving you an inquiry.
After using TK1 for several days, the TK1 board won’t work.
This is the output of the kernel message when the current problem occurred. Please check below.
[89897.953434] dvfs_rail_set_voltage: rail didn’t reach target 1010 in 1 steps (950)
[100375.851699] dvfs_rail_set_voltage: rail didn’t reach target 950 in 2 steps (1010)
[122398.709222] dvfs_rail_set_voltage: rail didn’t reach target 950 in 2 steps (1010)
[134847.625997] dvfs_rail_set_voltage: rail didn’t reach target 1010 in 1 steps (1150)
[134847.633703] dvfs_rail_set_voltage: rail didn’t reach target 1150 in 1 steps (1050)
[134847.647644] Failed to set regulator vdd_core for clock sdmmc4 to 1150 mV
[134847.660259] sdhci-tegra sdhci-tegra.3: clock enable is failed, ret: -22
Is there a meaning of the message and a solution to the problem? I’d appreciate your help.
