The physical installation direction‘ s effect to Jetson AGX orin
I’m using Jetson AGX Orin with 64G devkit version. You know , it has a shell and a fan inside . My question is , if the physical installation direction of Orin is not flat(the fan is not facing vertically) , will it has any bad influence to Orin?
That should be ok. Please note, devkit is only for development, not for product usage, so the general use case of development in room should be ok.
I got it , thank you so much !
