The power button on the jetson nano devkit carriere board is
How is the action?
Does long press turn it off?
I used to change the way the power button works through gsettings.
Jetson nano seems to go into suspended when not logged in ubuntu.
Connect the power button to the devkit carrier board as follows and
I press the power button on the screen before logging in to ubuntu
It seems to go into suspended mode.
If you press the power button again, the login standby screen appears immediately without booting up.
Is it possible to shutdown without going into suspended mode in this situation?
When the HDMI cable is not connected, it does not enter suspended mode even when the power button is pressed.
As soon as the HDMI cable is connected, it goes into suspended mode.
Here’s what I checked with journalctl:
8월 04 14:50:31 nvidia-desktop systemd-logind[3993]: Power key pressed.
8월 04 14:50:32 nvidia-desktop systemd-logind[3993]: Power key pressed.
8월 04 14:50:33 nvidia-desktop systemd-logind[3993]: Power key pressed.
8월 04 14:50:39 nvidia-desktop kernel: tegradc tegradc.0: unblank
8월 04 14:50:39 nvidia-desktop kernel: tegradc tegradc.1: blank - powerdown
8월 04 14:50:39 nvidia-desktop /usr/lib/gdm3/gdm-x-session[5349]: (–) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): connected
8월 04 14:50:39 nvidia-desktop /usr/lib/gdm3/gdm-x-session[5349]: (–) NVIDIA(GPU-0): LG Electronics LG IPS FULLHD (DFP-0): External TMDS
8월 04 14:50:40 nvidia-desktop whoopsie[4699]: [14:50:40] offline
8월 04 14:50:40 nvidia-desktop systemd[1]: Reached target Sleep.
8월 04 14:50:40 nvidia-desktop systemd[1]: Starting Suspend…
8월 04 14:50:40 nvidia-desktop systemd-sleep[6858]: Suspending system…
