The power consumption of Orin nano is larger than that of Orin NX?
Hello, I am doing a power consumption experiment, and the test results are: The power consumption of Orin nano running three YOLOV5 models in 15W mode is 18.72W, and the power consumption of Orin NX running three identical YOLOV5 models in 20W mode is 14.88W. May I ask why the power consumption of Orin nano is larger than that of Orin NX?
The real power consumption depends on boards, peripherals, use case, thermal solution, supply voltage, test methods and etc., not just by Jetson module. You can use command line tegrastats to show the detail of CPU, GPU freq and usage, and also the power consumption of each main power rails.
