Hi, everyone:
I am using a camera named ar0234, and the driver is coded by myself according to ov9281.c
Now when i debug my driver, i met a problem:
i use command
v4l2-ctl --set-fmt-video=width=1920,height=1200,pixelformat=GREY -c sensor_mode=60 --stream-mmap --stream-count=1 -d /dev/video0
It show
tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
tegra194-vi5 15c10000.vi: no reply from camera processor
tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
i try to trace it,
trace log is show
kworker/0:1-10177 [000] .... 5194.716538: rtcpu_vinotify_event: tstamp:162652867415 tag:FS channel:0x00 frame:1 vi_tstamp:162652724717 data:0x00000010
kworker/0:1-10177 [000] .... 5194.716542: rtcpu_vinotify_event: tstamp:162652867582 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:162652724720 data:0x00000000
kworker/0:1-10177 [000] .... 5194.716544: rtcpu_vinotify_event: tstamp:162652867725 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:162652724800 data:0x00000649
kworker/0:1-10177 [000] .... 5194.716590: rtos_queue_send_from_isr_failed: tstamp:162653249556 queue:0x0bcb41f8
kworker/0:1-10177 [000] .... 5194.716592: rtos_queue_send_from_isr_failed: tstamp:162653249709 queue:0x0bcb8a60
kworker/0:1-10177 [000] .... 5194.716594: rtos_queue_send_from_isr_failed: tstamp:162653249862 queue:0x0bcba5e0
kworker/0:1-10177 [000] .... 5194.716595: rtos_queue_send_from_isr_failed: tstamp:162653250007 queue:0x0bcbb3a0
kworker/0:1-10177 [000] .... 5194.716596: rtos_queue_send_from_isr_failed: tstamp:162653250154 queue:0x0bcbc160
kworker/0:1-10177 [000] .... 5194.716598: rtcpu_vinotify_event: tstamp:162653409752 tag:FE channel:0x00 frame:1 vi_tstamp:162653234729 data:0x00000020
kworker/0:1-10177 [000] .... 5194.716599: rtcpu_vinotify_event: tstamp:162653409911 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:1 vi_tstamp:162653234730 data:0x01000000
kworker/0:1-10177 [000] .... 5194.716601: rtcpu_vinotify_event: tstamp:162653410073 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:162611923488 data:0x01020001
kworker/0:1-10177 [000] .... 5194.716602: rtcpu_vinotify_event: tstamp:162653410216 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:162653234731 data:0x00000000
kworker/0:1-10177 [000] .... 5194.716604: rtcpu_vinotify_event: tstamp:162653410374 tag:FS channel:0x00 frame:2 vi_tstamp:162653243646 data:0x00000010
kworker/0:1-10177 [000] .... 5194.716605: rtcpu_vinotify_event: tstamp:162653410516 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:162653243649 data:0x00000000
kworker/0:1-10177 [000] .... 5194.716606: rtcpu_vinotify_event: tstamp:162653410671 tag:CHANSEL_NOMATCH channel:0x01 frame:2 vi_tstamp:162653243728 data:0x00000649
kworker/0:1-10177 [000] .... 5194.716607: rtcpu_vinotify_event: tstamp:162653756881 tag:FE channel:0x00 frame:2 vi_tstamp:162653753658 data:0x00000020
kworker/0:1-10177 [000] .... 5194.772527: rtcpu_vinotify_event: tstamp:162654278123 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:2 vi_tstamp:162653753658 data:0x01000000
kworker/0:1-10177 [000] .... 5194.772529: rtcpu_vinotify_event: tstamp:162654278268 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:162628535136 data:0x01020001
kworker/0:1-10177 [000] .... 5194.772531: rtcpu_vinotify_event: tstamp:162654278436 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:162653753660 data:0x00000000
kworker/0:1-10177 [000] .... 5194.772532: rtcpu_vinotify_event: tstamp:162654278574 tag:FS channel:0x00 frame:3 vi_tstamp:162653762575 data:0x00000010
kworker/0:1-10177 [000] .... 5194.772533: rtcpu_vinotify_event: tstamp:162654278735 tag:CHANSEL_NOMATCH channel:0x01 frame:3 vi_tstamp:162653762657 data:0x00000649
kworker/0:1-10177 [000] .... 5194.772535: rtcpu_vinotify_event: tstamp:162654278871 tag:FE channel:0x00 frame:3 vi_tstamp:162654272587 data:0x00000020
kworker/0:1-10177 [000] .... 5194.772536: rtcpu_vinotify_event: tstamp:162654820509 tag:FS channel:0x00 frame:4 vi_tstamp:162654281505 data:0x00000010
kworker/0:1-10177 [000] .... 5194.772537: rtcpu_vinotify_event: tstamp:162654820646 tag:CHANSEL_NOMATCH channel:0x01 frame:4 vi_tstamp:162654281586 data:0x00000649
kworker/0:1-10177 [000] .... 5194.772539: rtcpu_vinotify_event: tstamp:162654820806 tag:FE channel:0x00 frame:4 vi_tstamp:162654791515 data:0x0000002
The details could see trace-log-1101
trace-log-1101 (92.3 KB)
Thank your help me to solve this issue…
hello ultwcz1997,
this failure, tegra194-vi5 15c10000.vi: no reply from camera processor
it meant VI engine cannot receive camera frames.
could you please use $ v4l2-ctl -d /dev/video0 --list-formats-ext
to examine the reported sensor formats.
BTW,
I doubt this is command, -c sensor_mode=60
. do you really have 60 sensor modes available?
are you going to call TEGRA_CAMERA_CID_SENSOR_MODE_ID
for mode selections? it should be sensor_modes
as control flag.
hello @JerryChang ,
Index : 0
Type : Video Capture
Pixel Format: 'GREY'
Name : 8-bit Greyscale
Size: Discrete 1920x1200
Interval: Discrete 0.017s (60.000 fps)
Interval: Discrete 0.008s (120.000 fps)
Size: Discrete 1920x1080
Index : 1
Pixel Format: 'Y10 '
Name : 10-bit Greyscale
Sorry, sensor_mode
wrote error.
BTW, the $v4l2-ctl --get-fmt-video -d /dev/video0
shows follow,
Format Video Capture:
Width/Height : 1920/1200
Pixel Format : 'Y10 '
Field : None
Bytes per Line : 3840
Size Image : 4608000
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Why it only shows one format, what should i do next?
Thank you.
hello ultwcz1997,
may I know what’s your sensor device tree settings, did you report pixel format correctly?
please see-also Sensor Software Driver Programming , you may review [Property-Value Pairs] settings.
thanks
Hi,JerryChang,
Thanks you reply.
The device tree settings is following:
i2c@3180000 {
tca9548@70 {
i2c@0 {
ar0234_a@10 {
compatible = "nvidia,ar0234";
reg = <0x10>;
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "5.78";
physical_h = "3.62";
sensor_model ="ar0234";
use_sensor_mode_id = "true";
/* Sensor output flip and mirror settings */
vertical-flip = "false";
horizontal-mirror = "false";
mode0 { /* mode ar0234_mode_1920x1200_10bit_60fps */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1200";
mode_type = "mono";
pixel_phase = "grey";
csi_pixel_bit_depth = "10";
readout_orientation = "0";
line_length = "2448"; // 0x0264 *4
inherent_gain = "1";
//mclk_multiplier = "2";
pix_clk_hz = "180000000";
gain_factor = "128";
min_gain_val = "128"; /* 1x */
max_gain_val = "2048"; /* 15.9924x */
step_gain_val = "1"; /* 1/128 */
default_gain = "128";
framerate_factor = "1000000";
min_framerate = "1121986"; /* 1.12 fps */
max_framerate = "60000000"; /* 60 fps */
step_framerate = "1";
default_framerate = "60000000";
exposure_factor = "1000000";
min_exp_time = "14"; /* 13.6us */
max_exp_time = "890936"; /* us */
step_exp_time = "1";
default_exp_time = "2500";
embedded_metadata_height = "0";
mode1 { /* mode ar0234_mode_1920x1200_8bit_60fps */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1200";
mode_type = "mono";
csi_pixel_bit_depth = "8";
min_exp_time = "14"; /* us */
mode2 { /* mode ar0234_mode_910x600_10bit_120fps */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "910";
active_h = "600";
mode_type = "mono";
line_length = "612"; // 0x02D8 * 2
pix_clk_hz = "45000000"; // 100 MHz -> 800Mbps -> 800 / 10 = 80Mpix(pre lane), 2 lane(must multiplier 2)
min_gain_val = "128"; /* 1 dB */
max_gain_val = "2048"; /* 16 dB */
step_gain_val = "1"; /* 0.0625 dB */
min_framerate = "1121986"; /* 1.67 fps */
max_framerate = "120000000"; /* 120 fps */
default_framerate = "120000000";
mode3 { /* mode ar0234_mode_910x600_8bit_120fps */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "910";
active_h = "600";
mode_type = "mono";
max_framerate = "120000000"; /* 210 fps */
mode4 { /* mode ar0234_mode_1920x1080_10bit_60fps */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
mode_type = "mono";
line_length = "2448"; // 0x0264 * 4
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
ar0234_out0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&ar0234_csi_in0>;
PS: mode2-mode4 is not really correct.
Thank you.
these two were incorrect.
please check Property-Value Pairs session for the table that describe the entries.
Hi JerryChang,
This is already fixed in the driver, and i have used it in ov9282 sensor sussessfully.
The main problem is register configuration uncorrectlly.
Thanks your suggestions.
system
Closed
November 29, 2022, 3:45am
#12
