I want to use AGX to design a high speed sortation equipment,this equipment has 16 channels ,that means ,i need 16 GPIOs to control 16 ralays,so can the AGX
make 16 of 40pins to be push-pull output mode.thank you!The I2S, SPI, UART … function pin can be used as GPIOs as well, Please check datasheet for the signal level and IO type. And software need config the pin correctly.
ok,thank you for your answer.i have a moderate request,the information that the datasheet can give me i can not understand very well, so can you give me a definite answer whether agx can provide 16 GPIOs,.no matter whether you can give me the answer, i thank you very much.
Except the dedicated signal, such as clock/DDR/CSI/HDMI/JTAG/USB and system control(reset, Power on …), The others pins could config as a GPIOs function. The pinmux table file give it more clear. AGX could provide more than 16 GPIOs.
very thank you for you answer
