Hi, community:
I am not sure about the parameter tap power in table raypaths, i.e., SELECT tap_power FROM raypaths.
In user guide, tap power is described as power of the raypath channel tap in Watts. Does it mean that this power takes the tx and rx antenna element (angle, polarization, beamwidth) into acount?
In other word, I was wondering if tap power can be regarded as RSSI in the given raypath or received power.
Thank you.
