The results of my CUDA code are absurds
Hello!!!
I wrote a code for computing the value of a vanilla call using Monte Carlo (you don’t have to know what it is to help me :) ). The results that I get are absurds in the sense that the prices are sometimes negatives, which is normaly impossible and sometimes very high (which is also very weird). I think that the mistake that I made is related to the sizes of the arrays. But I don’t know where it is. I have been trying to debug it for days without success. So I was hoping you could help me with it. Thanks in advance.
Here is the code:
#include <curand_kernel.h>
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <curand.h>
#include <time.h>
#define NBLOCKS 128
#define NTHREADS 128
#define NUMSIM 1e05
#define MAX 10000000
global void inistate(unsigned int initialSeed, curandState * state)
unsigned int tid = threadIdx.x + blockIdx.x * blockDim.x;
curand_init(initialSeed, tid, 0, & state[tid]);
device inline float getUdlValueAtMaturity(const float & S0, const float & drift, const float & diffusion, curandState & state)
return S0*expf(drift + diffusion * curand_normal(& state));
device inline float getPayoff(const float & ST, const float & K)
return max(ST - K, 0.0f);
struct Option
float S0;
float K;
float r;
float vol;
float T;
float premium;
enum OptionType
Call,
Put
OptionType optionType;
device float reduce_sum(double in)
shared float sdata[NTHREADS];
// - Write to shared memory
unsigned int ltid = threadIdx.x;
sdata[ltid] = in;
__syncthreads();
for (unsigned int s = blockDim.x / 2 ; s > 0 ; s >>= 1)
    if (ltid < s)
        sdata[ltid] += sdata[ltid + s];
    __syncthreads();
return sdata[0];
global void do_mc_simul(curandState * state, float * result, Option * option, const unsigned int n)
unsigned int dim = gridDim.x * blockDim.x;
float drift = (option->r - 0.5f*powf(option->vol, 2.0f))*option->T;
float diffusion = option->vol * sqrtf(option->T);
curandState tidState = state[tid];
float sumPayoff = 0.0f;
float ST = 0.0f;
for(unsigned int i = tid; i < n; i += dim)
ST = getUdlValueAtMaturity(option->S0, drift, diffusion, tidState);
sumPayoff += getPayoff(ST, option->K);
sumPayoff = reduce_sum(sumPayoff);
if(threadIdx.x == 0)
result[dim] = sumPayoff;
int main()
srand(time(NULL));
dim3 block;
dim3 grid;
block.x = (unsigned int) NTHREADS;
grid.x  = (unsigned int) (NUMSIM + NTHREADS - 1) / (NTHREADS);
unsigned int initialSeed = (unsigned int) (rand() % (MAX + 1));
Option * devCallOption;
float * devResults = 0;
printf(“Seed : %d.\n”, initialSeed);
// Allocate memory on the CPU for the Call Option
Option * hostCallOption = (Option *) malloc(sizeof(Option));
float * hostResults = (float *) malloc(grid.x * sizeof(float));
curandState * devState = 0;
cudaMalloc((void **) & devState, grid.x * block.x * sizeof(curandState));
cudaMalloc((void **) & devResults, grid.x * sizeof(float));
cudaMalloc((void **) & devCallOption, sizeof(Option));
hostCallOption->S0 = 50.0f;
hostCallOption->K = 44.0f;
hostCallOption->r = 0.05f;
hostCallOption->vol = sqrtf(0.1f);
hostCallOption->T = 1.0f;
hostCallOption->premium = 0.0f;
printf(“S0 : %f. \n”, hostCallOption->S0);
printf(“K : %f. \n”, hostCallOption->K);
printf(“r : %f. \n”, hostCallOption->r);
printf(“vol : %f. \n”, hostCallOption->vol);
printf(“T : %f. \n”, hostCallOption->T);
printf(“premium : %f. \n”, hostCallOption->premium);
cudaMemcpy(devCallOption, hostCallOption, sizeof(Option), cudaMemcpyHostToDevice);
inistate<<<grid, block>>>(initialSeed, devState);
do_mc_simul<<<grid, block, block.x * sizeof(float)>>>(devState, devResults, devCallOption, NUMSIM);
cudaMemcpy(hostResults, devResults, grid.x * sizeof(float), cudaMemcpyDeviceToHost);
printf(“value of gridx : %d\n”, grid.x);
for(unsigned int i = 0; i < grid.x; ++i)
printf(“host result %d : %f\n”, i, hostResults[i]);
hostCallOption->premium += hostResults[i];
hostCallOption->premium /= NUMSIM;
hostCallOption->premium *= expf(-hostCallOption->r * hostCallOption->T);
printf(“The price of the call is %f.\n\n”, hostCallOption->premium);
cudaFree(devCallOption);
cudaFree(devResults);
cudaFree(devState);
free(hostCallOption);
free(hostResults);
Check all return codes from CUDA functions for errors.
Could you be more specific? I don’t understand what you mean. Thanks.
cudaError_t err = cudaMemcpy(hostResults, devResults, grid.x * sizeof(float), cudaMemcpyDeviceToHost);
if (err != cudaSuccess)
    fprintf(stderr, "cudaMemcpy returned %s\n", cudaGetErrorString(err));
and do that for every CUDA call.
It’s easy to do with the help of a little macro
#define CHECK_CUDA_ERROR(x) {cudaError_t err__ = (x); if (err__!=cudaSuccess) fprintf(stderr, #x " returned \"%s\"\n", cudaGetErrorString(err__));}
and wrapping all CUDA calls into it.
Compile your code with extra flags -g -G to add debug information and then run the cuda-memcheck and cuda-gdb programs to debug them. In my experience when I was accessing out of bonds I was often getting some huge negative numbers.
