I’m not sure why, but when I tried to measure branch efficiency using nsight system, I couldn’t get good results. Could you please let me know if I did anything wrong? Thank you.
sudo ncu --metrics all -c 5 ./thread_branch_efficiency_test
__global__ void mathKernel1(float *c)
int tid = blockIdx.x* blockDim.x + threadIdx.x;
float a = 0.0;
float b = 0.0;
if (tid % 2 == 0)
a = 100.0f;
else
b = 200.0f;
c[tid] = a + b;
__global__ void mathKernel2(float *c)
float a = 0.0;
float b = 0.0;
if ((tid/warpSize) % 2 == 0)
a = 100.0f;
else
b = 200.0f;
c[tid] = a + b;
__global__ void mathKernel3(float *c)
float a = 0.0;
float b = 0.0;
bool ipred = (tid % 2 == 0);
if (ipred)
a = 100.0f;
else
b = 200.0f;
c[tid] = a + b;
int main(int argc, char **argv)
int dev = 0;
cudaDeviceProp deviceProp;
cudaGetDeviceProperties(&deviceProp, dev);
printf("%s using Device %d: %s\n", argv[0], dev, deviceProp.name);
//set up data size
int size = 64;
int blocksize = 64;
if (argc > 1) blocksize = atoi(argv[1]);
if (argc > 2) size = atoi(argv[2]);
printf("Data size %d ", size);
//set up execution configuration
dim3 block(blocksize,1);
dim3 grid((size - 1) / block.x + 1,1);
printf("Execution Configure (block %d grid %d)\n", block.x, grid.x);
//allocate gpu memory
float * C_dev;
size_t nBytes = size * sizeof(float);
float * C_host=(float*)malloc(nBytes);
cudaMalloc((float**)&C_dev, nBytes);
//run a warmup kernel to remove overhead
double iStart, iElaps;
cudaDeviceSynchronize();
iStart = cpuSecond();
warmup<<<grid,block>>> (C_dev);
iElaps = cpuSecond() - iStart;
printf("warmup <<<%d,%d>>>elapsed %lf sec \n", grid.x, block.x, iElaps);
//run kernel 1
mathKernel1 <<< grid,block >>> (C_dev);
printf("mathKernel1<<<%4d,%4d>>>elapsed %lf sec \n", grid.x, block.x, iElaps);
cudaMemcpy(C_host,C_dev,nBytes,cudaMemcpyDeviceToHost);
//for(int i=0;i<size;i++)
// printf("%f ",C_host[i]);
//run kernel 2
mathKernel2 <<<grid,block >>> (C_dev);
printf("mathKernel2<<<%4d,%4d>>>elapsed %lf sec \n", grid.x, block.x, iElaps);
//run kernel 3
mathKernel3 <<<grid, block >>> (C_dev);
printf("mathKernel3<<<%4d,%4d>>>elapsed %lf sec \n", grid.x, block.x, iElaps);
cudaFree(C_dev);
free(C_host);
cudaDeviceReset();
return EXIT_SUCCESS;
