DRIVE OS Version: 7.0.3
Issue Description:
I have a question regarding the support status of the Docker runtime on the target device (ARM architecture) in DRIVE OS 7.
According to the Docker Services documentation for DRIVE OS 7.0.3, there is the following statement:
“The Docker runtime present in the NVIDIA DriveOS Linux Guest OS is from upstream Ubuntu Canonical repositories and is considered experimental on non-amd64 architectures.”
Since the DRIVE AGX platform is based on ARM (aarch64), this implies that running Docker on the target is currently treated as “experimental.”
Could you please clarify if there are plans to officially support the Docker runtime on ARM architectures in future releases? I would like to know if there is a roadmap to move this from an experimental feature to a fully supported one for production environments.
Thank you.
Currently we don’t have plan. May I know why you need this feature. Do you have any any use case?
Hi, thanks for the reply.
Here is our main use case: We are currently using Docker on Jetson AGX to manage complex dependencies for our autonomous driving system.
We plan to port this system to DRIVE AGX (DRIVE OS) and want to use Docker in the exact same way (for dependency management during development and CI).
So, our core question is: What does “experimental” really mean here?
Does it mean “it probably works, but NVIDIA hasn’t validated it, so it’s unsupported (use at your own risk)”?
Or does it mean “it has known fatal issues (like instability) and we shouldn’t even try it for development”?
Knowing this distinction is critical for our porting strategy.
Dear @nobuo.takamasa ,
Experimental means, we have not fully tested it and some features may not work. So we recommend not to use in production.
Thank you for the clarification. That clearly explains the status and is very helpful for our planning.
We appreciate your support.
