I’m currently working on our custom board, using I2S0 and I2C2 to control the ALC5640 audio codec. I’ve modified the device tree based on the framework diagram I prepared, but I’m not getting any audio output. Additionally, when I try to play a sound file, it finishes playback almost instantly — as if it’s not using the correct sample rate or clocking.
When I check the kernel logs using dmesg, it seems that the APE isn’t being loaded properly. However, when I run cat /proc/asound/cards, the APE card does appear in the list.
Below is the framework diagram I’ve put together, along with the relevant device tree changes.
dmesg
test@tac3000pro-ubuntu:/boot/dtb$ sudo dmesg |grep card
[ 7.369712] No soundcards found.
[ 15.034012] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/3510000.hda/sound/card0/input2
[ 15.035354] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/3510000.hda/sound/card0/input3
[ 15.036427] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/3510000.hda/sound/card0/input4
[ 15.037536] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/3510000.hda/sound/card0/input5
test@tac3000pro-ubuntu:/boot/dtb$ cat /proc/asound/cards
0 [HDA ]: tegra-hda - NVIDIA Jetson Orin NX HDA
NVIDIA Jetson Orin NX HDA at 0x3518000 irq 120
1 [APE ]: tegra-ape - NVIDIA Jetson Orin NX APE
NVIDIA-NVIDIAJetsonOrinNXEngineeringReferenceDeveloperKitSuper-NotSpecified-Jet
device tree kernel_tegra234-p3768-0000+p3767-0000-nv-super.txt (316.7 KB)
Could anyone help me identify what might be missing or incorrect in the device tree configuration? Any suggestions would be greatly appreciated.
Logs doesn’t seem correct. Could you please re-share ‘pinconf-groups’ sysfs logs.
DT update is required, add the routing and widget properties in sound node and link-name in I2S2 dai-link as mentioned here Custom audio card.
For playback from HP use the route mentioned under heading “For stereo playback to both playback ports“ here Codec playback route. Make sure to use ‘I2S2 Mux’ rather than ‘I2S1 Mux’.
Please note, for LOUT the routing property needs to be updated and also the mixer controls settings.
I used these settings and changed I2S1 to I2S2, but the result is not satisfactory.
I’m wondering if I need to modify other dai-link entries in the device tree, since the audio plays back extremely fast when I play music.
It’s been a while since the last update, so I’d like to kindly follow up on this thread.
Has there been any progress or feedback regarding this issue? I’m still encountering the problem and would really appreciate any guidance on whether my configuration might be incorrect or if there are known fixes.
Thank you for your response. After the modification, I can now see APE messages in the dmesg output.I configured it according to this.
but there is still no sound from the headphone. Additionally, when I play an audio file, it finishes playback extremely quickly.But the microphone seems to be working normally.
