The RTSP video stream output by deepstream 5.0 can only be viewed by one VLC player and cannot be opened by two people at the same time
VLC rtsp://localhost:8554/ds-test
• DeepStream Version
• TensorRT Version
For achieving this use-case in deepstream-app, you can enable two RTSP sinks with different port number, in config file. If you successfully set the config file, the prints will be like:
i = 1
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
i = 2
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8555/ds-test ***
