The sensor chip does not reset at jetson TX1 R28.2.
I find the CAM2_RST_L is always low, can not to high.
Who can help me fix this question?
the dtsi is below:
reset-gpios = <&gpio CAM2_RST_L GPIO_ACTIVE_HIGH>;
the dtsi is below:
hello sensor_test,
could you please share the steps and logs to show that CAM2_RST_L is always low.
also, there’s only CAM0_RST and CAM1_RST gpios in the TX1’s pinmux spreadsheet.
may i know which tegra-gpio you would like to use.
thanks
Pleases see as below:
#define CAM2_RST_L TEGRA_GPIO(S, 7)
hello sensor_test,
I can not find CAM2_RST_L in the debug/gpio.
and jetson tx1 syslog.log,I can not find the CAM2_RST_L
nvidia@tegra-ubuntu:~$ sudo cat /sys/kernel/debug/gpio
[sudo] password for nvidia:
Sorry, try again.
GPIOs 0-255, platform/6000d000.gpio, tegra-gpio:
gpio-2 ( |pcie_wake ) in hi
gpio-56 ( |wlan_pwr ) out hi
gpio-57 ( |rtl-5v0 ) out hi
gpio-58 ( |wlan-default-input-h) in lo IRQ
gpio-59 ( |bt_ext_wake ) out hi
gpio-60 ( |reset_gpio ) out lo
gpio-61 ( |bt_host_wake ) in lo IRQ
gpio-64 ( |wlan-default-output-) out hi
gpio-65 ( |wlan-default-input-i) in hi
gpio-66 ( |wlan-default-output-) out hi
gpio-67 ( |vdd-disp-3v0 ) out lo
gpio-87 ( |pwm-fan-tach ) in hi IRQ
gpio-148 ( |en-vdd-vcm-2v8 ) out lo
gpio-169 ( |lcd-bl-en ) out lo
gpio-188 ( |temp_alert ) in hi IRQ
gpio-189 ( |Power ) in hi IRQ
gpio-190 ( |Volume Up ) in hi IRQ
gpio-192 ( |Volume Down ) in hi IRQ
gpio-200 ( |extcon:extcon@1 ) in hi IRQ
gpio-201 ( |cd ) in hi IRQ
gpio-203 ( |en-vdd-sd ) out lo
gpio-204 ( |wp ) in hi
gpio-225 ( |hdmi2.0_hpd ) in hi IRQ
gpio-228 ( |usb-vbus1 ) out lo
gpio-229 ( |en-usb-vbus2 ) in hi
GPIOs 472-479, platform/max77620-gpio, max77620-gpio, can sleep:
gpio-472 ( |extcon:extcon@1 ) in hi
gpio-473 ( |vdd-sys-boost ) out hi
gpio-474 ( |spmic-default-output) out hi
gpio-475 ( |vdd-3v3 ) out hi
gpio-478 ( |enable ) out lo
gpio-479 ( |max77620-gpio7 ) out lo
GPIOs 480-495, i2c/1-0077, tca9539, can sleep:
gpio-483 ( |en-vdd-cam-1v2 ) out lo
gpio-489 ( |en-vdd-cam ) out lo
gpio-490 ( |en-vdd-cam-1v2-alt ) out lo
GPIOs 496-511, i2c/1-0074, tca9539, can sleep:
gpio-497 ( |en-vdd-ts-1v8 ) out lo
gpio-498 ( |en-vdd-ts-hv-3v3 ) out lo
gpio-499 ( |en-vdd-disp-3v3 ) out lo
gpio-500 ( |vdd-fan ) out hi
gpio-503 ( |en-mdm-pwr-3v7 ) out lo
gpio-505 ( |en-vdd-disp-1v8 ) out lo
gpio-508 ( |vdd-hdmi ) out hi
gpio-509 ( |en-vdd-cam-hv-2v8 ) out lo
syslog
[code]
Apr 12 03:05:42 tegra-ubuntu systemd-modules-load[218]: Inserted module ‘bluedroid_pm’
Apr 12 03:05:42 tegra-ubuntu systemd-modules-load[218]: Module ‘nvhost_vi’ is builtin
Apr 12 03:05:42 tegra-ubuntu rsyslogd: [origin software=“rsyslogd” swVersion=“8.16.0” x-pid=“528” x-info=“http://www.rsyslog.com”] start
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Remount Root and Kernel File Systems.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Load Kernel Modules.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Create list of required static device nodes for the current kernel.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started LVM2 metadata daemon.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Create Static Device Nodes in /dev…
Apr 12 03:05:42 tegra-ubuntu rsyslogd-2222: command ‘KLogPermitNonKernelFacility’ is currently not permitted - did you already set it via a RainerScript command (v6+ config)? [v8.16.0 try http://www.rsyslog.com/e/2222 ]
Apr 12 03:05:42 tegra-ubuntu rsyslogd: rsyslogd’s groupid changed to 115
Apr 12 03:05:42 tegra-ubuntu rsyslogd: rsyslogd’s userid changed to 108
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Mounting FUSE Control File System…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Mounting Configuration File System…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Apply Kernel Variables…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Load/Save Random Seed…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting udev Coldplug all Devices…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Flush Journal to Persistent Storage…
Apr 12 03:05:42 tegra-ubuntu systemd-sysctl[243]: Couldn’t write ‘1’ to ‘net/ipv4/tcp_syncookies’, ignoring: No such file or directory
Apr 12 03:05:42 tegra-ubuntu systemd-sysctl[243]: Couldn’t write ‘1’ to ‘kernel/yama/ptrace_scope’, ignoring: No such file or directory
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Mounted Configuration File System.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Mounted FUSE Control File System.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Apply Kernel Variables.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Load/Save Random Seed.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Create Static Device Nodes in /dev.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting udev Kernel Device Manager…
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Initializing cgroup subsys cpuset
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Initializing cgroup subsys cpuacct
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Linux version 4.4.38+ (ros@ubuntu) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #2 SMP PREEMPT Wed Apr 11 01:33:18 PDT 2018
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Boot CPU: AArch64 Processor [411fd071]
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] cma: Reserved 16 MiB at 0x00000000fdc00000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] On node 0 totalpages: 1043456
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Flush Journal to Persistent Storage.
Apr 12 03:05:42 tegra-ubuntu systemd-udevd[255]: Network interface NamePolicy= disabled on kernel command line, ignoring.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started udev Kernel Device Manager.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started udev Coldplug all Devices.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Found device /dev/ttyS0.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Reached target Sound Card.
Apr 12 03:05:42 tegra-ubuntu lvm[229]: /dev/mmcblk0rpmb: read failed after 0 of 4096 at 0: Input/output error
Apr 12 03:05:42 tegra-ubuntu rsyslogd-2039: Could not open output pipe ‘/dev/xconsole’:: No such file or directory [v8.16.0 try http://www.rsyslog.com/e/2039 ]
Apr 12 03:05:42 tegra-ubuntu lvm[229]: /dev/mmcblk0rpmb: read failed after 0 of 4096 at 4128768: Input/output error
Apr 12 03:05:42 tegra-ubuntu lvm[229]: /dev/mmcblk0rpmb: read failed after 0 of 4096 at 4186112: Input/output error
Apr 12 03:05:42 tegra-ubuntu lvm[229]: /dev/mmcblk0rpmb: read failed after 0 of 4096 at 4096: Input/output error
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Apr 12 03:05:42 tegra-ubuntu rsyslogd-2007: action ‘action 9’ suspended, next retry is Thu Apr 12 03:06:12 2018 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Reached target Local File Systems (Pre).
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Reached target Local File Systems.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Create Volatile Files and Directories…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting LSB: AppArmor initialization…
Apr 12 03:05:42 tegra-ubuntu systemd-tmpfiles[284]: [/usr/lib/tmpfiles.d/var.conf:14] Duplicate line for path “/var/log”, ignoring.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Clean up any mess left by 0dns-up…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Tell Plymouth To Write Out Runtime Data…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Set console keymap…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Create Volatile Files and Directories.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Apr 12 03:05:42 tegra-ubuntu systemd-udevd[274]: Process ‘/bin/rm /var/lib/alsa/asound.state’ failed with exit code 1.
Apr 12 03:05:42 tegra-ubuntu systemd-udevd[265]: Process ‘/usr/sbin/alsactl -E HOME=/run/alsa restore 0’ failed with exit code 99.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Clean up any mess left by 0dns-up.
Apr 12 03:05:42 tegra-ubuntu systemd-udevd[267]: Could not generate persistent MAC address for ip6tnl0: No such file or directory
Apr 12 03:05:42 tegra-ubuntu systemd-udevd[270]: Could not generate persistent MAC address for dummy0: No such file or directory
Apr 12 03:05:42 tegra-ubuntu loadkeys[297]: Loading /etc/console-setup/cached.kmap.gz
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Set console keymap.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started LSB: AppArmor initialization.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Raise network interfaces…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Network Time Synchronization…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Update UTMP about System Boot/Shutdown…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Load/Save RF Kill Switch Status…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Network Time Synchronization.
Apr 12 03:05:42 tegra-ubuntu systemd-rfkill[453]: Failed to parse state file /var/lib/systemd/rfkill/platform-bluedroid_pm:bluetooth: Invalid argument
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Update UTMP about System Boot/Shutdown.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Reached target System Initialization.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Socket activation for snappy daemon.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Daily Cleanup of Temporary Directories.
Apr 12 03:05:42 tegra-ubuntu systemd-udevd[267]: Process ‘/usr/sbin/alsactl -E HOME=/run/alsa restore 1’ failed with exit code 99.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Listening on RPCbind Server Activation Socket.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Listening on GPS (Global Positioning System) Daemon Sockets.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started CUPS Scheduler.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] DMA zone: 8192 pages used for memmap
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] DMA zone: 0 pages reserved
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] DMA zone: 519168 pages, LIFO batch:31
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Normal zone: 8192 pages used for memmap
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Normal zone: 524288 pages, LIFO batch:31
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] psci: probing for conduit method from DT.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] psci: PSCIv1.0 detected in firmware.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc0ffe65000 s31616 r8192 d29824 u69632
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] pcpu-alloc: s31616 r8192 d29824 u69632 alloc=17*4096
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] CPU features: enabling workaround for ARM erratum 832075
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1027072
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Reached target Paths.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Listening on D-Bus System Message Bus Socket.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Listening on CUPS Scheduler.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Reached target System Time Synchronized.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: apt-daily.timer: Adding 3h 21min 295.422ms random time.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Daily apt activities.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Reached target Timers.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Listening on Socket activation for snappy daemon.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Reached target Sockets.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Reached target Basic System.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Configure USB flashing port for device mode.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Permit User Sessions…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started GPS (Global Positioning System) Daemon.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Run anacron jobs.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started crash report submission daemon.
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Login Service…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting System Logging Service…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started Regular background program processing daemon.
Apr 12 03:05:42 tegra-ubuntu anacron[512]: Anacron 2.3 started on 2018-04-12
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting NVIDIA specific first-boot script…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Accounts Service…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Modem Manager…
Apr 12 03:05:42 tegra-ubuntu systemd-rfkill[453]: Failed to parse state file /var/lib/systemd/rfkill/platform-sdhci-tegra.1:wlan: Invalid argument
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Save/Restore Sound Card State…
Apr 12 03:05:42 tegra-ubuntu anacron[512]: Normal exit (0 jobs run)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03236161235350000406 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1075 core_edp_ma=4000 gpt root=/dev/mmcblk0p1 rw rootwait
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting Avahi mDNS/DNS-SD Stack…
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Starting LSB: Speech Dispatcher…
Apr 12 03:05:42 tegra-ubuntu cron[535]: (CRON) INFO (pidfile fd = 3)
Apr 12 03:05:42 tegra-ubuntu systemd[1]: Started D-Bus System Message Bus.
Apr 12 03:05:42 tegra-ubuntu dnsmasq[516]: dnsmasq: syntax check OK.
Apr 12 03:05:42 tegra-ubuntu cron[535]: (CRON) INFO (Running @reboot jobs)
Apr 12 03:05:42 tegra-ubuntu ModemManager[546]: ModemManager (version 1.4.12) starting in system bus…
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Memory: 4061860K/4173824K available (11233K kernel code, 2059K rwdata, 6404K rodata, 1192K init, 662K bss, 95580K reserved, 16384K cma-reserved)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Virtual kernel memory layout:
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc6000000 ( 64 MB actual)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] .init : 0xffffffc0011ba000 - 0xffffffc0012e4000 ( 1192 KB)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] .text : 0xffffffc000080000 - 0xffffffc0011b9db4 ( 17640 KB)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] .data : 0xffffffc0012ff000 - 0xffffffc001501d10 ( 2060 KB)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Preemptible hierarchical RCU implementation.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Build-time adjustment of leaf fanout to 64.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] NR_IRQS:64 nr_irqs:64 0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] enable_t210_agic_clks:106 ape clocked & reset cleared
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] t210 clock_and_reset probe
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] clk_cbus_recalc_rate: no gbus parent
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] kmemleak: Kernel memory leak detector disabled
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.000004] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.001284] Console: colour dummy device 80x25
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.002220] console [tty0] enabled
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.002252] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.002287] pid_max: default: 32768 minimum: 301
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.002369] Security Framework initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.002391] SELinux: Initializing.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.002456] SELinux: Starting in permissive mode
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.002492] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.002518] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003178] Initializing cgroup subsys io
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003210] Initializing cgroup subsys memory
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003248] Initializing cgroup subsys devices
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003274] Initializing cgroup subsys freezer
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003300] Initializing cgroup subsys net_cls
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003324] Initializing cgroup subsys perf_event
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003349] Initializing cgroup subsys net_prio
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003377] Initializing cgroup subsys pids
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003401] Initializing cgroup subsys debug
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003669] CPU0 ipc=1024
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003704] CPU1 ipc=1024
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003734] CPU2 ipc=1024
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003765] CPU3 ipc=1024
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.003825] ASID allocator initialised with 65536 entries
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.025403] tegra-id: chipid=22117.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.025432] tegra-id: opt_subrevision=0.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.025464] Tegra Speedo/IDDQ fuse revision 4
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.025485] Tegra: CPU Speedo ID 7, SoC Speedo ID 0, GPU Speedo ID 2
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.025506] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.025528] Tegra: CPU Speedo Value 2094, SoC Speedo Value 1997, GPU Speedo Value 2103
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.025557] Tegra: CPU IDDQ Value 2340, SoC IDDQ Value 2724, GPU IDDQ Value 3290
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.025600] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 SoC Process: 1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.026803] DTS File Name: /home/ros/JetPack-L4T-3.2/64_TX1/Linux_for_Tegra/sources/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.026854] DTB Build time: Apr 11 2018 01:34:18
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.040764] CPU1: Booted secondary processor [411fd071]
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.052732] CPU2: Booted secondary processor [411fd071]
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.064724] CPU3: Booted secondary processor [411fd071]
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.064805] Brought up 4 CPUs
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.064879] SMP: Total of 4 processors activated.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.064903] CPU: All CPU(s) started at EL2
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.064946] alternatives: patching kernel code
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.067458] devtmpfs: initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.122181] Initilizing CustomIPI irq domain
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.122504] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.123087] pinctrl core: initialized pinctrl subsystem
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.123268] OS set in device tree is not L4T.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.123613] regulator-dummy: no parameters
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.123828] Initializing plugin-manager
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.123894] Plugin module not found
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.124090] node /plugin-manager/fragement@0 match with board >=2180-1000-300
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.125436] Adding domain ape-pd to PM domain mc-clk-pd
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.125484] Adding domain adsp-pd to PM domain ape-pd
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.129222] NET: Registered protocol family 16
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.131033] console [pstore-1] enabled
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.131057] pstore: Registered ramoops as persistent store backend
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.131083] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.140221] cpuidle: using governor ladder
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.152212] cpuidle: using governor menu
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.152523] bpmp: mail init ok
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.153379] vdso: 2 pages (1 code @ ffffffc001305000, 1 data @ ffffffc001304000)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.153437] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.154860] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.155829] tegra_powergate_init: DONE
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.155872] DTS File Name: /home/ros/JetPack-L4T-3.2/64_TX1/Linux_for_Tegra/sources/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.155925] DTB Build time: Apr 11 2018 01:34:18
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.158007] tegra_bpmp_of_clk_init: EMC proxy not found.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.158048] Error: Driver ‘tegra-mc’ is already registered, aborting…
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.159474] platform tegra-carveouts: SMMU isn’t ready yet
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.160170] platform tegra-carveouts: domain=ffffffc0fa0b8618 allocates as[0]=ffffffc0fa0cc0a8
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.160267] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.160502] platform smmu_test: domain=ffffffc0fa0b8918 allocates as[0]=ffffffc0fa0cc110
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.160822] platform 70016000.bpmp: domain=ffffffc0fa0b8c18 allocates as[0]=ffffffc0fa0cc178
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.161508] bpmp: ping status is 0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.161612] bpmp 70016000.bpmp: firmware tag is 1e4b302fc0f866f97885165cf8b395ac
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.161863] bpmp 70016000.bpmp: probe ok
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.162513] mc: mapped MMIO address: 0xffffff800007e000 → 0x70019000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.162615] mc: mapped MMIO address: 0xffffff80000b6000 → 0x7001c000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.162713] mc: mapped MMIO address: 0xffffff80000dc000 → 0x7001d000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.162803] mc-err: Set intmask: 0x23d40
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.174137] GPIO line 58 (wlan-default-input-h2) hogged as input
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.174184] GPIO line 65 (wlan-default-input-i1) hogged as input
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.174229] GPIO line 56 (wlan-default-output-high-h0) hogged as output/high
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.174269] GPIO line 64 (wlan-default-output-high-i0) hogged as output/high
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.174310] GPIO line 66 (wlan-default-output-high) hogged as output/high
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.174416] gpiochip_add_data: registered GPIOs 0 to 255 on device: tegra-gpio
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.176889] platform 70006000.serial: domain=ffffffc0fa12d118 allocates as[0]=ffffffc0fa0cc1e0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.178000] platform sound: domain=ffffffc0fa12da18 allocates as[0]=ffffffc0fa0cc248
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.180455] platform tegradc.1: domain=ffffffc0fa132c18 allocates as[0]=ffffffc0fa0cc2b0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.183026] platform 57000000.gpu: domain=ffffffc0fa167f18 allocates as[0]=ffffffc0fa0cc318
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.183107] platform 57000000.gpu: domain=ffffffc0fa167f18 allocates as[1]=ffffffc0fa0cc380
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.183183] platform 57000000.gpu: domain=ffffffc0fa167f18 allocates as[2]=ffffffc0fa0cc3e8
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.183253] platform 57000000.gpu: domain=ffffffc0fa167f18 allocates as[3]=ffffffc0fa0cc450
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.183957] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.184000] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.184027] tegra-pmc: ### PMC reset source: Power on reset
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.184049] tegra-pmc: ### PMC reset status reg: 0x0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.228336] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.228373] tegra-pmc: Clear bootloader IO dpd settings
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.228403] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.228474] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.231685] platform 1003000.pcie-controller: domain=ffffffc0fa1af018 allocates as[0]=ffffffc0fa0cc4b8
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.233976] platform sdhci-tegra.3: domain=ffffffc0fa1b5118 allocates as[0]=ffffffc0fa0cc520
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.234587] platform sdhci-tegra.0: domain=ffffffc0fa1b5518 allocates as[0]=ffffffc0fa0cc588
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.241481] vdd-ac-bat: 5000 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.242688] vdd-cpu-fixed: 1000 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.246552] irq: no irq domain found for /soctherm@0x700E2000 !
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.246871] irq: no irq domain found for /soctherm@0x700E2000 !
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.269501] ACPI: Interpreter disabled.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.270299] SCSI subsystem initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.270376] libata version 3.00 loaded.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.270587] usbcore: registered new interface driver usbfs
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.270657] usbcore: registered new interface driver hub
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.270755] usbcore: registered new device driver usb
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.273904] gpiochip_add_data: registered GPIOs 496 to 511 on device: tca9539
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.275355] gpiochip_add_data: registered GPIOs 480 to 495 on device: tca9539
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.279042] max77620 4-003c: PMIC Version OTP:0x3C and ES:0x8
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.281347] GPIO line 474 (spmic-default-output-high) hogged as output/high
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.281493] gpiochip_add_data: registered GPIOs 472 to 479 on device: max77620-gpio
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.284358] vdd-core: 600 <–> 1400 mV at 1075 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.288338] vddio-ddr: at 1125 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.289200] vdd-pre-reg: 1350 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.292205] vdd-1v8: 1800 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.296207] avdd-sys: 1200 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.300206] vdd-pex: 1050 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.300963] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.302024] vdd-cam-hv: 2800 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.304206] vdd-rtc: 850 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.305197] avdd-ts-hv: 3300 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.306194] vdd-ts: 1800 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.308207] vdd-gen-pll-edp: 1050 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.312206] vdd-hdmi-dp: 1050 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.312816] max77620 4-003c: max77620 probe successful
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.314814] media: Linux media interface: v0.10
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.314898] Linux video capture interface: v2.00
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.324245] tegra210-emc 7001b000.memory-controller: validated EMC DFS table
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.324671] Advanced Linux Sound Architecture Driver Initialized.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.327626] tegra210_dvfs: no clock found for sdmmc2_ddr
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.327675] tegra210_dvfs: no clock found for sdmmc4_ddr
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.327761] tegra210_dvfs: no clock found for sdmmc1_ddr
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.327802] tegra210_dvfs: no clock found for sdmmc3_ddr
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.329974] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.332213] vdd-3v3: 3300 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.336219] max77620-gpio7: 1050 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.336562] lcd-bl-en: 1800 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.336944] en-vdd-sd: 3300 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.345884] en-vdd-cam: 1800 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.348207] vdd-sys-boost: 5000 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.348853] vdd-hdmi: 5000 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.349101] aux-3v3: 3300 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.349326] snsr_pm: 3300 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.352210] vdd-disp-3v0: 3000 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.352888] vdd-fan: 5000 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.353167] usb-vbus1: 5000 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.353804] en-vdd-ts-1v8: 1800 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.361241] en-vdd-ts-hv-3v3: 3300 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.366668] en-vdd-disp-3v3: 3300 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.367336] en-mdm-pwr-3v7: 3700 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.368164] en-vdd-disp-1v8: 1800 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.368810] en-vdd-cam-hv-2v8: 2800 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.369100] rtl-5v0: 5000 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.369385] en-usb-vbus2: 5000 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.370025] en-vdd-cam-1v2: 1200 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.370330] en-vdd-vcm-2v8: 2800 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.370971] en-vdd-cam-1v2-alt: 1200 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.373724] extcon-gpio-states extcon:extcon@1: Cable state 0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.374905] clocksource: Switched to clocksource arch_sys_counter
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.422008] nvmap_heap_init: nvmap_heap_init: created heap block cache
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.422263] pnp: PnP ACPI: disabled
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.422461] nvmap_page_pool_init: Total RAM pages: 1019561
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.422488] nvmap_page_pool_init: nvmap page pool size: 127445 pages (497 MB)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.422593] nvmap_background_zero_thread: PP zeroing thread starting.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.422867] misc nvmap: iram :dma coherent mem declare 0x0000000040001000,258048
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.423057] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.436620] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.438588] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.439053] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.439276] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.441035] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.441341] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.441598] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.443048] isomgr_init(): iso emc max clk=1600000KHz
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.443076] isomgr_init(): max_iso_bw=11520000KB
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.443240] NET: Registered protocol family 2
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.443855] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.444074] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.444367] TCP: Hash tables configured (established 32768 bind 32768)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.444500] UDP hash table entries: 2048 (order: 4, 65536 bytes)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.444569] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.444838] NET: Registered protocol family 1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.445173] RPC: Registered named UNIX socket transport module.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.445229] RPC: Registered udp transport module.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.445251] RPC: Registered tcp transport module.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.445273] RPC: Registered tcp NFSv4.1 backchannel transport module.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.445311] PCI: CLS 0 bytes, default 128
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.445575] Trying to unpack rootfs image as initramfs…
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.455935] host1x 50000000.host1x: initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.457694] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.461349] futex hash table entries: 1024 (order: 5, 131072 bytes)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.461474] audit: initializing netlink subsys (disabled)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.461563] audit: type=2000 audit(0.455:1): initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.473711] ntfs: driver 2.1.32 [Flags: R/O].
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.474288] fuse init (API version 7.23)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.475194] SELinux: Registering netfilter hooks
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.477679] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.477833] io scheduler noop registered
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.477864] io scheduler deadline registered
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.478083] io scheduler cfq registered (default)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.484492] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.484540] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0xa26a411
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.484577] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486239] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486275] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486306] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486343] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486387] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486423] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486457] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486498] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486544] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486592] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486638] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486685] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486730] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.486778] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.487226] tegra21x-padctl-uphy 7009f000.pinctrl: mailbox is not ready yet
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.488221] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.489295] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.490024] Adding domain pcie-pd to PM domain mc-clk-pd
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.494046] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.494114] tegra-pcie 1003000.pcie-controller: failed to get PHY: -517
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.494160] tegra-pcie 1003000.pcie-controller: failed to get PHYs: -517
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.497431] tsec 54500000.tsec: initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.498828] tsec 54100000.tsecb: initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.501590] nvdec 54480000.nvdec: initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.506720] falcon 54340000.vic: initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.508105] falcon 544c0000.nvenc: initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.509076] falcon 54380000.nvjpg: initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.511069] DC OR NODE connected to /host1x/sor1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.511164] display board info: id 0xffff, fab 0x0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.511216] panel_select fail by _node_status
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.511271] display board info: id 0xffff, fab 0x0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.511316] panel_select fail by _node_status
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.511342] generic_infoframe_type: 0x87
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.511499] tegradc tegradc.1: DT parsed successfully
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.511555] tegradc tegradc.1: Display dc.ffffff8000980000 registered with id=0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.512478] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.512667] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=750000, max_bw=4687500
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.513337] display board info: id 0xffff, fab 0x0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.513389] panel_select fail by _node_status
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.517315] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.518709] tegradc tegradc.1: probed
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.522952] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.525003] tegra-adma 702e2000.adma: Tegra ADMA driver register 10 channels
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.526556] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.526864] kfuse 7000fc00.kfuse: initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.528753] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.529626] clk_cbus_round_rate: no gbus parent
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.529657] tegra_gpu_edp gpu_edp: unable to get max GPU freq
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.530166] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.530200] vdd-cpu: 708 <–> 1322 mV at 708 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.530264] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.531527] vdd-gpu: applied init 1000000uV constraint
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.531561] vdd-gpu: 710 <–> 1320 mV at 1000 mV
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.531623] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.532031] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.532165] No Device Node present for smmu client: serial8250 !!
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.532193] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.532232] No Device Node present for smmu client: serial8250 !!
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.532257] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.533324] No Device Node present for smmu client: serial8250 !!
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.533355] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.533404] No Device Node present for smmu client: serial8250 !!
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.533430] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.534104] console [ttyS0] disabled
Apr 12 03:05:42 tegra-ubuntu kernel: [ 0.534179] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 320, base_baud = 25500000) is a Tegra
Apr 12 03:05:42 tegra-ubuntu kernel: [ 1.162940] random: nonblocking pool is initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.465070] console [ttyS0] enabled
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.466482] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 321, base_baud = 0) is a TEGRA_UART
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.466997] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 322, base_baud = 0) is a TEGRA_UART
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.467338] serial-tegra 70006300.serial: RX in PIO mode
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.467439] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 323, base_baud = 0) is a TEGRA_UART
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.469138] Console: switching to colour frame buffer device 80x30
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.469742] gk20a 57000000.gpu: platform probe failed
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.479266] brd: module loaded
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.484747] loop: module loaded
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.485375] zram: Added device: zram0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.485385] Silicon Labs C2 port support v. 0.51.0 - (C) 2007 Rodolfo Giometti
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.485591] nct1008_nct72 0-004c: find device tree node, parsing dt
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.485596] nct1008_nct72 0-004c: starting parse dt
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.485675] nct1008_nct72 0-004c: success parsing dt
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.485884] nct1008_nct72 0-004c: success in enabling tmp451 VDD rail
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.604253] tegradc tegradc.1: fb registered
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.614780] tmp451: Enabled overheat logging at 102.00C
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.622247] nct1008_nct72 0-004c: nct1008_probe: initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.632500] THERMAL EST: found 2 subdevs
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.638509] THERMAL EST num_resources: 0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.644427] [THERMAL EST subdev 0]
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.649808] [THERMAL EST subdev 1]
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.655424] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.668161] THERMAL EST: thz register success.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.674603] THERMAL EST: end of probe, return err: 0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.681473] tegra_profiler: Branch: Dev
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.687091] tegra_profiler: Version: 1.117
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.692886] tegra_profiler: Samples version: 41
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.699057] tegra_profiler: IO version: 22
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.704746] armv8_pmu: imp: 0x41, idcode: 0x1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.710688] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.722165] armv8_pmu: imp: 0x41, idcode: 0x1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.728197] armv8_pmu: [1] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.739656] armv8_pmu: imp: 0x41, idcode: 0x1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.745693] armv8_pmu: [2] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.757367] armv8_pmu: imp: 0x41, idcode: 0x1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.763495] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.775422] tegra_profiler: auth: init
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.781522] tegra-ahci 70027000.sata: Missing devslp-active state
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.790399] Rounding down aligned max_sectors from 4294967295 to 4294967288
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.799845] spi-tegra114 7000d400.spi: Static pin configuration used
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.809017] spi-tegra114 7000da00.spi: Static pin configuration used
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.818683] tun: Universal TUN/TAP device driver, 1.6
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.825636] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.834130] PPP generic driver version 2.4.2
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.840517] PPP BSD Compression module registered
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.847148] PPP Deflate Compression module registered
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.854176] PPP MPPE Compression module registered
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.860952] NET: Registered protocol family 24
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.867461] usbcore: registered new interface driver r8152
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.875028] usbcore: registered new interface driver asix
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.882449] usbcore: registered new interface driver ax88179_178a
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.890480] usbcore: registered new interface driver cdc_ether
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.898219] usbcore: registered new interface driver smsc95xx
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.905795] usbcore: registered new interface driver net1080
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.913199] usbcore: registered new interface driver cdc_subset
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.920819] usbcore: registered new interface driver zaurus
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.928066] usbcore: registered new interface driver cdc_ncm
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.935356] usbcore: registered new interface driver cdc_acm
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.942466] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.953384] usbcore: registered new interface driver usb-storage
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.960988] usbcore: registered new interface driver usbserial
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.968315] usbcore: registered new interface driver ftdi_sio
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.975463] usbserial: USB Serial support registered for FTDI USB Serial Device
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.985551] usbcore: registered new interface driver option
Apr 12 03:05:42 tegra-ubuntu kernel: [ 2.992610] usbserial: USB Serial support registered for GSM modem (1-port)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.001099] usbcore: registered new interface driver pl2303
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.008179] usbserial: USB Serial support registered for pl2303
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.016608] tegra-xudc-new 700d0000.xudc: usb2 phy is not available yet
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.156686] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc1
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.169410] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.178244] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.186550] i2c /dev entries driver
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.193217] regulator_get() failed for (1-0010,vana), -19
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.200423] imx219 1-0010: camera_common_regulator_get vana ERR: ffffffffffffffed
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.211682] regulator_get() failed for (1-0010,vdig), -19
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.219102] imx219 1-0010: camera_common_regulator_get vdig ERR: ffffffffffffffed
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.232013] IR NEC protocol handler initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.238802] IR Sharp protocol handler initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.245706] IR XMP protocol handler initialized
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.252454] usbcore: registered new interface driver uvcvideo
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.260361] USB Video Class driver (1.1.1)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.266926] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.277903] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.287261] tegra_soctherm 700e2000.soctherm: pllx_offset tz:1 max:8, min:4
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.296933] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.310173] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.323596] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.337360] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.350781] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.364445] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.378454] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature 2147483647 forced to 127000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.392324] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.406063] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.419157] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.430198] tegra_aotag tegra-aotag: Registering sensor 0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.438262] tegra_aotag tegra-aotag: Bound to TZ : ID 0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.446036] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.454918] FAN dev name: pwm-fan
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.460718] FAN:gpio request success.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.466911] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.475375] pwm_fan_driver pwm-fan: got pwm for fan
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.482838] pwm_fan_driver pwm-fan: fan tach request irq success
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.491246] pwm_fan_driver pwm-fan: tach period: 1000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.498691] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.510730] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.522932] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.535217] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.547498] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.559777] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.572058] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.584334] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.596635] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.609265] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.623159] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.636992] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.650780] device-mapper: uevent: version 1.0.3
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.658477] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.674551] sdhci: Secure Digital Host Controller Interface driver
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.683497] sdhci: Copyright(c) Pierre Ossman
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.690541] sdhci-pltfm: SDHCI platform and OF driver helper
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.699615] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.702223] tegra-se 70012000.se: tegra_se_probe: complete
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.702832] hidraw: raw HID events driver (C) Jiri Kosina
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.705643] usbcore: registered new interface driver usbhid
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.705646] usbhid: USB HID core driver
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.739729] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.752045] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.768489] tegra-i2c 7000c400.i2c: no acknowledge from address 0x42
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.777416] ina3221x 1-0042: ina3221 reset failure status: 0xffffff87
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.786634] ina3221x: probe of 1-0042 failed with error -121
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.795517] tegra-i2c 7000c400.i2c: no acknowledge from address 0x43
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.798948] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.799297] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.799318] sdhci-tegra sdhci-tegra.1: Client registration for eMC Successful
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.837096] ina3221x 1-0043: ina3221 reset failure status: 0xffffff87
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.838956] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA 64-bit with 64 bit addr
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.839821] sdhci-tegra sdhci-tegra.0: Got CD GPIO
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.839896] sdhci-tegra sdhci-tegra.0: Got WP GPIO
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.839984] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.840049] sdhci-tegra sdhci-tegra.0: wakeup init done, cd_irq: 262
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.840082] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.842263] en-vdd-sd: supplied by vdd-3v3
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.861436] mmc0: MAN_BKOPS_EN bit is not set
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.868362] mmc0: Skipping tuning since strobe enabled
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.873703] mmc0: new HS400 MMC card at address 0001
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.873959] mmcblk mmc0:0001: Card claimed for testing.
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.878612] mmcblk0: mmc0:0001 016G32 14.7 GiB
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.883122] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.883140] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.885349] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.928892] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.982981] ina3221x: probe of 1-0043 failed with error -121
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.991449] parse_throttle_dt_data: Num cap clks = 6
Apr 12 03:05:42 tegra-ubuntu kernel: [ 3.998437] parse_throttle_dt_data: clk=cclk_g type=2
Apr 12 03:05:42 tegra-ubuntu kernel: [ 4.005420] parse_throttle_dt_data: clk=gpu type=4
Apr 12 03:05:42 tegra-ubuntu kernel: [ 4.012154] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 4.020135] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
Apr 12 03:05:42 tegra-ubuntu kernel: [ 4.028031] parse_throttle_dt_data: clk=cap.throttle.sclk
hello sensor_test,
please check tc358840 kernel drivers for CAM2_RST example,
sources/kernel/kernel-4.4/drivers/media/i2c/tc358840.c
