the software of synaptic install failed
hello,
sudo apt-get update
Hit:1 Index of /ubuntu-ports xenial InRelease
Hit:2 Index of /ubuntu-ports xenial-updates InRelease
Hit:3 Index of /ubuntu-ports xenial-security InRelease
Reading package lists… Done
sudo apt-get install synaptic
Building dependency tree
Reading state information… Done
Package synaptic is not aailable, but is refered to by another package.
This may mean that the package is missing,has been obsoketed,or is only available from another source
E: Package ‘synaptic’ has no installation candidate
How to install synaptic?
Thank you very much.
This installs for me on R28.2 (I have all repositories enabled…perhaps the dependency is for a package in a repository you don’t have enabled).
A reverse dependency check:
# apt-cache rdepends --installed synaptic
synaptic
Reverse Depends:
  update-notifier
 |apt
  update-notifier
  update-manager
 |apt
  update-notifier
 |apt
  update-manager
What do you get if you run:
sudo apt-get install update-notifier update-manager
If you see packages installed but no longer required, perhaps one is in the way…run:
sudo apt autoremove
…then try install again.
