In my understanding, the SBT offset
parameter in optixTrace
represents the index of the hitgroup SBT for the current trace call, and missSBTIndex
represents the index of the missgroup SBT for the current trace call. So does the SBT stride
actually have any functional effect, or does it only serve as a symbolic and informative role? For example, would the two pieces of code below essentially have the same effect, with SBT stride
not playing a functional role?
optixTrace(
handle,
ray_origin, ray_dir,
0.0f, 1e16f,
0.0f, // rayTime
OptixVisibilityMask(1),
OPTIX_RAY_FLAG_NONE,
0, // SBT offset
2, // SBT stride
0 // missSBTIndex
optixTrace(
handle,
0.0f, 1e16f,
0.0f, // rayTime
0, // SBT offset
3, // SBT stride
0 // missSBTIndex
Hello. The common use of SBT stride and offset is to implement multiple ray types. For instance, having separate shadow rays and radiance rays is common when path tracing. These two logical types of rays would need to invoke different hit-programs (and possibly miss programs) since they perform different operations when shading.
To implement such a system, you would generate an SBT with two hit groups per material, rather than one. One hit program group would perform lighting calculations for the radiance rays and the other might check opacity for shadow rays. When calling optixTrace
you would need to inform optix which hit-programs this particular ray would use. The stride tells optix how many ray types exist (in this case 2) and the offset would tell optix which ray type this particular ray belongs to (might be zero for radiance rays and one for shadow rays, but this depends on what order you used in your SBT). Functionally, the stride allows optix to correctly index into the SBT array since you have multiple hit groups per material.
Note that the SDK uses only a single ray-type for its samples so SBT offset is always 0 and SBT stride is 1. However we do still often use named variables to indicate the semantics of these parameters:
optixTrace(
handle,
ray_origin,
ray_direction,
0.0f, // tmin
1e16f, // tmax
ray_time,
OptixVisibilityMask( 1 ),
RAY_TYPE_RADIANCE, // SBT offset
RAY_TYPE_COUNT, // SBT stride
RAY_TYPE_RADIANCE, // missSBTIndex
r, g, b );
Also, if you want to see the somewhat technical details of how SBT Index and Stride are applied, please take a look at chapter 7 of the OptiX Programming Guide. Section 7.3 gives the following formula for how the SBT index is computed by optix after intersection:
sbt-index =
sbt-instance-offset
+ (sbt-geometry-acceleration-structure-index * sbt-stride-from-trace-call)
+ sbt-offset-from-trace-call
If you only call optixAccelBuild
once in a case like this, it basically means there’s just one geometry acceleration structure, so the sbt-geometry-acceleration-structure-index
defaults to 0. In this situation, no matter what value you set for sbt-stride
, it gets multiplied by 0, so it doesn’t really affect the result. Does that mean only sbt-offset
actually matters?
Yes, in this case you only have a single GAS, so the sbt-geometry-acceleration-structure-index will always be zero. But you want your shaders to be decoupled from the input geometry hierarchy. If you decided to add a second GAS, then your shader would give incorrect results unless the stride is correct.
