The square wave generated by PWM1 on the Jetson AGX Orin shows phase shifts
The square wave generated by PWM1 on the Jetson AGX Orin shows phase shifts, as seen in the diagram below. The time interval between two rising edges occasionally falls far below the expected period, which is 100ms. In one case, it was only 50ms. How can this issue be analyzed and resolved? Thank you.
3e2b3ddb-95b6-4b3c-b87c-2b934bd2e0d6
Sorry for the late response.
Hi, what is the test equipment? Could you use oscilloscope to capture the shifts? And what is your software setting to generate this pwm signal?
