I am connecting an SSD to the DriveAGX via PCIe, but it is not recognized.
I tried all four ports and entered the fdisk -l command in the terminal, and rebooted with the SSD connected but it was not recognized.
Some people were having the same problem, but they weren’t getting answers.
(URL : PCIe ports)
I’d like to know what the solution is.
To use PCIe device on SATA connector require not only a simple cable but a bridge-cable.
To connect your SSD to the eSATA connector on the DRIVE AGX you’d need a SATA cable.
please close the topic if this answer you need.
thanks
