The stored images do not correspond to the frame_meta.batch_id
• Hardware Platform (Jetson / GPU) - Jetson Nano
• DeepStream Version - 6.0.1
• JetPack Version (valid for Jetson only) - 4.6.2
• TensorRT Version - 8.2
• NVIDIA GPU Driver Version (valid for GPU only) - 10.2
I made modifications to the code by removing the ‘pgie’ element and adding a ‘capsfilter’ to facilitate image storage. However, upon inspecting the stored images, I observed a discrepancy between the batch ID and the corresponding images. For reference, I have attached an image to illustrate this issue.
The image labeled as “0_227.jpg” appears to be incorrect; it seems to correspond to batch_id = 1 instead
pipeline: nvurisrcbin->nvstreammux->nvvideoconvert->capsfilter->tiler->nv3dsink
can you please check and resolve this issue?
Could you attach the modifications and config files?
deepstream_test_3.txt (11.9 KB)
Could you add some log in your code and attach the log?
+   count = 0
     while l_frame is not None:
         try:
             # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
             # The casting is done by pyds.NvDsFrameMeta.cast()
             # The casting also keeps ownership of the underlying memory
             # in the C code, so the Python garbage collector will leave
             # it alone.
         except StopIteration:
             break
         frame_number=frame_meta.frame_num
         l_obj=frame_meta.obj_meta_list
         num_rects = frame_meta.num_obj_meta
+      print("########### count %d batch_id %d frame_num %d###########"%(count,
 frame_meta.batch_id, frame_meta.frame_num))
         #n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
         #cv2.imwrite(f'{frame_meta.batch_id}_{frame_number}.jpg', n_frame)
+      print("########### count %d###########"%(count))
+      count++
log.txt (189.8 KB)
You can see from your log. The batch_id and the frame number are matched.
############# count 0 batch_id 0 frame_num 0#############
############# count 0#############
############# count 1 batch_id 1 frame_num 0#############
############# count 1#############
############# count 0 batch_id 0 frame_num 1#############
############# count 1 batch_id 1 frame_num 1#############
############# count 0 batch_id 0 frame_num 2#############
############# count 1 batch_id 1 frame_num 2#############
############# count 0 batch_id 0 frame_num 3#############
############# count 1 batch_id 1 frame_num 3#############
############# count 0 batch_id 0 frame_num 4#############
############# count 1 batch_id 1 frame_num 4#############
but the images are not matched, can you check.
Could you attach the video souce and describe in detail what a mismatch specifically refers to?
I have two RTSP streams and have stored images with filenames in the format ‘batch_id_frame_number.jpg’.
I can successfully retrieve images up to ‘0_226.jpg.’ However, after that point, the images are mismatched, with the second stream’s image appearing in place of the first stream’s image.
The batch id is not strictly coresspinding to the source id. If you want to save that by source id, please use the source_id parameter from the FrameMeta.
log.txt (106.1 KB)
source_id parameter also do the same thing.
check log.txt.
My goal is to send frames to a separate thread while maintaining the association with their respective camera IDs and applying motion detection. However, if I receive different images for the same camera ID, I’m unsure how to handle this situation. Can you please provide guidance on this?
In theory, the source ID can distinguish the corresponding source. Could you do the following test?
  1. change the source to uridecoderbin
  2. add the probe function to the src of streammux
    We have a corresponding demo for your requirements, but it is based on C/C++,and currently there is no Python version available. deepstream_parallel_inference_app
