The system fails to boot at the UEFI stage,after Update the db/dbx Keys with a Capsule Update
hi nv team:
jp version:jp6.2.1
Core Board:orin devkit && orin nano 8g.
We attempted to perform a secure boot of UEFI, but encountered an issue while verifying the key update of DBX.
My burning command is as follows.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh  --uefi-keys uefi_keys/uefi_keys.conf jetson-agx-orin-devkit internal
Then use the following method to create firmware.
sudo ADDITIONAL_DTB_OVERLAY="UefiUpdateSecurityKeys.dtbo" ./l4t_generate_soc_bup.sh  -e t23x_agx_bl_spec t23x
./generate_capsule/l4t_generate_soc_capsule.sh -i bootloader/payloads_t23x/bl_only_payload -o ./TEGRA_AGX.Cap t234
I have identified an issue.The first boot after updating the firmware was successful.
Then reboot, it will definitely not get up.The relevant errors are shown below.
The following are the commands for operation
fwupdmgr get-devices
NVIDIA Jetson AGX Orin Developer Kit
â
ââG1M15M:
â     Device ID:          a3ef198bd9356a5c55e7784412afec09581bce68
â     Current version:    0x3846515430304857
â     Vendor:             Micron (EMMC:0x000013)
â     GUIDs:              4069750d-b244-5498-b4f1-47b182d59c6b
â                         61de7eba-6573-5196-aef5-467ecab3b9fb
â                         d21b74dc-09a8-56b6-9395-f3d5779e3b4f
â     Device Flags:       â Internal device
â                         â Updatable
â
ââSystem Firmware:
      Device ID:          a45df35ac0e948ee180fe216a5f703f32dda163f
      Summary:            UEFI ESRT device
      Current version:    2360324
      Minimum Version:    2360324
      Vendor:             NVIDIA (DMI:EDK II)
      Update State:       Success
      GUIDs:              bf0d4599-20d4-414e-b2c5-3595b1cda402
                          230c8b18-8d9b-53ec-838b-6cfc0383493a
                          â Updatable
                          â System requires external power source
                          â Needs a reboot after installation
                          â Cryptographic hash verification is available
                          â Device is usable for the duration of the update
nvidia@tegra-ubuntu:~$ cd /sys/firmware/efi/efivars/
nvidia@tegra-ubuntu:/sys/firmware/efi/efivars$ printf "\x07\x00\x00\x00\x04\x00\x00\x00\x00\x00\x00\x00" > /tmp/var_tmp.bin
nvidia@tegra-ubuntu:/sys/firmware/efi/efivars$ sudo dd if=/tmp/var_tmp.bin of=OsIndications-8be4df61-93ca-11d2-aa0d-00e098032b8c bs=12;sync
[sudo] password for nvidia:
1+0 records in
1+0 records out
12 bytes copied, 0.00234067 s, 5.1 kB/s
nvidia@tegra-ubuntu:/sys/firmware/efi/efivars$ sudo fwupdtool install-blob /home/nvidia/TEGRA_AGX.Cap  a45df35ac0e948ee180fe216a5f703f32dda163f
Loadingâ                 [-                                      ]Loadingâ                 [***************************************]
Restarting deviceâ       [ -                                     ]Restarting deviceâ       [ -                                     ]Writingâ                 [ -                                     ]Schedulingâ              [ -                                     ]Decompressingâ           [ -                                     ]Restarting deviceâ       [  -                                    ]Restarting deviceâ       [  -                                    ]Restarting deviceâ       [***************************************]
Waitingâ                 [***************************************]
An update requires a reboot to complete. Restart now? [y|N]: y
[  523.529464] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[  523.529476] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[  523.529481] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[  523.529486] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[  523.643160] arm-smmu 12000000.iommu: disabling translation
[  523.643337] arm-smmu 10000000.iommu: disabling translation
[  523.643398] arm-smmu 8000000.iommu: disabling translation
[  523.643680] reboot: Restarting system
3hJetson System firmware version 36.4.4-gcid-41062509 date 2025-06-16T15:25:51+00:
00
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
Update Progress -   5% **++++++++++++++++++++++++++++++++++++++++++++++++Update Progress -   6% ***+++++++++++++++++++++++++++++++++++++++++++++++Update Progress -   7% ***+++++++++++++++++++++++++++++++++++++++++++++++Update Progress -   8% ****++++++++++++++++++++++++++++++++++++++++++++++Update Progress -   9% ****++++++++++++++++++++++++++++++++++++++++++++++Update Progress -  10% *****+++++++++++++++++++++++++++++++++++++++++++++Update Progress -  11% *****+++++++++++++++++++++++++++++++++++++++++++++Update Progress -  12% ******++++++++++++++++++++++++++++++++++++++++++++Update Progress -  13% ******++++++++++++++++++++++++++++++++++++++++++++Update Progress -  14% *******+++++++++++++++++++++++++++++++++++++++++++Update Progress -  15% *******+++++++++++++++++++++++++++++++++++++++++++Update Progress -  16% ********++++++++++++++++++++++++++++++++++++++++++Update Progress -  17% ********++++++++++++++++++++++++++++++++++++++++++Update Progress -  18% *********+++++++++++++++++++++++++++++++++++++++++Update Progress -  19% *********+++++++++++++++++++++++++++++++++++++++++Update Progress -  20% **********++++++++++++++++++++++++++++++++++++++++Update Progress -  65% ********************************++++++++++++++++++Update Progress -  66% *********************************+++++++++++++++++Update Progress -  67% *********************************+++++++++++++++++Update Progress -  68% **********************************++++++++++++++++Update Progress -  69% **********************************++++++++++++++++Update Progress -  70% ***********************************+++++++++++++++Update Progress -  71% ***********************************+++++++++++++++Update Progress -  72% ************************************++++++++++++++Update Progress -  95% ***********************************************+++Update Progress - 100% **************************************************3hJetson System firmware version 36.4.4-gcid-41062509 date 2025-06-16T15:25:51+00:
00
ESC   to enter Setup.
......L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: UEFI Secure Boot is enabled.
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.148-tegra (buildbrain@mobile-u64-6262-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon Jun 16 08:24:48 PDT 2025 ()
[    0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x827f8f198 TPMFinalLog=0x818b50000 SMBIOS=0xffff0000 SMBIOS 3.0=0x827980000 MEMATTR=0x8219b3018 ESRT=0x821926498 TPMEventLog=0x818b65018 RNG=0x815120018 MEMRESERVE=0x818b6ac18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot enabled
[    0.000000] esrt: Reserving ESRT space from 0x0000000821926498 to 0x00000008219264d0.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000804000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000833ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x828c76800-0x828c78fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000833ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x0000000818a11fff]
[    0.000000]   node   0: [mem 0x0000000818a12000-0x0000000818b5ffff]
[    0.000000]   node   0: [mem 0x0000000818b60000-0x0000000818b6afff]
[    0.000000]   node   0: [mem 0x0000000818b6b000-0x0000000818b6bfff]
[    0.000000]   node   0: [mem 0x0000000818b6c000-0x000000082604ffff]
[    0.000000]   node   0: [mem 0x0000000826050000-0x0000000827f8ffff]
[    0.000000]   node   0: [mem 0x0000000827f90000-0x000000082c5fffff]
[    0.000000]   node   0: [mem 0x000000082c600000-0x000000082c7fffff]
[    0.000000]   node   0: [mem 0x000000082c800000-0x000000082cd6ffff]
[    0.000000]   node   0: [mem 0x000000082d700000-0x000000082d7fffff]
[    0.000000]   node   0: [mem 0x0000000832000000-0x0000000833ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000833ffffff]
[    0.000000] On node 0, zone Normal: 2448 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 18432 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 7930224
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=PARTUUID=b2b21542-857c-4685-8da7-00fcd560c4ae rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x82C610000 bl_prof_ro_ptr=65536@0x82C600000
[    0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x82C610000 bl_prof_ro_ptr=65536@0x82C600000", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 31148496K/32225728K available (20160K kernel code, 4064K rwdata, 10056K rodata, 7680K init, 529K bss, 815088K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000576] Console: colour dummy device 80x25
[    0.000597] printk: console [tty0] enabled
[    0.000737] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000754] pid_max: default: 32768 minimum: 301
[    0.000816] LSM: Security Framework initializing
[    0.000868] Yama: becoming mindful.
[    0.000906] SELinux:  Initializing.
[    0.001195] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.001346] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.004654] rcu: Hierarchical SRCU implementation.
[    0.008780] Tegra Revision: A01 SKU: 208 CPU Process: 0 SoC Process: 0
[    0.009174] Remapping and enabling EFI services.
[    0.010488] smp: Bringing up secondary CPUs ...
[    0.011396] Detected PIPT I-cache on CPU1
[    0.011505] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.011594] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.012381] Detected PIPT I-cache on CPU2
[    0.012399] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.012426] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.013082] Detected PIPT I-cache on CPU3
[    0.013092] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.013111] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.015842] Detected PIPT I-cache on CPU4
[    0.015866] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.015900] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.016605] Detected PIPT I-cache on CPU5
[    0.016618] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.016640] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.017323] Detected PIPT I-cache on CPU6
[    0.017337] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.017356] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.018025] Detected PIPT I-cache on CPU7
[    0.018041] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.018063] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.020779] Detected PIPT I-cache on CPU8
[    0.020808] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[    0.020838] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[    0.021553] Detected PIPT I-cache on CPU9
[    0.021569] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[    0.021587] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[    0.022282] Detected PIPT I-cache on CPU10
[    0.022296] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[    0.022317] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[    0.023021] Detected PIPT I-cache on CPU11
[    0.023034] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[    0.023054] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[    0.023129] smp: Brought up 1 node, 12 CPUs
[    0.023138] SMP: Total of 12 processors activated.
[    0.023144] CPU features: detected: 32-bit EL0 Support
[    0.023146] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.023151] CPU features: detected: Common not Private translations
[    0.023155] CPU features: detected: CRC32 instructions
[    0.023157] CPU features: detected: Data cache clean to Point of Persistence
[    0.023161] CPU features: detected: Generic authentication (architected algorithm)
[    0.023163] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.023164] CPU features: detected: LSE atomic instructions
[    0.023166] CPU features: detected: Privileged Access Never
[    0.023168] CPU features: detected: RAS Extension Support
[    0.023174] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.117144] CPU: All CPU(s) started at EL2
[    0.124815] devtmpfs: initialized
[    0.191323] KASLR enabled
[    0.191726] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.191777] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.198780] pinctrl core: initialized pinctrl subsystem
[    0.200995] SMBIOS 3.6.0 present.
[    0.201035] DMI: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.4.4-gcid-41062509 06/16/2025
[    0.202224] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.208434] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.209304] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.210090] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.210216] audit: initializing netlink subsys (disabled)
[    0.210552] audit: type=2000 audit(0.208:1): state=initialized audit_enabled=0 res=1
[    0.215639] thermal_sys: Registered thermal governor 'step_wise'
[    0.215651] thermal_sys: Registered thermal governor 'user_space'
[    0.215655] thermal_sys: Registered thermal governor 'power_allocator'
[    0.225272] cpuidle: using governor menu
[    0.225921] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.226472] ASID allocator initialised with 32768 entries
[    0.232984] Serial: AMBA PL011 UART driver
[    0.289189] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 118, base_baud = 0) is a SBSA
[    0.289288] printk: console [ttyAMA0] enabled
[    0.308326] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.317389] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.317399] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.317401] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.317402] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.318527] cryptd: max_cpu_qlen set to 1000
[    0.320648] ACPI: Interpreter disabled.
[    0.322680] iommu: Default domain type: Translated
[    0.322686] iommu: DMA domain TLB invalidation policy: strict mode
[    0.323063] SCSI subsystem initialized
[    0.323260] vgaarb: loaded
[    0.323444] usbcore: registered new interface driver usbfs
[    0.323467] usbcore: registered new interface driver hub
[    0.323489] usbcore: registered new device driver usb
[    0.323879] pps_core: LinuxPPS API ver. 1 registered
[    0.323884] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.323895] PTP clock support registered
[    0.323962] EDAC MC: Ver: 3.0.0
[    0.325288] Registered efivars operations
[    0.325902] FPGA manager framework
[    0.325978] Advanced Linux Sound Architecture Driver Initialized.
[    0.326529] Bluetooth: Core ver 2.22
[    0.326562] NET: Registered PF_BLUETOOTH protocol family
[    0.326566] Bluetooth: HCI device and connection manager initialized
[    0.326575] Bluetooth: HCI socket layer initialized
[    0.326580] Bluetooth: L2CAP socket layer initialized
[    0.326596] Bluetooth: SCO socket layer initialized
[    0.327018] clocksource: Switched to clocksource arch_sys_counter
[    0.364312] VFS: Disk quotas dquot_6.6.0
[    0.364463] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.364877] pnp: PnP ACPI: disabled
[    0.375895] NET: Registered PF_INET protocol family
[    0.376814] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.391492] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.392254] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.392297] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.393718] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.395530] TCP: Hash tables configured (established 262144 bind 65536)
[    0.395884] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.396250] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.396953] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.397924] RPC: Registered named UNIX socket transport module.
[    0.397934] RPC: Registered udp transport module.
[    0.397938] RPC: Registered tcp transport module.
[    0.397941] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.397967] PCI: CLS 0 bytes, default 64
[    0.398564] Unpacking initramfs...
[    0.409364] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.409948] kvm [1]: IPA Size Limit: 48 bits
[    0.410012] kvm [1]: GICv3: no GICV resource entry
[    0.410023] kvm [1]: disabling GICv2 emulation
[    0.410072] kvm [1]: GIC system register CPU interface enabled
[    0.410600] kvm [1]: vgic interrupt IRQ9
[    0.411281] kvm [1]: VHE mode initialized successfully
[    0.418723] Initialise system trusted keyrings
[    0.418789] Key type blacklist registered
[    0.419081] workingset: timestamp_bits=42 max_order=23 bucket_order=0
[    0.430426] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.431655] NFS: Registering the id_resolver key type
[    0.431721] Key type id_resolver registered
[    0.431725] Key type id_legacy registered
[    0.431866] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.431894] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.431941] ntfs: driver 2.1.32 [Flags: R/O].
[    0.432539] 9p: Installing v9fs 9p2000 file system support
[    0.433744] integrity: Platform Keyring initialized
[    0.516453] Key type asymmetric registered
[    0.516465] Asymmetric key parser 'x509' registered
[    0.516616] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.516631] io scheduler mq-deadline registered
[    0.516644] io scheduler kyber registered
[    0.558653] EINJ: ACPI disabled.
[    0.607421] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.609183] SuperH (H)SCI(F) driver initialized
[    0.609489] msm_serial: driver initialized
[    0.610183] printk: console [ttyTCU0] enabled
[    0.611068] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.611074] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.611080] arm-smmu 8000000.iommu: 	stage 1 translation
[    0.611082] arm-smmu 8000000.iommu: 	stage 2 translation
[    0.611084] arm-smmu 8000000.iommu: 	nested translation
[    0.611090] arm-smmu 8000000.iommu: 	stream matching with 128 register groups
[    0.611093] arm-smmu 8000000.iommu: 	128 context banks (0 stage-2 only)
[    0.611117] arm-smmu 8000000.iommu: 	Supported page sizes: 0x61311000
[    0.611120] arm-smmu 8000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.611124] arm-smmu 8000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.612098] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.612100] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.612102] arm-smmu 10000000.iommu: 	stage 1 translation
[    0.612102] arm-smmu 10000000.iommu: 	stage 2 translation
[    0.612103] arm-smmu 10000000.iommu: 	nested translation
[    0.612106] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    0.612108] arm-smmu 10000000.iommu: 	128 context banks (0 stage-2 only)
[    0.612122] arm-smmu 10000000.iommu: 	Supported page sizes: 0x61311000
[    0.612123] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.612124] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.612463] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.612466] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.612469] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.612470] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.612472] arm-smmu 12000000.iommu: 	nested translation
[    0.612475] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    0.612477] arm-smmu 12000000.iommu: 	128 context banks (0 stage-2 only)
[    0.612480] arm-smmu 12000000.iommu: 	Supported page sizes: 0x61311000
[    0.612483] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.612484] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.623259] loop: module loaded
[    0.624205] megasas: 07.717.02.00-rc1
[    0.628184] tun: Universal TUN/TAP device driver, 1.6
[    0.628747] thunder_xcv, ver 1.0
[    0.628773] thunder_bgx, ver 1.0
[    0.628800] nicpf, ver 1.0
[    0.629652] hclge is initializing
[    0.629682] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.629688] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.629732] e1000: Intel(R) PRO/1000 Network Driver
[    0.629738] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.629771] e1000e: Intel(R) PRO/1000 Network Driver
[    0.629775] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.629800] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.629805] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.629821] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.629827] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.630055] sky2: driver version 1.30
[    0.630704] VFIO - User Level meta-driver version: 0.3
[    0.632171] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.632181] ehci-pci: EHCI PCI platform driver
[    0.632208] ehci-platform: EHCI generic platform driver
[    0.632285] ehci-orion: EHCI orion driver
[    0.632360] ehci-exynos: EHCI Exynos driver
[    0.632428] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.632452] ohci-pci: OHCI PCI platform driver
[    0.632475] ohci-platform: OHCI generic platform driver
[    0.632545] ohci-exynos: OHCI Exynos driver
[    0.632963] usbcore: registered new interface driver usb-storage
[    0.634783] i2c_dev: i2c /dev entries driver
[    0.636095] pps pps0: new PPS source ktimer
[    0.636104] pps pps0: ktimer PPS source registered
[    0.636112] pps_ldisc: PPS line discipline registered
[    0.638167] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.640311] sdhci: Secure Digital Host Controller Interface driver
[    0.640316] sdhci: Copyright(c) Pierre Ossman
[    0.640755] Synopsys Designware Multimedia Card Interface Driver
[    0.641357] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.642480] ledtrig-cpu: registered to indicate activity on CPUs
[    0.643476] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.644003] tegra-bpmp bpmp: Adding to iommu group 0
[    0.645469] tegra-bpmp bpmp: firmware: 39f77b2baaf3f0522607-da583751bbf
[    1.196187] Freeing initrd memory: 15484K
[    5.558853] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    5.558887] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    5.558900] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    5.559444] hid: raw HID events driver (C) Jiri Kosina
[    5.560271] usbcore: registered new interface driver usbhid
[    5.560283] usbhid: USB HID core driver
[    5.573362] optee: probing for conduit method.
[    5.573406] optee: revision 4.2
[    5.633592] optee: dynamic shared memory is enabled
[    5.633878] optee: initialized driver
[    5.637912] usbcore: registered new interface driver snd-usb-audio
[    5.640698] NET: Registered PF_PACKET protocol family
[    5.642248] Bluetooth: RFCOMM TTY layer initialized
[    5.642304] Bluetooth: RFCOMM socket layer initialized
[    5.642361] Bluetooth: RFCOMM ver 1.11
[    5.642920] 9pnet: Installing 9P2000 support
[    5.643170] Key type dns_resolver registered
[    5.645694] printk: console [tty0]: printing thread started
[    5.646968] printk: console [ttyTCU0]: printing thread started
[    5.647894] printk: console [ttyAMA0]: printing thread started
[    5.648135] Loading compiled-in X.509 certificates
[    5.659809] Loaded X.509 cert 'Build time autogenerated kernel key: 7f1e7893f24e1cf3b68affc169b61dbde0fdceaa'
[    5.723292] integrity: Loading X.509 certificate: UEFI:db
[    5.727500] integrity: Loaded X.509 cert 'my Signature Database key: bc7be0d686b93fc232a66940cd790c1dfc88fcab'
[    5.727517] integrity: Loading X.509 certificate: UEFI:db
[    5.728731] integrity: Loaded X.509 cert 'my another Signature Database key: 0775d826b347deaa0e03241b49200d5e92ee139f'
[    5.728739] integrity: Loading X.509 certificate: UEFI:db
[    5.729915] integrity: Loaded X.509 cert 'update DB 1: c0dcc2d993ac771e31c80d0b5dd15e1c1f207d31'
[    5.729921] integrity: Loading X.509 certificate: UEFI:db
[    5.731089] integrity: Loaded X.509 cert 'Update DB 0: 68f3456f5bec540a51ecabae0ec02251a82d399e'
[    5.732624] integrity: Revoking X.509 certificate: UEFI:dbx
[    5.798887] gpio-394 (camera-control-output-low): hogged as output/low
[    5.798950] gpio-397 (camera-control-output-low): hogged as output/low
[    5.799028] gpio-487 (camera-control-output-low): hogged as output/low
[    5.799072] gpio-486 (camera-control-output-low): hogged as output/low
[    5.808515] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    5.813996] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    5.818675] serial-tegra 3100000.serial: RX in PIO mode
[    5.818696] serial-tegra 3100000.serial: TX in PIO mode
[    5.818912] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    5.822081] serial-tegra 3110000.serial: RX in PIO mode
[    5.822099] serial-tegra 3110000.serial: TX in PIO mode
[    5.822297] 3110000.serial: ttyTHS2 at MMIO 0x3110000 (irq = 206, base_baud = 0) is a TEGRA_UART
[    5.830127] tegra_rtc c2a0000.rtc: registered as rtc1
[    5.830154] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    5.831508] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    5.845176] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    5.854085] tegra-i2c 3190000.i2c: Adding to iommu group 1
[    5.860919] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    5.865570] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[    5.868841] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[    5.874232] tegra-i2c c240000.i2c: Adding to iommu group 1
[    5.879928] tegra-i2c c250000.i2c: Adding to iommu group 1
[    5.910796] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[    5.913921] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[    5.916611] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[    5.917574] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[    5.919296] irq: IRQ233: trimming hierarchy from :bus@0:pmc@c360000
[    5.919358] irq: IRQ234: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    5.919400] irq: IRQ235: trimming hierarchy from :bus@0:pmc@c360000
[    5.919456] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    6.357054] ALSA device list:
[    6.357059]   No soundcards found.
[    6.359820] mmc0: CQHCI version 5.10
[    6.360217] sdhci-tegra 3400000.mmc: Got CD GPIO
[    6.396383] mmc0: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[    6.407378] irq: IRQ236: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    6.408010] mmc1: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[    6.409141] Freeing unused kernel memory: 7680K
[    6.409258] Run /init as init process
[    6.425522] Checking overlayfs setting...
[    6.435962] Overlayfs is disabled...
[    6.442342] Root device found: PARTUUID=b2b21542-857c-4685-8da7-00fcd560c4ae
[    6.501407] mmc0: Command Queue Engine enabled
[    6.501417] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    6.501666] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[    6.504796]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    6.505232] mmcblk0boot0: mmc0:0001 G1M15M 31.5 MiB
[    6.505648] mmcblk0boot1: mmc0:0001 G1M15M 31.5 MiB
[    6.506018] mmcblk0rpmb: mmc0:0001 G1M15M 4.00 MiB, chardev (511:0)
[    9.602250] tegra194-pcie 14100000.pcie: Adding to iommu group 4
[    9.606141] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    9.606166] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    9.606172] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    9.606175] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    9.606648] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    9.606654] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    9.677714] irq: IRQ237: trimming hierarchy from :bus@0:pmc@c360000
[    9.711194] tegra194-pcie 14100000.pcie: Link up
[    9.712818] tegra194-pcie 14100000.pcie: Link up
[    9.712895] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    9.712900] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    9.712904] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    9.712906] pci_bus 0001:00: root bus resource [bus 00-ff]
[    9.712907] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    9.712953] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    9.713102] pci 0001:00:00.0: PME# supported from D0 D3hot
[    9.716749] pci 0001:01:00.0: [17cb:1103] type 00 class 0x028000
[    9.716928] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
[    9.717960] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[    9.730070] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a81fffff]
[    9.730078] pci 0001:01:00.0: BAR 0: assigned [mem 0x20a8000000-0x20a81fffff 64bit]
[    9.730162] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    9.730167] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a81fffff]
[    9.730289] pcieport 0001:00:00.0: Adding to iommu group 4
[    9.730389] pcieport 0001:00:00.0: PME: Signaling with IRQ 200
[    9.730509] pcieport 0001:00:00.0: AER: enabled with IRQ 200
[    9.731305] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[    9.732686] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    9.732698] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    9.732704] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    9.732706] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    9.733008] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    9.733010] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[   10.263462] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[   10.269955] Rootfs mounted over PARTUUID=b2b21542-857c-4685-8da7-00fcd560c4ae
[   10.282238] Switching from initrd to actual rootfs
[   10.384055] systemd[1]: System time before build time, advancing clock.
[   10.416107] NET: Registered PF_INET6 protocol family
[   10.417098] Segment Routing with IPv6
[   10.417105] In-situ OAM (IOAM) with IPv6
[   10.443058] systemd[1]: systemd 249.11-0ubuntu3.15 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[   10.443435] systemd[1]: Detected architecture arm64.
[   10.446341] systemd[1]: Hostname set to <tegra-ubuntu>.
[   10.493351] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog
[   10.493368] systemd[1]: Set hardware watchdog to 2min.
[   10.706515] systemd[1]: /lib/systemd/system/snapd.service:23: Unknown key name 'RestartMode' in section 'Service', ignoring.
[   10.717644] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   10.725097] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   10.786874] systemd[1]: Queued start job for default target Graphical Interface.
[   10.788531] systemd[1]: Created slice Slice /system/modprobe.
[   10.802251] systemd[1]: Created slice Slice /system/serial-getty.
[   10.802680] systemd[1]: Created slice Slice /system/systemd-fsck.
[   10.803014] systemd[1]: Created slice User and Session Slice.
[   10.822977] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.831659] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.831826] systemd[1]: Reached target Slice Units.
[   10.831879] systemd[1]: Reached target Mounting snaps.
[   10.831925] systemd[1]: Reached target Mounted snaps.
[   10.831974] systemd[1]: Reached target Swaps.
[   10.832027] systemd[1]: Reached target Local Verity Protected Volumes.
[   10.832174] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   10.832384] systemd[1]: Listening on LVM2 poll daemon socket.
[   10.838209] systemd[1]: Listening on RPCbind Server Activation Socket.
[   10.839019] tegra194-pcie 14160000.pcie: Phy link never came up
[   10.889222] systemd[1]: Listening on Syslog Socket.
[   10.907204] systemd[1]: Listening on fsck to fsckd communication Socket.
[   10.907355] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   10.907680] systemd[1]: Listening on Journal Audit Socket.
[   10.907844] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.908044] systemd[1]: Listening on Journal Socket.
[   10.908811] systemd[1]: Listening on udev Control Socket.
[   10.908960] systemd[1]: Listening on udev Kernel Socket.
[   10.909957] systemd[1]: Mounting Huge Pages File System...
[   10.911021] systemd[1]: Mounting POSIX Message Queue File System...
[   10.962737] systemd[1]: Mounting Kernel Debug File System...
[   10.975614] systemd[1]: Mounting Kernel Trace File System...
[   10.979230] systemd[1]: Starting Journal Service...
[   10.990166] systemd[1]: Finished Availability of block devices.
[   10.993466] systemd[1]: Starting Set the console keyboard layout...
[   11.004827] systemd[1]: Starting Create List of Static Device Nodes...
[   11.006009] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   11.007278] systemd[1]: Starting Load Kernel Module configfs...
[   11.032673] systemd[1]: Starting Load Kernel Module drm...
[   11.033945] systemd[1]: Starting Load Kernel Module efi_pstore...
[   11.035088] systemd[1]: Starting Load Kernel Module fuse...
[   11.048344] fuse: init (API version 7.34)
[   11.058436] systemd[1]: Starting NVIDIA specific first-boot udev script...
[   11.059788] systemd[1]: Started Nameserver information manager.
[   11.072460] systemd[1]: Reached target Preparation for Network.
[   11.072662] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   11.074599] systemd[1]: Starting Load Kernel Modules...
[   11.076176] systemd[1]: Starting Remount Root and Kernel File Systems...
[   11.082773] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null). Quota mode: none.
[   11.083089] nvsciipc: loading out-of-tree module taints kernel.
[   11.090995] nvsciipc: loaded module
[   11.104410] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   11.104944] nvmap_co_device_init: vpr :dma coherent mem declare 0x0000000849800000,914358272
[   11.104950] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[   11.104961] nvmap_page_pool_init: Total RAM pages: 7858451
[   11.104962] nvmap_page_pool_init: nvmap page pool size: 982306 pages (3837 MB)
[   11.105014] nvmap_background_zero_thread: PP zeroing thread starting.
[   11.105030] nvmap_heap_create: created heap vpr base 0x0000000849800000 size (892928KiB)
[   11.105061] nvmap_heap_create: fsi :dma coherent mem declare 0x000000082f000000,16777216
[   11.105062] nvmap_heap_create: created heap fsi base 0x000000082f000000 size (16384KiB)
[   11.117408] tegra-host1x 13e00000.host1x: Adding to iommu group 6
[   11.117692] systemd[1]: Starting Coldplug All udev Devices...
[   11.118578] host1x-context host1x-ctx.0: Adding to iommu group 7
[   11.118713] host1x-context host1x-ctx.1: Adding to iommu group 8
[   11.118829] host1x-context host1x-ctx.2: Adding to iommu group 9
[   11.118940] host1x-context host1x-ctx.3: Adding to iommu group 10
[   11.119081] host1x-context host1x-ctx.4: Adding to iommu group 11
[   11.119206] host1x-context host1x-ctx.5: Adding to iommu group 12
[   11.119348] host1x-context host1x-ctx.6: Adding to iommu group 13
[   11.119494] host1x-context host1x-ctx.7: Adding to iommu group 14
[   11.119642] host1x-context host1x-ctx.8: Adding to iommu group 15
[   11.119781] host1x-context host1x-ctx.9: Adding to iommu group 16
[   11.119906] host1x-context host1x-ctx.10: Adding to iommu group 17
[   11.120042] host1x-context host1x-ctx.11: Adding to iommu group 18
[   11.120171] host1x-context host1x-ctx.12: Adding to iommu group 19
[   11.120313] host1x-context host1x-ctx.13: Adding to iommu group 20
[   11.120452] host1x-context host1x-ctx.14: Adding to iommu group 21
[   11.120590] host1x-context host1x-ctx.15: Adding to iommu group 22
[   11.183673] systemd[1]: Started Journal Service.
[   11.198058] nvgpu: 17000000.gpu          nvgpu_nvhost_syncpt_init:122  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   11.198058]
[   11.342337] systemd-journald[306]: Received client request to flush runtime journal.
[   11.843089] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[   11.843093] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[   11.843094] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[   11.843096] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[   11.843095] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   11.843098] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[   11.843100] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[   11.843100] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   11.843104] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   11.843110] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   11.843116] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   11.843118] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   11.843120] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   11.843122] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   11.843124] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   11.843141] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   11.843143] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   11.882475] thermal cooling_device12: hot-surface-alert cooling state: 0 -> 1
[   11.918169] (NULL device *): fops function table already registered
[   12.265008] thermal cooling_device4: cpu-throttle-alert cooling state: 0 -> 1
[   12.271823] thermal cooling_device4: cpu-throttle-alert cooling state: 1 -> 0
[   14.954855] using random self ethernet address
[   14.954862] using random host ethernet address
[   15.276750] using random self ethernet address
[   15.276757] using random host ethernet address
Ubuntu 22.04.5 LTS tegra-ubuntu ttyAMA0
tegra-ubuntu login: nvidia
Password:
Welcome to Ubuntu 22.04.5 LTS (GNU/Linux 5.15.148-tegra aarch64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/pro
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
Expanded Security Maintenance for Applications is not enabled.
3 updates can be applied immediately.
To see these additional updates run: apt list --upgradable
Enable ESM Apps to receive additional future security updates.
See https://ubuntu.com/esm or run: sudo pro status
The list of available updates is more than a week old.
To check for new updates run: sudo apt update
Last login: Thu Sep 10 07:38:31 UTC 2026 from 192.168.55.100 on pts/0
nvidia@tegra-ubuntu:~$ mokutil --dbx
[key 1]
SHA1 Fingerprint: d9:81:a8:ff:3f:92:35:f2:b7:9a:11:6b:bf:b9:a7:09:57:6d:85:ff
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            63:df:9a:77:46:ab:43:d9:ee:27:3e:81:b2:3c:07:ca:31:75:a8:cf
        Signature Algorithm: sha256WithRSAEncryption
        Issuer: CN=my another Signature Database key
        Validity
            Not Before: Aug 21 07:46:52 2026 GMT
            Not After : Aug 18 07:46:52 2036 GMT
        Subject: CN=my another Signature Database key
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                Public-Key: (2048 bit)
                Modulus:
                    00:cf:42:7f:3c:24:d3:c5:f6:3a:bd:aa:c0:6e:35:
                    d1:e5:94:56:ec:78:29:92:5b:5f:a0:43:41:b1:fb:
                    66:91:1f:a7:34:77:43:d8:e3:f7:a1:92:0f:ea:f1:
                    37:01:6e:7b:fb:06:dd:4a:c9:b8:40:57:e7:a5:a8:
                    83:be:bd:3f:a7:42:0e:78:ff:76:90:34:3a:fc:b7:
                    28:f6:b0:b3:dd:6f:eb:be:89:f5:46:29:45:6f:c7:
                    c5:46:86:52:a1:a5:1e:36:52:55:f1:a1:13:85:1e:
                    8e:58:99:35:eb:61:de:af:1f:15:d5:56:48:87:96:
                    30:29:a0:22:bb:49:a3:cf:79:bf:d9:3f:79:b0:d9:
                    68:97:fb:01:25:ab:89:50:92:f8:9d:4b:2c:f5:3f:
                    ed:6d:35:38:48:53:f7:4a:40:ac:67:51:96:c0:23:
                    a8:5a:86:7c:cb:4c:12:32:1b:71:1f:57:7e:4b:87:
                    48:c6:42:4a:15:19:32:2c:68:35:21:2f:5f:a5:79:
                    13:f4:ef:7b:46:00:62:a6:53:1a:fa:61:b2:63:ab:
                    a2:d4:f8:0e:51:89:d1:7c:7f:86:83:04:33:9b:89:
                    e0:fa:2d:08:d3:25:d4:53:93:e4:a2:ad:be:3d:bb:
                    85:32:b6:78:a4:56:c2:25:8d:f6:89:6f:fa:ac:27:
                    04:f5
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            X509v3 Subject Key Identifier:
                07:75:D8:26:B3:47:DE:AA:0E:03:24:1B:49:20:0D:5E:92:EE:13:9F
            X509v3 Authority Key Identifier:
            X509v3 Basic Constraints: critical
                CA:TRUE
    Signature Value:
        00:10:53:a5:1d:0a:c1:10:48:dc:e5:63:bf:26:66:6b:ad:73:
        77:f0:db:1b:f5:e1:3e:be:3f:f6:6f:45:38:61:8d:10:4f:45:
        e5:74:bd:fa:e2:91:f8:c5:78:c4:14:67:8b:d2:8a:12:89:22:
        bd:b3:a6:f3:31:23:c0:a7:b1:3b:f4:04:69:6a:9a:e4:df:14:
        48:b2:99:22:4c:9a:20:b9:36:23:02:8f:e7:ee:f6:05:2f:fb:
        bd:57:58:cb:82:af:fd:eb:28:f6:b9:b0:a5:41:b7:e3:4c:5e:
        84:63:35:57:03:64:6e:a6:16:84:58:e2:bb:ae:02:2c:72:b8:
        41:97:f4:42:83:10:8e:f7:3d:00:af:00:50:c8:20:ba:c2:43:
        7b:8b:fa:f0:fc:31:39:8f:bf:5f:9f:d1:94:7c:19:31:1e:07:
        a5:e0:a1:49:ac:39:60:bd:a7:b7:f0:32:5c:22:11:38:b9:0a:
        40:c5:1b:da:bd:b3:b5:8e:98:5a:ac:0f:26:2c:30:2a:74:b6:
        7b:31:4e:a7:60:c3:a0:9f:af:a9:d8:e1:1a:44:f9:f3:51:8f:
        71:a8:a7:2c:76:30:84:4e:05:77:90:0a:24:06:2a:d5:f2:f9:
        58:d6:6f:d9:c3:f5:3a:d4:3a:2d:eb:b6:2e:e8:53:e2:12:23:
        30:74:f6:2e
nvidia@tegra-ubuntu:~$ sud o reboot
[  193.647517] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[  193.647526] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[  193.647529] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[  193.647533] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[  193.761253] arm-smmu 12000000.iommu: disabling translation
[  193.761441] arm-smmu 10000000.iommu: disabling translation
[  193.761500] arm-smmu 8000000.iommu: disabling translation
[  193.761753] reboot: Restarting system
The following is the error message after rebooting again.
ÿâ
[0000.061] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.067] I> t234-A01-0-Silicon (0x12347) Prod
[0000.071] I> Boot-mode : Coldboot
[0000.074] I> Entry timestamp: 0x00000000
[0000.078] I> last_boot_error: 0x0
[0000.081] I> BR-BCT: preprod_dev_sign: 0
[0000.085] I> rst_source: 0x0, rst_level: 0x0
[0000.089] I> Task: SE error check
[0000.092] I> Task: Bootchain select WAR set
[0000.096] I> Task: Enable SLCG
[0000.099] I> Task: CRC check
[0000.102] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0000.109] I> Task: Initialize MB2 params
[0000.113] I> MB2-params @ 0x40060000
[0000.117] I> Task: Crypto init
[0000.120] I> Task: Perform MB1 KAT tests
[0000.124] I> Task: NVRNG health check
[0000.127] I> NVRNG: Health check success
[0000.131] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.137] I> Task: Enabling and initialization of Bandwidth limiter
[0000.143] I> No request to configure MBWT settings for any PC!
[0000.149] I> Task: Secure debug controls
[0000.152] I> Task: strap war set
[0000.156] I> Task: Initialize SOC Therm
[0000.159] I> Task: Program NV master stream id
[0000.164] I> Task: Verify boot mode
[0000.169] I> Task: Alias fuses
[0000.173] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.180] I> Task: Print SKU type
[0000.183] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.188] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.193] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.197] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.201] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.205] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.210] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.214] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.219] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.223] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.227] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.231] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.235] I> FUSE_SKU_INFO_0 = 0xd0
[0000.239] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.243] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.246] I> SKU: Prod
[0000.248] I> Task: Boost clocks
[0000.251] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.257] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.262] I> BPMP NAFLL lock success.
[0000.266] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.270] I> Initializing PLLC2 for AXI_CBB.
[0000.274] I> AXI_CBB : src = 35, divisor = 0
[0000.278] I> Task: Voltage monitor
[0000.282] I> VMON: Vmon re-calibration and fine tuning done
[0000.287] I> Task: UPHY init
[0000.292] I> HSIO UPHY init done
[0000.295] W> Skipping GBE UPHY config
[0000.298] I> Task: Boot device init
[0000.302] I> Boot_device: QSPI_FLASH instance: 0
[0000.306] I> Qspi clock source : pllc_out0
[0000.311] I> QSPI Flash: Macronix 64MB
[0000.314] I> QSPI-0l initialized successfully
[0000.318] I> Task: TSC init
[0000.321] I> Task: Load membct
[0000.324] I> RAM_CODE 0x4000401
[0000.327] I> Loading MEMBCT
[0000.330] I> Slot: 1
[0000.332] I> Binary[0] block-66816 (partition size: 0x40000)
[0000.337] I> Binary name: MEM-BCT-0
[0000.341] I> Size of crypto header is 8192
[0000.345] I> Size of crypto header is 8192
[0000.349] I> strt_pg_num(66816) num_of_pgs(16) read_buf(0x40050000)
[0000.355] I> BCH of MEM-BCT-0 read from storage
[0000.359] I> BCH address is : 0x40050000
[0000.363] I> MEM-BCT-0 header integrity check is success
[0000.368] I> Binary magic in BCH component 0 is MEM0
[0000.373] I> component binary type is 0
[0000.377] I> strt_pg_num(66832) num_of_pgs(115) read_buf(0x40040000)
[0000.384] I> MEM-BCT-0 binary is read from storage
[0000.389] I> MEM-BCT-0 binary integrity check is success
[0000.394] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.400] I> RAM_CODE 0x4000401
[0000.406] I> RAM_CODE 0x4000401
[0000.410] I> Task: Load Page retirement list
[0000.414] I> Task: SDRAM params override
[0000.417] I> Task: Save mem-bct info
[0000.421] I> Task: Carveout allocate
[0000.424] I> RCM blob carveout will not be allocated
[0000.429] I> Update CCPLEX IST carveout from MB1-BCT
[0000.434] I> ECC region[0]: Start:0x0, End:0x0
[0000.438] I> ECC region[1]: Start:0x0, End:0x0
[0000.443] I> ECC region[2]: Start:0x0, End:0x0
[0000.447] I> ECC region[3]: Start:0x0, End:0x0
[0000.451] I> ECC region[4]: Start:0x0, End:0x0
[0000.455] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0000.461] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.466] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.471] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.475] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.486] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0000.493] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0000.500] I> allocated(CO:43) base:0x83c000000 size:0x4000000 align: 0x200000
[0000.507] I> allocated(CO:39) base:0x839e00000 size:0x2200000 align: 0x10000
[0000.514] I> allocated(CO:20) base:0x836000000 size:0x2000000 align: 0x2000000
[0000.521] I> allocated(CO:24) base:0x834000000 size:0x2000000 align: 0x2000000
[0000.528] I> allocated(CO:28) base:0x832000000 size:0x2000000 align: 0x2000000
[0000.536] I> allocated(CO:29) base:0x830000000 size:0x2000000 align: 0x2000000
[0000.543] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0000.550] I> allocated(CO:35) base:0x838e00000 size:0x1000000 align: 0x100000
[0000.557] I> allocated(CO:41) base:0x82f000000 size:0x1000000 align: 0x100000
[0000.564] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0000.571] I> allocated(CO:03) base:0x838000000 size:0x800000 align: 0x800000
[0000.578] I> allocated(CO:06) base:0x82e800000 size:0x800000 align: 0x800000
[0000.585] I> allocated(CO:56) base:0x82e000000 size:0x800000 align: 0x200000
[0000.592] I> allocated(CO:07) base:0x838800000 size:0x400000 align: 0x400000
[0000.599] I> allocated(CO:33) base:0x82dc00000 size:0x400000 align: 0x200000
[0000.606] I> allocated(CO:19) base:0x82d980000 size:0x280000 align: 0x10000
[0000.612] I> allocated(CO:23) base:0x838c00000 size:0x200000 align: 0x200000
[0000.619] I> allocated(CO:01) base:0x82d800000 size:0x100000 align: 0x100000
[0000.626] I> allocated(CO:05) base:0x82d700000 size:0x100000 align: 0x100000
[0000.633] I> allocated(CO:08) base:0x82d600000 size:0x100000 align: 0x100000
[0000.640] I> allocated(CO:09) base:0x82d500000 size:0x100000 align: 0x100000
[0000.647] I> allocated(CO:12) base:0x82d400000 size:0x100000 align: 0x100000
[0000.654] I> allocated(CO:15) base:0x82d300000 size:0x100000 align: 0x100000
[0000.661] I> allocated(CO:17) base:0x82d200000 size:0x100000 align: 0x100000
[0000.668] I> allocated(CO:27) base:0x82d100000 size:0x100000 align: 0x100000
[0000.675] I> allocated(CO:42) base:0x82d000000 size:0x100000 align: 0x100000
[0000.682] I> allocated(CO:54) base:0x82d900000 size:0x80000 align: 0x80000
[0000.689] I> allocated(CO:34) base:0x82cff0000 size:0x10000 align: 0x10000
[0000.695] I> allocated(CO:72) base:0x82cdf0000 size:0x200000 align: 0x10000
[0000.702] I> allocated(CO:47) base:0x82c800000 size:0x400000 align: 0x200000
[0000.709] I> allocated(CO:50) base:0x82c600000 size:0x200000 align: 0x100000
[0000.716] I> allocated(CO:52) base:0x82cdc0000 size:0x30000 align: 0x10000
[0000.723] I> allocated(CO:48) base:0x82cda0000 size:0x20000 align: 0x10000
[0000.730] I> allocated(CO:69) base:0x82cd80000 size:0x20000 align: 0x10000
[0000.736] I> allocated(CO:49) base:0x82cd70000 size:0x10000 align: 0x10000
[0000.743] I> NSDRAM base: 0x80000000, end: 0x82cdf0000, size: 0x7acdf0000
[0000.750] I> Task: Thermal check
[0000.753] I> Using min_chip_limit as min_tmon_limit
[0000.758] I> Using max_chip_limit as max_tmon_limit
[0000.762] I> BCT max_tmon_limit = 105
[0000.766] I> BCT min_tmon_limit = -28
[0000.769] I> BCT max_tmon_limit = 105
[0000.773] I> BCT min_tmon_limit = -28
[0000.776] I> SKU specific max_chip_limit = 105
[0000.781] I> SKU specific min_chip_limit = -28
[0000.785] I> BCT max_chip_limit = 105
[0000.788] I> BCT min_chip_limit = -28
[0000.792] I> enable_soctherm_polling = 0
[0000.796] I> max temp read = 46
[0000.799] I> min temp read = 43
[0000.802] I> Enabling thermtrip
[0000.805] I> Task: Update FSI SCR with thermal fuse data
[0000.810] I> Task: Enable WDT 5th expiry
[0000.814] I> Task: I2C register
[0000.817] I> Task: Set I2C bus freq
[0000.820] I> Task: Reset FSI
[0000.823] I> Task: Pinmux init
[0000.826] I> Task: Prod config init
[0000.829] I> Task: Pad voltage init
[0000.833] I> Task: Prod init
[0000.835] I> Task: Program rst req config reg
[0000.840] I> Task: Common rail init
[0000.844] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.854] I> DONE: Thermal config
[0000.859] I> DONE: SOC rail config
[0000.863] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.869] I> DONE: MEMIO rail config
[0000.873] I> DONE: GPU rail info
[0000.877] I> DONE: CV rail info
[0000.880] I> Task: Mem clock src
[0000.883] I> Task: Misc. board config
[0000.887] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.893] I> Task: SDRAM init
[0000.896] I> MemoryType: 4 MemBctRevision: 10
[0000.903] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 10
[0000.910] I> MSS CAR: Init PLLM
[0000.913] I> MSS CAR: Init PLLHUB
[0000.918] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0000.930] I> SDRAM initialized!
[0000.933] I> SDRAM Size in Total 0x800000000
[0000.937] I> Task: Dram Ecc scrub
[0000.940] I> Task: DRAM alias check
[0000.956] I> Task: Program NSDRAM carveout
[0000.960] I> NSDRAM carveout encryption is enabled
[0000.965] I> Program NSDRAM carveout
[0000.969] I> Task: Register checker
[0000.972] I> Task: Enable clock-mon
[0000.986] I> FMON: Fmon re-programming done
[0000.990] I> Task: Mapper init
[0000.993] I> Task: SC7 Context Init
[0000.997] I> Task: CCPLEX IST init
[0001.000] I> Task: CPU WP0
[0001.004] I> Loading MCE
[0001.006] I> Slot: 1
[0001.008] I> Binary[8] block-85760 (partition size: 0x80000)
[0001.014] I> Binary name: MCE
[0001.017] I> Size of crypto header is 8192
[0001.021] I> Size of crypto header is 8192
[0001.024] I> strt_pg_num(85760) num_of_pgs(16) read_buf(0x4003e000)
[0001.031] I> BCH of MCE read from storage
[0001.035] I> BCH address is : 0x4003e000
[0001.039] I> MCE header integrity check is success
[0001.043] I> Binary magic in BCH component 0 is MTSM
[0001.048] I> component binary type is 8
[0001.052] I> Size of crypto header is 8192
[0001.056] I> strt_pg_num(85776) num_of_pgs(350) read_buf(0x40000000)
[0001.064] I> MCE binary is read from storage
[0001.068] I> MCE binary integrity check is success
[0001.073] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.079] I> Size of crypto header is 8192
[0001.090] I> Size of crypto header is 8192
[0001.094] I> Sending WP0 mailbox command to PSC
[0001.103] I> Task: XUSB Powergate
[0001.106] I> Skipping powergate XUSB.
[0001.110] I> Task: MB1 fixed firewalls
[0001.116] W> Firewall readback mismatch
[0001.121] I> Task: Load bpmp-fw
[0001.124] I> Slot: 1
[0001.126] I> Binary[15] block-72960 (partition size: 0x180000)
[0001.132] I> Binary name: BPMP_FW
[0001.135] I> Size of crypto header is 8192
[0001.139] I> Size of crypto header is 8192
[0001.143] I> strt_pg_num(72960) num_of_pgs(16) read_buf(0x807fe000)
[0001.149] I> BCH of BPMP_FW read from storage
[0001.153] I> BCH address is : 0x807fe000
[0001.157] I> BPMP_FW header integrity check is success
[0001.162] I> Binary magic in BCH component 0 is BPMF
[0001.167] I> component binary type is 15
[0001.171] I> Size of crypto header is 8192
[0001.175] I> strt_pg_num(72976) num_of_pgs(1990) read_buf(0x80000000)
[0001.192] I> BPMP_FW binary is read from storage
[0001.199] I> BPMP_FW binary integrity check is success
[0001.204] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.210] I> Slot: 1
[0001.212] I> Binary[16] block-76032 (partition size: 0x400000)
[0001.218] I> Binary name: BPMP_FW_DTB
[0001.221] I> Size of crypto header is 8192
[0001.225] I> Size of crypto header is 8192
[0001.229] I> strt_pg_num(76032) num_of_pgs(16) read_buf(0x807fc000)
[0001.235] I> BCH of BPMP_FW_DTB read from storage
[0001.240] I> BCH address is : 0x807fc000
[0001.244] I> BPMP_FW_DTB header integrity check is success
[0001.249] I> Binary magic in BCH component 0 is BPMD
[0001.254] I> component binary type is 16
[0001.258] I> Size of crypto header is 8192
[0001.262] I> strt_pg_num(76048) num_of_pgs(736) read_buf(0x8079fff0)
[0001.272] I> BPMP_FW_DTB binary is read from storage
[0001.278] I> BPMP_FW_DTB binary integrity check is success
[0001.283] I> Binary BPMP_FW_DTB loaded successfully at 0x8079fff0 (0x5bf40)
[0001.290] I> Task: BPMP fw ast config
[0001.293] I> Task: Load psc-fw
[0001.296] I> Slot: 1
[0001.298] I> Binary[17] block-84224 (partition size: 0xc0000)
[0001.304] I> Binary name: PSC_FW
[0001.307] I> Size of crypto header is 8192
[0001.311] I> Size of crypto header is 8192
[0001.315] I> strt_pg_num(84224) num_of_pgs(16) read_buf(0x80ffe000)
[0001.321] I> BCH of PSC_FW read from storage
[0001.325] I> BCH address is : 0x80ffe000
[0001.329] I> PSC_FW header integrity check is success
[0001.334] I> Binary magic in BCH component 0 is PFWP
[0001.339] I> component binary type is 17
[0001.342] I> Size of crypto header is 8192
[0001.346] I> strt_pg_num(84240) num_of_pgs(591) read_buf(0x80fb4200)
[0001.356] I> PSC_FW binary is read from storage
[0001.361] I> PSC_FW binary integrity check is success
[0001.366] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.372] I> Task: Load nvdec-fw
[0001.375] I> Slot: 1
[0001.377] I> Binary[7] block-69376 (partition size: 0x100000)
[0001.383] I> Binary name: NVDEC
[0001.386] I> Size of crypto header is 8192
[0001.390] I> Size of crypto header is 8192
[0001.394] I> strt_pg_num(69376) num_of_pgs(16) read_buf(0x800fe000)
[0001.400] I> BCH of NVDEC read from storage
[0001.404] I> BCH address is : 0x800fe000
[0001.408] I> NVDEC header integrity check is success
[0001.413] I> Binary magic in BCH component 0 is NDEC
[0001.417] I> component binary type is 7
[0001.421] I> Size of crypto header is 8192
[0001.425] I> strt_pg_num(69392) num_of_pgs(560) read_buf(0x80000000)
[0001.434] I> NVDEC binary is read from storage
[0001.439] I> NVDEC binary integrity check is success
[0001.444] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.450] I> Size of crypto header is 8192
[0001.462] I> Task: Load tsec-fw
[0001.465] I> TSEC-FW load support not enabled
[0001.469] I> Task: GPIO interrupt map
[0001.473] I> Task: SC7 context save
[0001.476] I> Slot: 1
[0001.478] I> Binary[27] block-0 (partition size: 0x100000)
[0001.483] I> Binary name: BR_BCT
[0001.486] I> Size of crypto header is 8192
[0001.490] I> Size of crypto header is 8192
[0001.494] I> Size of crypto header is 8192
[0001.498] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.504] I> BR_BCT binary is read from storage
[0001.509] I> BR_BCT binary integrity check is success
[0001.513] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.520] I> Slot: 1
[0001.522] I> Binary[13] block-86784 (partition size: 0x30000)
[0001.527] I> Binary name: SC7-FW
[0001.530] I> Size of crypto header is 8192
[0001.534] I> Size of crypto header is 8192
[0001.538] I> Size of crypto header is 8192
[0001.542] I> Size of crypto header is 8192
[0001.546] I> strt_pg_num(86784) num_of_pgs(16) read_buf(0xa0002000)
[0001.552] I> BCH of SC7-FW read from storage
[0001.556] I> BCH address is : 0xa0002000
[0001.560] I> SC7-FW header integrity check is success
[0001.565] I> Binary magic in BCH component 0 is WB0B
[0001.570] I> component binary type is 13
[0001.574] I> Size of crypto header is 8192
[0001.578] I> strt_pg_num(86800) num_of_pgs(349) read_buf(0xa0004000)
[0001.586] I> SC7-FW binary is read from storage
[0001.591] I> SC7-FW binary integrity check is success
[0001.596] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[0001.602] I> Slot: 1
[0001.604] I> Binary[22] block-87168 (partition size: 0x30000)
[0001.610] I> Binary name: PSC_RF
[0001.613] I> Size of crypto header is 8192
[0001.617] I> Size of crypto header is 8192
[0001.620] I> Size of crypto header is 8192
[0001.624] I> Size of crypto header is 8192
[0001.628] I> strt_pg_num(87168) num_of_pgs(16) read_buf(0xa002fa00)
[0001.635] I> BCH of PSC_RF read from storage
[0001.639] I> BCH address is : 0xa002fa00
[0001.643] I> PSC_RF header integrity check is success
[0001.647] I> Binary magic in BCH component 0 is PSCR
[0001.652] I> component binary type is 22
[0001.656] I> Size of crypto header is 8192
[0001.660] I> strt_pg_num(87184) num_of_pgs(224) read_buf(0xa0031a00)
[0001.667] I> PSC_RF binary is read from storage
[0001.672] I> PSC_RF binary integrity check is success
[0001.677] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x1be60)
[0001.686] I> Task: Save WP0 payload to SC7 ctx
[0001.691] I> Task: Load MB2rf binary to SC7 ctx
[0001.695] I> Slot: 1
[0001.697] I> Binary[14] block-87552 (partition size: 0x20000)
[0001.703] I> Binary name: MB2_RF
[0001.706] I> Size of crypto header is 8192
[0001.710] I> Size of crypto header is 8192
[0001.714] I> Size of crypto header is 8192
[0001.717] I> Size of crypto header is 8192
[0001.721] I> strt_pg_num(87552) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.728] I> BCH of MB2_RF read from storage
[0001.732] I> BCH address is : 0xa00d5d10
[0001.736] I> MB2_RF header integrity check is success
[0001.741] I> Binary magic in BCH component 0 is MB2R
[0001.745] I> component binary type is 14
[0001.749] I> Size of crypto header is 8192
[0001.753] I> strt_pg_num(87568) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.761] I> MB2_RF binary is read from storage
[0001.765] I> MB2_RF binary integrity check is success
[0001.770] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf60)
[0001.776] I> Task: Save fuse alias data to SC7 ctx
[0001.781] I> Task: Save PMIC data to SC7 ctx
[0001.785] I> Task: Save Pinmux data to SC7 ctx
[0001.790] I> Task: Save Pad Voltage data to SC7 ctx
[0001.794] I> Task: Save controller prod data to SC7 ctx
[0001.799] I> Task: Save prod cfg data to SC7 ctx
[0001.804] I> Task: Save I2C bus freq data to SC7 ctx
[0001.809] I> Task: Save SOCTherm data to SC7 ctx
[0001.813] I> Task: Save FMON data to SC7 ctx
[0001.817] I> Task: Save VMON data to SC7 ctx
[0001.821] I> Task: Save TZDRAM data to SC7 ctx
[0001.825] I> Task: Save GPIO int data to SC7 ctx
[0001.830] I> Task: Save clock data to SC7 ctx
[0001.834] I> Task: Save debug data to SC7 ctx
[0001.838] I> Task: Save MBWT data to SC7 ctx
[0001.846] I> SC7 context save done
[0001.850] I> Task: Load MB2/Applet/FSKP
[0001.853] I> Loading MB2
[0001.856] I> Slot: 1
[0001.858] I> Binary[6] block-71424 (partition size: 0x80000)
[0001.863] I> Binary name: MB2
[0001.866] I> Size of crypto header is 8192
[0001.870] I> Size of crypto header is 8192
[0001.874] I> strt_pg_num(71424) num_of_pgs(16) read_buf(0x8007e000)
[0001.880] I> BCH of MB2 read from storage
[0001.884] I> BCH address is : 0x8007e000
[0001.888] I> MB2 header integrity check is success
[0001.893] I> Binary magic in BCH component 0 is MB2B
[0001.897] I> component binary type is 6
[0001.901] I> Size of crypto header is 8192
[0001.905] I> strt_pg_num(71440) num_of_pgs(846) read_buf(0x80000000)
[0001.916] I> MB2 binary is read from storage
[0001.921] I> MB2 binary integrity check is success
[0001.926] I> Binary MB2 loaded successfully at 0x80000000 (0x69a70)
[0001.932] I> Task: Map CCPLEX SHARED carveout
[0001.936] I> Task: Prepare MB2 params
[0001.940] I> Task: Dram ecc test
[0001.943] I> Task: Misc NV security settings
[0001.947] I> NVDEC sticky bits programming done
[0001.951] I> Successfully powergated NVDEC
[0001.955] I> Task: Disable/Reload WDT
[0001.959] I> Task: Program misc carveouts
[0001.963] I> Program IPC carveouts
[0001.966] I> Task: Disable SCPM/POD reset
[0001.970] I> SLCG Global override status := 0x0
[0001.974] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-0fbce5b9)
I> Emulation:
I> Entry timestamp: 0x001e8e2a
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x82e000000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: TZDRAM heap init
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Secondary storage device: QSPI_FLASH instance: 0
I> Secondary storage device: SDMMC_USER instance: 3
I> sdmmc HS400 mode enabled
I> Task: Partition Manager Init
I> strt_pg_num(130592) num_of_pgs(1) read_buf(0x82e001000)
I> strt_pg_num(130560) num_of_pgs(32) read_buf(0x82e001200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
W> PARTITION_MANAGER: Failed to publish partition.
I> Found 15 partitions in SDMMC_USER (instance 3)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: B_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-118016 (partition size: 0x90000), name: B_spe-fw
I> strt_pg_num(118016) num_of_pgs(16) read_buf(0x40067ab0)
I> strt_pg_num(118032) num_of_pgs(512) read_buf(0x82d600000)
I> Partition name: B_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-119168 (partition size: 0x100000), name: B_rce-fw
I> strt_pg_num(119168) num_of_pgs(16) read_buf(0x40067ab0)
I> strt_pg_num(119184) num_of_pgs(880) read_buf(0x82d200000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x82d600000
I> Partition name: B_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-107776 (partition size: 0x500000), name: B_dce-fw
I> strt_pg_num(107776) num_of_pgs(16) read_buf(0x40067ab0)
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x82d200000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(107792) num_of_pgs(1) read_buf(0x82e1403d8)
I> strt_pg_num(107792) num_of_pgs(8) read_buf(0x82e1403d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(107800) num_of_pgs(512) read_buf(0x82e0003c0)
I> strt_pg_num(108312) num_of_pgs(512) read_buf(0x82e0403c0)
I> dce : will be decompressed at 0x836000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(108824) num_of_pgs(512) read_buf(0x82e0803c0)
I> dce : decompressed to 12067600 bytes
I> dce: plain binary integrity check is success
I> Partition name: B_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-121216 (partition size: 0x200000), name: B_adsp-fw
I> strt_pg_num(121216) num_of_pgs(16) read_buf(0x40067ab0)
I> strt_pg_num(121232) num_of_pgs(800) read_buf(0x838800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x836000000
I> Partition name: B_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-72448 (partition size: 0x40000), name: B_xusb-fw
I> strt_pg_num(72448) num_of_pgs(16) read_buf(0x40067ab0)
I> strt_pg_num(72464) num_of_pgs(312) read_buf(0x82d700000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x838800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: B_pva-fw
I> Binary@ device:3/0 block-125312 (partition size: 0x40000), name: B_pva-fw
I> strt_pg_num(125312) num_of_pgs(16) read_buf(0x40067ab0)
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x82d700000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(125328) num_of_pgs(1) read_buf(0x82e1403d8)
I> strt_pg_num(125328) num_of_pgs(8) read_buf(0x82e1403d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(125336) num_of_pgs(512) read_buf(0x82e0003c0)
I> pva-fw : will be decompressed at 0x82d980000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x82d980000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Enable FSI-SE clock...
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x832000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
I> Task: Revoke PKC fuse
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE..
I> Enabling combined UART
ÿýÿàspe: early_init
ÿžÿàvic initialized
ÿžÿàtsc initialized
ÿžÿàaon lic initialized
ÿžÿàspe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
ÿžÿàspe: SafeRTOS v8.4
ÿžÿàspe: init
ÿžÿàscheduler initialized
ÿžÿàaon hsp initialized
ÿžÿàtag initialized
ÿžÿàtcu initialized
ÿžÿàbpmp ipc initialized
ÿžÿàspe: late init
ÿžÿàcpu_nic clock initialized
ÿžÿàapb clock initialized
ÿžÿàpm initialized
ÿžÿàbpmp hsp initialized
ÿžÿàtop1 hsp initialized
ÿžÿàccplex ipc initialized
ÿžÿàspe: start scheduler
ÿžÿá
I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Start secure NOR provision
I> Skip Secure NOR provisioning
I> Task: Trigger load FSI keyblob
I> Skipping FSI key blob copy
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d to pÿâ
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is da583751bbfe2b7f6e204562d97ff39e
bpmp: combined binary md5 is 39f77b2baaf3f0522607569dd3ae9a48
bpmp: firmware tag is 39f77b2baaf3f0522607-da583751bbf
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
ÿásc
I> Task: Unhalt FSI
I> FSI unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load HV/CPUBL
I> Task: Load TOS
I> Task: Trigger loadÿâinitialized avfs_clk_platform
initialized powergate
ÿå[     2.598218] Camera-FW on t234-rce-safe started
TCU early console enabled.
ÿá TSÿâinitialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
ÿáEC leyblob
I> Sending opcode 0x53535452 to psc
ÿè
ÿáI> Sent opcode to psc
I> Partition name: B_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-87808 (partition size: 0x380000), name: B_cpu-bootloader
ÿèDCE Started
ÿáI> strt_pg_num(87808) num_of_pgs(16) read_buf(0x40067ab0)
I> cpubl : oem authentication of header done
I> strt_pg_num(87824) num_of_pgs(1) read_buf(0x82e143f98)
I> strt_pg_num(87824) num_of_pgs(8) read_buf(0x82e143f98)
ÿèDCE_R5_Init
ÿáI> cpubl : meta-blob integrity check is success.
I> strÿâinitialized emc
initialized emc_mrq
ÿát_pg_num(87832) num_of_pgs(512) read_buf(0x82ÿâinitialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
ÿáe003f8ÿâinitialized uphy
ÿá0)
ÿèMPU enabled
DCE_SWÿâinitialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
ÿáI> strt_pg_num(88344) num_of_pgs(512) read_buf(0x82e043f80)
ÿè_Inÿâinitialized clk_cal_late
initialized noc_late
initialized cvc
ÿáI> cpubl : will be decompressed at 0ÿâinitialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable sdmmc4_axicif
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactÿå[     2.796285] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.422 ms, total boot 211.561 ms)
ÿâmon
initialized extras_post
bpmp: init complete
ÿáx82c800000
ÿèit
ÿáI> strt_pg_num(88856) num_of_pgs(512) read_buf(0x82e083f80)
I> strt_pg_num(89368) num_of_pgs(512) read_buf(0x82e0c3f80)
I> strt_pg_num(89880) num_of_pgs(512) read_buf(0x82e103f80)
I> strt_pg_num(90392) num_of_pgs(512) read_buf(0x82e003f80)
I> strt_pg_num(90904) num_of_pgs(512) read_buf(0x82e043f80)
I> strt_pg_num(91416) num_of_pgs(512) read_buf(0x82e083f80)
I> strt_pg_num(91928) num_of_pgs(512) read_buf(0x82e0c3f80)
I> strt_pg_num(92440) num_of_pgs(512) read_buf(0x82e103f80)
I> strt_pg_num(92952) num_of_pgs(512) read_buf(0x82e003f80)
ÿèAdmin Task Init
Admin Task Init complete
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
SHA Task Started
DCE: FW BÿáI> strt_pg_num(93464) num_of_pgs(512) read_buf(0x82e043f80)
ÿèoot Complete
Admin Task Running
SHA Task Running
ÿáI> strt_pg_num(93976) num_of_pgs(512) read_buf(0x82e083f80)
I> cpubl : decompressed to 3670144 bytes
I> cpubl: plain binary integrity check is success
I> Partition name: B_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-94976 (partition size: 0x400000), name: B_secure-os
I> strt_pg_num(94976) num_of_pgs(16) read_buf(0x40067ab0)
I> strt_pg_num(94992) num_of_pgs(3696) read_buf(0x83fd32000)
I> NSDRAM carveout base: 0x80000000, size: 0x7acdf0000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x82c800000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x83fd32000
I> Relocating OP-TEE dtb from: 0x83feff180 to 0x83c040020, size: 0x2754
I> [0] START: 0x80000000, SIZE: 0x7acdf0000
I> [1] START: 0x832000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: B_eks
I> Binary@ device:3/0 block-107264 (partition size: 0x40000), name: B_eks
I> strt_pg_num(107264) num_of_pgs(16) read_buf(0x40067ab0)
I> strt_pg_num(107280) num_of_pgs(8) read_buf(0x83c020000)
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x83c020000
I> EKB detected (length: 0x410) @ VA:0x83c020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x83c040020
I> OEM sc7 context saved
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
I> Task: Storage device deinit
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Bootchain failure check
I> Current Boot-Chain Slot: 1
I> BR-BCT Boot-Chain is 1, and status is 1. Set UPDATE_BRBCT bit to 0
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
ÿäNOTICE:  BL31: v2.8(release):
NOTICE:  BL31: Built : 11:33:59, Sep 10 2026
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Thu Sep 10 03:22:21 UTC 2026 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: fTPM ID is not enabled.
I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is not supported.
I/TC: Primary CPU switching to normal world boot
ÿá
Jetson UEFI firmware (version 36.4.4-gcid-41062509 built on 2025-06-16T15:25:51+00:00)
ÿäI/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
I/TC: WARNING: Test UEFI variable auth key is being used !
I/TC: WARNING: UEFI variable protection is not fully enabled !
ASSERT [FvbNorFlashStandaloneMm] /home/zpx/work/uefi/nvidia-uefi_36.4.4/edk2-nvidia/Silicon/NVIDIA/Drivers/FvbNorFlashDxe/FvbNorFlashStandaloneMm.c(937): ((BOOLEAN)(0==1))
I noticed a similar issue on the forum.
Then I recompiled the firmware related to UEFI and OPTEE.
My method is as follows.
./edk2-nvidia/Platform/NVIDIA/StandaloneMmOptee/build.sh
cp images/uefi_StandaloneMmOptee_RELEASE.bin    {sdkpath}/Linux_for_Tegra/bootloader/standalonemm_optee_t234.bin
 export CROSS_COMPILE_AARCH64_PATH=/toolchain/aarch64--glibc--stable-2022.08-1
 export CROSS_COMPILE_AARCH64=/toolchain/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu-
 export UEFI_STMM_PATH=/home/zpx/work/uefi/nvidia-uefi_36.4.4/images/uefi_StandaloneMmOptee_RELEASE.bin
 ./optee_src_build.sh -p t234 -t
dtc -I dts -O dtb -o ./optee/tegra234-optee.dtb ./optee/tegra234-optee.dts
1. Extract the ATF source package.
   mkdir atf_build
   tar -I lbzip2 -C atf_build -xpf atf_src.tbz2
2. Build the ATF source code:
   cd atf_build
   export NV_TARGET_BOARD=generic
   ./nvbuild.sh
   cd ..
./gen_tos_part_img.py \
       --monitor ./atf_build/arm-trusted-firmware/generic-t234/tegra/t234/release/bl31.bin \
       --os ./optee/build/t234/core/tee-raw.bin \
       --dtb ./optee/tegra234-optee.dtb \
       --tostype optee \
       ./tos.img
cp tos.img     {SDK_PATH}/Linux_for_Tegra/bootloader/tos-optee_t234.img
cp tos.img     {SDK_PATH}/Linux_for_Tegra/bootloader/tos_t234.img
But it didn’t have any effect.
Then I re burned jp6.2.1 as a whole.Then repeat the operation as described in the previous text.
But there will still be problems encountered.
hello zhang.pei.xing,
please double check developer guide for reference,
for instance, Update the db/dbx Keys with a Capsule Update.
I have confirmed repeatedly, and I have written down my entire process. Can you help me see where the problem lies?
Prepare the key first.
cd to <LDK_DIR>#LDK_DIR就是Linux_for_Tegra所在目录
mkdir uefi_keys
cd uefi_keys
GUID=$(uuidgen)
openssl req -newkey rsa:2048 -nodes -keyout PK.key  -new -x509 -sha256 -days 3650 -subj "/CN=my Platform Key/" -out PK.crt
cert-to-efi-sig-list -g "${GUID}" PK.crt PK.esl
openssl req -newkey rsa:2048 -nodes -keyout KEK.key  -new -x509 -sha256 -days 3650 -subj "/CN=my Key Exchange Key/" -out KEK.crt
cert-to-efi-sig-list -g "${GUID}" KEK.crt KEK.esl
openssl req -newkey rsa:2048 -nodes -keyout db_1.key  -new -x509 -sha256 -days 3650 -subj "/CN=my Signature Database key/" -out db_1.crt
cert-to-efi-sig-list -g "${GUID}" db_1.crt db_1.esl
openssl req -newkey rsa:2048 -nodes -keyout db_2.key  -new -x509 -sha256 -days 3650 -subj "/CN=my another Signature Database key/" -out db_2.crt
cert-to-efi-sig-list -g "${GUID}" db_2.crt db_2.esl
The configuration file for the key.
vim uefi_keys.conf
UEFI_DB_1_KEY_FILE="db_1.key";  # UEFI payload signing key
UEFI_DB_1_CERT_FILE="db_1.crt"; # UEFI payload signing key certificate
UEFI_DEFAULT_PK_ESL="PK.esl"
UEFI_DEFAULT_KEK_ESL_0="KEK.esl"
UEFI_DEFAULT_DB_ESL_0="db_1.esl"
UEFI_DEFAULT_DB_ESL_1="db_2.esl"
 sudo tools/gen_uefi_keys_dts.sh uefi_keys/uefi_keys.conf
Burn command
sudo ./tools/kernel_flash/l4t_initrd_flash.sh  --uefi-keys uefi_keys/uefi_keys.conf jetson-agx-orin-devkit internal
Prepare the key to be upgraded.
cd to <LDK_DIR>/uefi_keys
GUID=$(uuidgen)
openssl req -newkey rsa:2048 -nodes -keyout update_kek_0.key  -new -x509 -sha256 -days 3650 -subj "/CN=Update KEK 0/" -out update_kek_0.crt
cert-to-efi-sig-list -g "${GUID}" update_kek_0.crt update_kek_0.esl
sign-efi-sig-list -a -k PK.key -c PK.crt KEK update_kek_0.esl update_kek_0.auth
openssl req -newkey rsa:2048 -nodes -keyout update_db_0.key  -new -x509 -sha256 -days 3650 -subj "/CN=Update DB 0/" -out update_db_0.crt
cert-to-efi-sig-list -g "${GUID}" update_db_0.crt update_db_0.esl
sign-efi-sig-list -a -k update_kek_0.key -c update_kek_0.crt db update_db_0.esl update_db_0.auth
openssl req -newkey rsa:2048 -nodes -keyout update_db_1.key  -new -x509 -sha256 -days 3650 -subj "/CN=update DB 1/" -out update_db_1.crt
cert-to-efi-sig-list -g "${GUID}" update_db_1.crt update_db_1.esl
sign-efi-sig-list -a -k KEK.key -c KEK.crt db update_db_1.esl update_db_1.auth
sign-efi-sig-list -a -k update_kek_0.key -c update_kek_0.crt dbx db_2.esl dbx_db_2.auth
vim uefi_update_keys.conf
UEFI_DB_1_KEY_FILE="update_db_0.key";  # UEFI payload signing key
UEFI_DB_1_CERT_FILE="update_db_0.crt"; # UEFI payload signing key certificate
UEFI_UPDATE_PRE_SIGNED_KEK_0="update_kek_0.auth"
UEFI_UPDATE_PRE_SIGNED_DB_0="update_db_0.auth"
UEFI_UPDATE_PRE_SIGNED_DB_1="update_db_1.auth"
UEFI_UPDATE_PRE_SIGNED_DBX_0="dbx_db_2.auth"
cd ..
sudo tools/gen_uefi_keys_dts.sh uefi_keys/uefi_update_keys.conf
sudo chmod 644 uefi_keys/*.auth
cd to <LDK_DIR>
cp uefi_keys/UefiUpdateSecurityKeys.dtbo bootloader/
Create upgraded firmware.
sudo ADDITIONAL_DTB_OVERLAY="UefiUpdateSecurityKeys.dtbo" ./l4t_generate_soc_bup.sh  -e t23x_agx_bl_spec t23x
./generate_capsule/l4t_generate_soc_capsule.sh -i bootloader/payloads_t23x/bl_only_payload -o ./TEGRA_AGX.Cap t234
Upgrade method.
fwupdmgr get-devices
cd /sys/firmware/efi/efivars/
printf "\x07\x00\x00\x00\x04\x00\x00\x00\x00\x00\x00\x00" > /tmp/var_tmp.bin
sudo dd if=/tmp/var_tmp.bin of=OsIndications-8be4df61-93ca-11d2-aa0d-00e098032b8c bs=12;sync
sudo fwupdtool install-blob /home/nvidia/TEGRA_AGX.Cap  a45df35ac0e948ee180fe216a5f703f32dda163f
sudo mount /dev/disk/by-partlabel/esp /media/
sudo mkdir /media/EFI/UpdateCapsule
sudo cp -rf TEGRA_AGX.Cap   /media/EFI/UpdateCapsule/
I have also tried upgrading using manual commands before. But the result is the same.
the assertion matches the known UEFI “Assertion 3” variable-store issue.
since you rebuilt StandaloneMm and the TOS image, please verify that your edk2-nvidia source contains both fixes from PR #113, especially commit 7d045f2. the public r36.4.4-updates branch has been reported as missing this block-erase fix
I have already included this patch in the previous compilation.、
But I am using the R36.4.4 version of UEFI.Do I need to switch to version r36.4.4-updates?Okay, I’ll verify with the r36.4.4-updates version again.You can also verify if this can be resolved.
I added this patch to the 36.4.4-updates version of UEFI, but it still fails.
please double check the steps to update tos image rather than uefi_jetson.bin
Step 1. apply the patch(https://github.com/NVIDIA/edk2-nvidia/pull/110/commits/8d0b58c5374f24ebaffe8472a0956354cd725f25) to UEFI source
Step 2. run the following command to build uefi_StandaloneMmOptee_RELEASE.bin
$ edk2_docker edk2-nvidia/Platform/NVIDIA/StandaloneMmOptee/build.sh
Step 3. refer to the steps in atf_and_optee_README.txt to build tos image (<Linux_for_Tegra>/bootloader/tos-optee_t234.img)
Step 4. flash the QSPI only to apply the change
$ sudo ./flash.sh -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit mmcblk0p1
I really followed the steps you said. And it has been repeated five or six times.
It still failed. If you succeed, can you provide me with the firmware you have compiled for verification?
please give it a try with.. tos_r36.4.4_patched.img.zip (1.2 MB)
you should update the TOS image (i.e. $OUT/Linux_for_Tegra/bootloader/tos-optee_t234.img) with the attachment,
please re-flash your target to apply this binary file update.
I used your firmware and still encountered issues after updating dbx.
may I know what’s your commands to flash a target?
My command is as follows.
And the command for me to create the firmware upgrade is as follows.
I used debug versions of UEFI and Optee firmware.I have obtained the following log, hoping it can help you analyze it.
minicom_20260915_update.zip (84.2 KB)
here’s the actual failure.
 VarIntValidate:ERROR Failed to match Stored Measurement with computed.
VarIntValidate: FAILED TO VALIDATE
MmFvbSmmVarReady:Var Store Validation failed Device ErrorASSERT [FvbNorFlashStandaloneMm] /home/zpx/work/uefi/nvidia-uefi_36.4.4-updates/edk2-nvidia/Silicon/NVIDIA/Drivers/FvbNorFlashDxe/FvbNorFlashStandaloneMm.c(937): ((BOOLEAN)(0==1))
ˇ‚
please double check you’re using same UEFI variable-auth/EKB auth key.
you may also try to reflash only QSPI to apply the binary file.
for instance,
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh -p "-c bootloader/generic/cfg/flash_t234_qspi.xml --no-systemimg" jetson-agx-orin-devkit internal
So why does this issue occur when updating dbx?
as mentioned, an auth key mismatch can lead to VarStore validation failure.
I am using the same UEFI variable-auth/EKB auth key.
I have repeatedly confirmed it.
Have you verified the updates of dbx? And after updating dbx, perform repeated reboot tests.
I have added the following printing.
uefi_optee_debug.patch.txt (7.7 KB)
Then we obtained the following log.
minicom_20260915_1618.zip (59.8 KB)
When updating kek as shown in the above figure, the append write of db was also added.
diff --git a/Silicon/NVIDIA/Library/NvVarIntLibrary/NvVarIntLibrary.c b/Silicon/NVIDIA/Library/NvVarIntLibrary/NvVarIntLibrary.c
index 16c239fb..37b6a105 100644
--- a/Silicon/NVIDIA/Library/NvVarIntLibrary/NvVarIntLibrary.c
+++ b/Silicon/NVIDIA/Library/NvVarIntLibrary/NvVarIntLibrary.c
@@ -362,8 +362,8 @@ MeasureSecureDbVars (
   PayloadPtr  = Data;
   PayloadSize = DataSize;
-  AppendWrite = FALSE;
   for (Index = 0; Index < (sizeof (SecureVars) / sizeof (SecureVars[0])); Index++) {
+    AppendWrite = FALSE;^M
     DEBUG ((
       DEBUG_INFO,
       "%a: First add %s VarName \n",
AppendWrite needs to be placed in a for loop to avoid adding kek measurement values to db and dbx.
I verified that it can update keys such as dbx and db without triggering an assert.
You’d better also verify it and update it in the later JP version.And also include the solutions to the bugs you left behind before.
hi jerryChang:
Do you have verification?
we’ve arrange resources for internal investigation, there’s no conclusion yet.
