The system hangs while running the fTPM stress test script on the Orin Nano
Hardware: Orin Nano
L4T / JetPack version:
cat /etc/nv_tegra_release
# R39 (release), REVISION: 2.0, GCID: 45755727, BOARD: generic, EABI: aarch64, DATE: Mon Jun  1 09:28:48 PM UTC 2026
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
During the fTPM stress test, the script below was used. Its main operations are saving and deleting keys.
#!/bin/bash
set -euo pipefail
SRK_HANDLE="0x81000001"
KEY_HANDLE="0x81000002"
ALGORITHM="rsa4096"
KEY_ATTR="fixedtpm|fixedparent|sensitivedataorigin|userwithauth|sign"
SLEEP_SEC=1
OUTPUT_DIR="./tpm_loop_test"
mkdir -p "${OUTPUT_DIR}"
tpm2_evictcontrol -C o -c "${KEY_HANDLE}" 2>/dev/null || true
echo "===== fTPM 密钥生成/持久化/删除 压力测试 ====="
loop_cnt=0
while true; do
    loop_cnt=$((loop_cnt + 1))
    ts=$(date +%Y%m%d_%H%M%S_%N)
    round_dir="${OUTPUT_DIR}/round_${loop_cnt}_${ts}"
    mkdir -p "${round_dir}"
    echo -e "\n[Round ${loop_cnt}] ${ts}"
    echo "[${loop_cnt}] tpm2_create RSA4096..."
    tpm2_create -C "${SRK_HANDLE}" -G "${ALGORITHM}" -a "${KEY_ATTR}" -c "${round_dir}/key.ctx"
    echo "[${loop_cnt}] evictcontrol persist ${KEY_HANDLE}..."
    tpm2_evictcontrol -C o -c "${round_dir}/key.ctx" "${KEY_HANDLE}"
    echo "[${loop_cnt}] readpublic..."
    tpm2_readpublic -c "${KEY_HANDLE}" -o "${round_dir}/pubkey.pem" -f pem
    sleep "${SLEEP_SEC}"
    echo "[${loop_cnt}] delete ${KEY_HANDLE}..."
    if tpm2_getcap handles-persistent | grep -q "${KEY_HANDLE}"; then
        echo "[ERROR ${loop_cnt}] Delete failed!"
        exit 1
    fi
    echo "[OK ${loop_cnt}] Done"
done
The SSH terminal output is shown below. The system froze directly during the 9th loop.
[9] tpm2_create RSA4096...
name-alg:
  value: sha256
  raw: 0xb
attributes:
  value: fixedtpm|fixedparent|sensitivedataorigin|userwithauth|sign
  raw: 0x40072
type:
  value: rsa
  raw: 0x1
exponent: 65537
bits: 4096
scheme:
  value: null
  raw: 0x10
scheme-halg:
  value: (null)
  raw: 0x0
sym-alg:
  value: null
  raw: 0x10
sym-mode:
  value: (null)
  raw: 0x0
sym-keybits: 0
rsa: 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
[9] evictcontrol persist 0x81000002...
persistent-handle: 0x81000002
action: persisted
[9] readpublic...
qualified name: 000bd97b69211b26724112adff85d393331e1e76f88dab87d49ade7da2d3b48578ba
name-alg:
  value: sha256
  raw: 0xb
attributes:
  raw: 0x40072
type:
  value: rsa
  raw: 0x1
exponent: 65537
bits: 4096
scheme:
  value: null
  raw: 0x10
scheme-halg:
  value: (null)
  raw: 0x0
sym-alg:
  value: null
  raw: 0x10
sym-mode:
  value: (null)
  raw: 0x0
sym-keybits: 0
[9] delete 0x81000002...
Then the serial terminal output is shown below:
[ 5967.811850] ---[ end trace 0000000000000000 ]---
[ 5967.811865] spi-tegra114 3210000.spi: spi transfer timeout
[ 5967.814038] spi_master spi0: failed to transfer one message from queue
[ 5967.814238] spi_master spi0: noqueue transfer failed
[ 5968.835578] WARNING: CPU: 2 PID: 102311 at drivers/spi/spi-tegra114.c:1112 tegra_spi_transfer_one_message+0x474/0x50c [spi_tegra114]
[ 5968.835845] ---[ end trace 0000000000000000 ]---
[ 5968.835851] spi-tegra114 3210000.spi: spi transfer timeout
[ 5968.837288] spi_master spi0: failed to transfer one message from queue
[ 5968.837494] spi_master spi0: noqueue transfer failed
[ 5969.859612] WARNING: CPU: 2 PID: 102311 at drivers/spi/spi-tegra114.c:1112 tegra_spi_transfer_one_message+0x474/0x50c [spi_tegra114]
[ 5969.859877] ---[ end trace 0000000000000000 ]---
[ 5969.859892] spi-tegra114 3210000.spi: spi transfer timeout
[ 5969.861409] spi_master spi0: failed to transfer one message from queue
[ 5969.861615] spi_master spi0: noqueue transfer failed
[ 5970.883591] WARNING: CPU: 2 PID: 84852 at drivers/spi/spi-tegra114.c:1112 tegra_spi_transfer_one_message+0x474/0x50c [spi_tegra114]
[ 5970.883856] ---[ end trace 0000000000000000 ]---
[ 5970.883868] spi-tegra114 3210000.spi: spi transfer timeout
[ 5970.887309] spi_master spi0: failed to transfer one message from queue
[ 5970.887533] spi_master spi0: noqueue transfer failed
[ 5971.907619] WARNING: CPU: 2 PID: 84852 at drivers/spi/spi-tegra114.c:1112 tegra_spi_transfer_one_message+0x474/0x50c [spi_tegra114]
[ 5971.907883] ---[ end trace 0000000000000000 ]---
[ 5971.907889] spi-tegra114 3210000.spi: spi transfer timeout
[ 5971.911535] spi_master spi0: failed to transfer one message from queue
[ 5971.911742] spi_master spi0: noqueue transfer failed
[ 5972.931576] WARNING: CPU: 2 PID: 102311 at drivers/spi/spi-tegra114.c:1112 tegra_spi_transfer_one_message+0x474/0x50c [spi_tegra114]
[ 5972.931842] ---[ end trace 0000000000000000 ]---
[ 5972.931858] spi-tegra114 3210000.spi: spi transfer timeout
[ 5972.933115] spi_master spi0: failed to transfer one message from queue
[ 5972.933316] spi_master spi0: noqueue transfer failed
[ 5973.955570] WARNING: CPU: 2 PID: 102311 at drivers/spi/spi-tegra114.c:1112 tegra_spi_transfer_one_message+0x474/0x50c [spi_tegra114]
[ 5973.955840] ---[ end trace 0000000000000000 ]---
[ 5973.955846] spi-tegra114 3210000.spi: spi transfer timeout
[ 5973.958024] spi_master spi0: failed to transfer one message from queue
[ 5973.958227] spi_master spi0: noqueue transfer failed
[ 5974.979591] WARNING: CPU: 2 PID: 84852 at drivers/spi/spi-tegra114.c:1112 tegra_spi_transfer_one_message+0x474/0x50c [spi_tegra114]
[ 5974.979857] ---[ end trace 0000000000000000 ]---
[ 5974.979863] spi-tegra114 3210000.spi: spi transfer timeout
[ 5974.981278] spi_master spi0: failed to transfer one message from queue
[ 5974.981465] spi_master spi0: noqueue transfer failed
[ 5976.003580] WARNING: CPU: 2 PID: 84852 at drivers/spi/spi-tegra114.c:1112 tegra_spi_transfer_one_message+0x474/0x50c [spi_tegra114]
[ 5976.003845] ---[ end trace 0000000000000000 ]---
[ 5976.003860] spi-tegra114 3210000.spi: spi transfer timeout
[ 5976.005814] spi_master spi0: failed to transfer one message from queue
[ 5976.006015] spi_master spi0: noqueue transfer failed
[ 5977.027580] WARNING: CPU: 2 PID: 102311 at drivers/spi/spi-tegra114.c:1112 tegra_spi_transfer_one_message+0x474/0x50c [spi_tegra114]
[ 5977.027846] ---[ end trace 0000000000000000 ]---
[ 5977.027852] spi-tegra114 3210000.spi: spi transfer timeout
[ 5977.029350] spi_master spi0: failed to transfer one message from queue
[ 5977.029544] spi_master spi0: noqueue transfer failed
[ 5978.051591] WARNING: CPU: 2 PID: 102311 at drivers/spi/spi-tegra114.c:1112 tegra_spi_transfer_one_message+0x474/0x50c [spi_tegra114]
[ 5978.051855] ---[ end trace 0000000000000000 ]---
Hello @mack.shi!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
hello mack.shi,
may I have more details of this test approach? what the test actually exercises and whether it targets fTPM?
actually, the script does more than “saving and deleting keys”.
each iteration..
(1) Creates a new RSA4096 key under the existing parent 0x81000001.
(2) Makes the key persistent at 0x81000002.
(3) Reads its public key.
(4) Removes its persistent TPM entry.
could you clarify how you confirmed that these commands target the OP-TEE fTPM? please share the selected TCTI/device, TPM driver binding, and tpm2_getcap properties-fixed output. also, how was the parent at 0x81000001 created, and are other TPM or SPI applications running concurrently?
