Hello, we are using the T5000 with our own carrier board (manufactured according to the official PCB design files). When running some large models with vLLM, we encounter an issue where the system automatically powers off and shuts down. We have also seen other developers in the community reporting the same problem.
It was mentioned that the issue might be related to a flaw in the power supply design provided in the reference design. We would like to know how to resolve this specifically.
What is the power supply used? (AC adaptor, custom PSU, etc)
As stated in the Design Guide, the 1ms system EDP can reach up to 330W for Jetson T5000. If your power source cannot sustain this transient load, or your pre-regulator OCP is set below this value for SYS_VIN_HV, MODULE_SHDN_N will be asserted during heavy inference workloads like LLM.
Hello, thank you for your reply. We use an adjustable power supply with a voltage set to 28V and a current threshold set to 10A. However, when loading the model, there will be a power outage and shutdown issue. After setting the current threshold to 10A yesterday afternoon, there was no corresponding situation. Is this the situation you mentioned? We also purchased relevant professional adapters yesterday, but they haven’t arrived yet.
Just to confirm, did the shutdown occur when the current limit was set below 10A, and has the issue stopped occurring since you increased it to 10A yesterday afternoon?
As mentioned previously, the system EDP can reach up to 330W, therefore, we recommend using a power supply with sufficient headroom to handle this transient power demand.
Thank you for your reply. Yes, before yesterday afternoon, we had always limited the current of the adjustable power supply to 5A. However, when loading the model yesterday, this situation occurred. Later, we changed the current limit to 5A and this problem did not occur again. But there were some warnings indicating that the current was overloaded. (“System throttled due to Over-current.”)。 Similarly, we detected the current overload situation you mentioned on the adjustable power supply, with a power much greater than 140W (approximately up to 28V 5.5A when the model is loaded)
The system throttled due to Over-current warning indicates that the module’s overcurrent protection was triggered. In MAXN mode, if the instantaneous combined power of VDD_GPU and VDD_CPU_SOC_MSS reaches 144W OC limit, the CPU and GPU clocks are throttled to 50%. (refer to NVIDIA Jetson Linux Developer Guide)
You mentioned that the current limit had always been set to 5A and that it was later changed to 5A again. Could you please clarify the current-limit settings before and after the issue?
Also, how was a current of approximately 5.5A observed while the power supply was limited to 5A?
We are using an adjustable power supply; initially, it was set to 28V/5A, but power loss occurred when loading the model. We subsequently discovered that the current exceeded 5A under these conditions, triggering the power supply’s protection mode. We have since increased the current threshold to 10A, and the issue has been resolved. I believe the problem was caused by the T5000 drawing excessive power during model loading, pushing the current beyond the 5A limit.
Hello, a new issue has arisen. We performed a firmware update using the official PD tool—as shown in the image, the upgrade was successful. However, we have noticed that a warning pops up upon startup regardless of whether we use Type-C or Micro-Fit power delivery. We are indeed using a third-party adapter.
Thank you for the update for sharing the screen shot.
The “Unknown power adapter detected” warning you are seeing is raised by the power-adapter detection patch in the software during login. This means the software could not validate the connected adapter as a recognized/supported power source. It does not indicate that the system or your model workload has failed.
Will this affect our use of third-party power supplies? This warning appeared only after we upgraded the PD firmware version; it was not present before.
