The temperature of the NX module is abnormal during operation
hello everyone!
We use NX modules to work on our self-developed carrier board. There are about 100 pieces in total. An external network camera is used for NX to process images. One of the modules will run for about a minute or two, and the temperature will reach 80 Many degrees, close to ninety degrees
So the happened rat is 1/100? All 100 modules been tested?
The same usage, the same scene, we must have used more than 100 modules. I can’t remember the exact number. All of them have been tested. Only this one will have this situation.
For this case, I will suggest to contact with the distributor to swap this module or do the RMA: Jetson FAQ | NVIDIA Developer
