When I run the example tf_to_trt.py,the error is as below:
2017-10-19 10:02:31.683051: E tensorflow/stream_executor/cuda/cuda_dnn.cc:352] Loaded runtime CuDNN library: 7001 (compatibility version 7000) but source was compiled with 5110 (compatibility version 5100). If using a binary install, upgrade your CuDNN library to match. If building from sources, make sure the library loaded at runtime matches a compatible version specified during compile configuration.
2017-10-19 10:02:31.683772: F tensorflow/core/kernels/conv_ops.cc:671] Check failed: stream->parent()->GetConvolveAlgorithms(&algorithms)
Aborted (core dumped)
the cudnn version of tensorrt is cudnn7.0, but tensorflow does not support cudnn7.0 now. How to solve it?
