I get the following error with 2023.2.1
├ nsys profile sleep 1
The timeout expired.
However 2023.1.1 works correctly
Generating '/tmp/nsys-report-772f.qdstrm'
[1/1] [========================100%] report6.nsys-rep
Generated:
/central/home/spjbyrne/report6.nsys-rep
Unfortunately I don’t have sudo
access, so I can’t use nvidia-persistenced
. If I try to run it I get
├ nvidia-persistenced
nvidia-persistenced failed to initialize. Check syslog for more details.
Would I be correct in assuming that “nsys profile sleep 1” is profiling a one second sleep?
My guess would be that there has been a performance change in the set up code that causing that to not be a sufficient time interval for sleep. Can you try with a longer sleep?
No, that doesn’t seem to help. In fact the time it takes seems to be independent of the length of the sleep
├ time nsys profile sleep 1
real 0m30.219s
user 0m0.096s
sys 0m0.122s
├ time nsys profile sleep 60
real 0m30.214s
user 0m0.093s
sys 0m0.106s
Somewhat strangely, we only see it on certain nodes. And on some nodes we actually have the opposite (it works with 2023.2.1, but times out with 2023.1.1).
