Jason nano 2GB, Jetson pack 4.6.1
I successfully configured ttyTHS1 with the help from linuxdev top Contributor and JerryChang
But when I try to config the other one: ttyS0, (I try check group, and it is “tty” group) the problem is : can transfer data only but can not receive the data. Please help
Group tty
means console is already using that port, so you cannot use this until serial console is disabled or moved to a different port. To disable:
sudo stop nvgetty.service
sudo disable nvgetty.service
You should also beware that when you look at a serial device with naming convention “ttyS#
” that this is a legacy driver (which early boot supports), and that the convention “ttyTHS#
” is for the newer “Tegra High Speed” driver. These are two separate drivers which can operate on the same UART, but you should not use both simultaneously. Be careful to not consider ttyS0
and possibly one of the ttyTHS
files as two separate UARTs. I think ttyTHS1
is a separate UART compared to ttyS0
, but there can be exceptions.
Thanks linuxdev for quick response.
Since Jason Nano 2GB has 2 sets of pins headers at which provides the serial communication:
40-Pin Header J6
12-Pin Header J12
I try to use both headers for 2 seperate communications. One set is for ttyTHS1 and other for ttyS0. The ttyTHS1 is successful one. For ttyS0, I tried as your suggestions but it still does not work: ttyS0 allow sending out data only, NOT allow receiving data.
First verify that the group of ttyS0
is “dialout
”. Once that is done, can you try a serial loopback test? What you would do is wire the ttyS0
TX to RX, and optionally also CTS to RTS, then point a serial terminal program at ttyS0
. Typing in text should result in echo of the text to the terminal.
Hi linuxdev,
I made the change in 99-tegra-device.rules : KERNEL==“ttyS0” OWNER=“root” GROUP=“dialout” MODE=“0666”
And verify that group of ttyS0 is “dialout”. Then I did a serial loopback test as you suggested (wire the ttyS0
TX to RX, then point a serial terminal program at ttyS0) but when typing in text, it did NOT result in echo of the text to the terminal.
Noted that the original GROUP of ttyS0 is “tty”
Please help. Thanks linuxdev
Hi linuxdev,
I just search around the FORUM, and see this interested one from you:
Serial console is what I would consider “important backup” in embedded. However, if you remove the right part of the kernel boot argument, then this tty will stop being used for console and messages once Linux starts. On the other hand, if this port sees any activity at all during boot within the U-Boot stage, then your system will halt. You’d need to have any hardware removed from this port until after boot completes.
For more recent releases the kernel command line boot arguments are in the device tree, and the device tree is flashed to a partition after being signed. Thus simple steps of updating a file and copying it in no longer apply.
Within the device tree look for “chosen”. This will have a node within it, “bootargs”. A kernel accepts two consoles as arguments…you’d be removing the arguments related to serial console. Those arguments look like:
console=ttyS0,115200n8
Eliminate those from your device tree, and then flash the new device tree. Serial console should then be removed after U-Boot is gone (you would have to modify U-Boot to get rid of it there).
And my other question is that: HOW DO I FLASH THE NEW DEVICE TREE (my model is Jetson Nano 2 GB)
Thanks linuxdev
Just to emphasize, it isn’t changing group to tty
from console
which stops serial console from running. Group tty
is a side-effect, and changing it to group dialout
without stopping the console service will just break console and not stop it.
There are two independent locations where console will run:
- In the bootloader stages before Linux;
- In Linux itself.
Those two locations are independent. If you are not sending traffic to the UART during boot stages (prior to reaching Linux), then there is no need to change this.
Depending on release and setup it may be that it is enough to just follow the mentioned removal of the “console=...
” listed above for both. However, before you do this, I recommend removing the changes you made to set group to “dialout
”, and instead using systemd
to disable serial console within Linux. It is reasonable to remove the noted serial console argument in extlinux.conf
, but perhaps is unnecessary if you disable via:
sudo systemctl stop nvgetty.service
sudo systemctl disable nvgetty.service
Once those two steps are taken the device special file should self-revert to group dialout
instead of group console
. This truly disables serial console rather than just breaking permissions. Does that help?
Hi linuxdev,
I tried all your suggestions, but this time it can receive less than 10 characters and then the “console” take over the ttyS0 and it stop receiving any character. Here 's my set up: Nano2GB connecting to PC via serial. The application on nano (using ttyS0) will send out 3 characters and wait to receive the data from PC. When I mentioned “console take over ttyS0”, it means that after the nano receive 5 characters then the nano sending out streaming of data … as the version of ubuntu, powerup info, that’s why I think the “console” took over the ttyS0. The “console” and the application used ttyS0 at the same time and cause traffic. So my questions: (1) How can I remove running of console from “bootloader”; (2) If it relates to device tree, I look at the directory /boot/dtb in which has file
kernel_tegra210-p3448-0003-p3542-0000.dtb
Should we modify the file?
Thanks so much
Yes, typically console disable is just in Linux, and does not disable in boot stages (and in boot stages stray characters can cause issues during boot). In file “/boot/extlinux/extlinux.conf
”, do you see something similar to (the ttyTCU0
might differ, someone else already mentioned this, but there is a twist in the story I’ll explain below regarding device tree):
console=ttyTCU0,115200n8
If so, copy the original somewhere for reference, and then remove this from the file. Try again.
Once actually booted to Linux, verify that the group of “ls -l /dev/ttyS0
” is “dialout
”, and not “tty
Typically, if earlier boot stages get a stray character at the wrong moment, then the boot will halt rather than continuing. If boot actually runs Linux, then you know a stray serial console character halting was not an issue.
Also, sometimes device tree can add options not expected. What do you see from:
cat /proc/cmdline
(this could reintroduce the above phrase I had you remove from extlinux.conf
Which serial console application are you using for cases where you might just be testing? Or is this data entirely from a different means, e.g., echo
or a program?
Btw, you are correct that if two programs both try to use the serial UART, then the behavior might be just what it is supposed to be doing. Also beware that there is a single UART behind both the “ttyS#
” naming convention (of a given “#
”) and the “ttyTHS#
” naming convention. The naming is due to different drivers on the same UART. If you were to use both the ttyS#
and the same UART via the ttyTHS#
, then there would be an undefined conflict. Just beware that each ttyS#
and ttyTHS#
entry is not equivalent to different UARTs (they can be, but naming convention alone is not a way to verify a specific UART is unique).
In the case of removing any kind of serial console entry see:
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-325/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/kernel_boot_time.html#wwpID0E0YB0HA
