We are using TX2 Module to develop a controller for automatic driving of construction vehicles, and develop and design a carrier board by ourselves.
The TX2 Module suddenly crashes and a black screen appears after being powered on on the carrier board developed by ourselves for many days. The attached file is the printed log. Please help find the cause of the failure, thank youdmesg20210326.log (118.0 KB)
so, this is a long run stability issue,
may I know which JetPack release you’re working with,
also, may I know how many days you’re running to see the failure.
thanks
DearJerryChang,
The problem posted by Mr arron arose in our lab, so let me answer your concerns. When the TX2 Module crashed, It is running image proceessing alogrithm, which is a virtual scene about unmanned mine.
The algorithm is not very complicated, but the module has been running for about one week and the temperature is high.
we guess it is the high temperature that results in the crashing. but we are not sure.
Hope this is helpful. Thanks
could you please enable tegrastats utility to monitor the frequencies, temperatures, powers…etc
you should also refer to Thermal Specifications for the supported power states; there’re software and hardware throttling for difference trip points.
thanks
