The USB can not be recognized with The NVIDIA NANO core chip randomness,The NVIDIA NANO and NX were tested separately on the same carrier board,The USB can not be recognized randomness with NANO, The system starts normally, and the external USB device cannot be identified。It may or may not be restored after the restart,Reinsert the Nano then restart the NANO will return to normal most of the time。On the same carrier board, install NVIDIA NX module and system booting successfully, test 100 times, no USB exception。
This problem was solved by attaching the RTC button battery to the NANO’s PMIC_BBAT pin。
Now I want to find a solution without the RTC button battery,Pls help,
Pls reference the log recorded error information,
LOG information: Abnormal information in (** ** ) is compared with normal identified logs
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201 (louis@ubuntu) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) ) #2 SMP PREEMPT Thu May 12 17:48:13 CST 2022
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000emphasized text
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 1.089998] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.595802] Host read timeout at address 545c00c4
[ 1.820598] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.828225] imx219 7-0010: board setup failed
[ 1.856647] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.864259] imx219 8-0010: board setup failed
[ 2.398114] usb 1-3: device not accepting address 2, error -71
[ 2.431709] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.942091] usb 1-3: device not accepting address 3, error -71
[ 3.843996] using random self ethernet address
[ 3.864647] using random host ethernet address
[ 4.047512] random: crng init done
[ 4.050915] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.448120] usb_wwan: loading out-of-tree module taints kernel.
[ 4.542256] usb 1-3: device descriptor read/64, error -71
[ 4.774253] usb 1-3: device descriptor read/64, error -71
[ 5.130267] usb 1-3: device descriptor read/64, error -71
[ 5.374228] usb 1-3: device descriptor read/64, error -71
[ 5.486166] usb usb1-port3: unable to enumerate USB device
[ 5.955772] Bridge firewalling registered
