The way of making CUDA code with static link of CUDA runtime
I have new question; Is it possible that Cuda application run on the CUDA-non installed PC?
It mentions whether we can build the cuda codes with static link of CUDA Run-times?
I tried to it;
1.I buit Cuda code with "Linker->input->additonal lib: added “cudart.lib”
I run the code at the PC without installing CUDA SDK.
Soon I saw error message which mentioned "It was able to executed because there were not cudart64_70.dll "
2.I buit Cuda code with "Linker->input->additonal lib: added “cudart_static.lib”
Application was able to executed without any errors.
Can we build the cuda code with statick link of CUDA Run time by using “cudart_static.llb” ?
I’d really appriciate it if anyone will give me the answer soon.
Regards,
That is the way to do it.
Thank you for your reply!
