Hello,I have a SN 2100 swtich,but I can’t use the command to manage the swtich,I know I should use the console cable to connect the PC,and I also enter the interface,but it shows I must input the ‘‘cumulus login’‘and ‘’ password’’ ,I input cumulus login :’‘admin’’,the password is also “admin”,but it tells me the login incorrect.
So I reset the switch back to factory defaults,but the issue isn’t solved. Your help will be appreciated , Thanks so much.
Dear Eddie,Thanks for your help.Now I can enter the swtich as you provided ,the system of the swtich seems Linux,to be honesty,I’m not familiar with the linux.I have another question,
Do you know whether the 2100 swtich support the function of Digital Diagnostic Monitoring.Where can I get the user guide?if you know the command ,could you tell me?Thanks so much.
