Hi teams
When we use AGX-Xavier with our own carry board to long run time test.,it show below error.It seems that the cpu can not schedule.Could you help me have a check ?
the log as below:
CPU-error.txt (47.9 KB)
BRs
thanks
Hi teams
the log as below:
BRs
thanks
Can reproduce with reference carry board?
workqueue thread is stuck. looks like a sw issue if the work you have introduces is not waiting for a HW event. Is the issue seen on a particular usecase or system is idle?
Hi Bibek
The system contains a Autopilot Apollo program.
The other is normal.(Xavier kernel and a full file system)
sorry, I could not understand your answer.
Is the issue seen with default jetpack?
In anycase, when this happens can you run sysrq trigger to show blocked tasks dump_stack?
sysrq+D
