There are some errors in the yolov3 example in deepstream 5.1 with A100
• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 5.1 triton
• TensorRT Version: 7.2.1
• NVIDIA GPU Driver Version: 450.80.02
We are testing the yolov3 example.
It runs normally on DGX-1, but there are some errors on DGX A100.
Here is the output:
root@8c1c343ca481:/opt/nvidia/deepstream/deepstream-5.1/sources/objectDetector_Yolo# deepstream-app -c deepstream_app_config_yoloV3.txt
 *** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Unknown or legacy key specified 'is-classifier' for group [property]
Warn: 'threshold' parameter has been deprecated. Use 'pre-cluster-threshold' instead.
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
Deserialize yoloLayerV3 plugin: yolo_83
Deserialize yoloLayerV3 plugin: yolo_95
Deserialize yoloLayerV3 plugin: yolo_107
0:00:12.005935058   456 0x55b61f3d7610 INFO                 nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.1/sources/objectDetector_Yolo/model_b1_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 4
0   INPUT  kFLOAT data            3x416x416
1   OUTPUT kFLOAT yolo_83         255x13x13
2   OUTPUT kFLOAT yolo_95         255x26x26
3   OUTPUT kFLOAT yolo_107        255x52x52
0:00:12.006023162   456 0x55b61f3d7610 INFO                 nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.1/sources/objectDetector_Yolo/model_b1_gpu0_int8.engine
0:00:12.066845522   456 0x55b61f3d7610 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/sources/objectDetector_Yolo/config_infer_primary_yoloV3.txt sucessfully
Runtime commands:
        h: Print this help
        q: Quit
        p: Pause
        r: Resume
**PERF:  FPS 0 (Avg)
**PERF:  0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
** INFO: <bus_callback:167>: Pipeline running
ERROR from sink_sub_bin_encoder1: Device '/dev/nvhost-msenc' failed during initialization
Debug info: gstv4l2object.c(4074): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/nvv4l2h264enc:sink_sub_bin_encoder1:
Call to S_FMT failed for YM12 @ 1920x1080: Unknown error -1
Quitting
KLT Tracker Init
App run failed
Please check this. A100 do not support hardware encode.
GPU H.264 (AVCHD) YUV 4:2:0 H.264 (AVCHD) YUV 4:4:4 H.264 (AVCHD) LOSSLESS H.265 (HEVC) YUV 4:2:0 H.265 (HEVC) YUV 4:4:4 H.265 (HEVC) LOSSLESS
MAX Color MAX Res. MAX Color MAX Res. MAX Color MAX Res. MAX Color MAX Res. MAX Color MAX Res. MAX Color MAX Res.
Ampere No No No No No No No No No No No No
(A100)
Thank you for your reply.
Will it be supported in the future?
I don’t think so, it’s production card, for ampere architecture card, non A100 support hardware encode. you also can get it from that page.
