If you have a scene at 60 frames per second, for 3600 frames, the entire scene should take 1 minute.
Oddly, this works correctly in Create. In Code, the entire scene finishes in about 24 seconds.
Just thought I would let you know.
Thanks! I’m guessing there’s some setting for controlling the playback speed (e.g. real-time vs as fast as possible) that we’re missing. Looking into it.
I think the problem may be in the combo box. If I set it to 120 FPS, it goes slower than if I set it to 60… 24 Goes the fastest.
Create works, so it is something specific to Code.
I was able to reproduce the issue. I’ve logged an internal issue, OM-91119, to get this fixed. Thanks for reporting it!
