When I set the source to 1 channel of offline video, the output detected video is stuck (WARNING: Overriding infer-config batch-size (4) with number of sources (1)), but when I input the same number of offline video as batch-size (4), it is smooth.
At this point I modified the input to RTSP and only input one way RTSP, the detected video is smooth.
Why is that?
• DeepStream Version
• TensorRT Version
• The pipeline being used
deepstream-app version 6.1.0
DeepStreamSDK 6.1.0
CUDA Driver Version: 11.4
CUDA Runtime Version: 11.0
TensorRT Version: 8.2
cuDNN Version: 8.4
libNVWarp360 Version: 2.0.1d3
Device on:A6000
Could you please attach your pipeline?
About the pipeline, I used deepstream-test3, no change.
nvstreammux -> nvinfer -> nvdslogger -> nvtiler -> nvvidconv -> nvosd->sink
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
We suggest you set the batch-size as much as the number of sources.
