There is error happening when i used dlprof to profile tensorrt sample code
When i run dlprof to profile tensort sample sample_onnx_mnist, there is error happening as below:
Exported successfully to
/tmp/nsys-report-5ba1-d87b-4be6-92c6.sqlite
Report file moved to “/usr/src/tensorrt/bin/./output-mnist/nsys_profile.qdstrm”
Report file moved to “/usr/src/tensorrt/bin/./output-mnist/nsys_profile.qdrep”
Report file moved to “/usr/src/tensorrt/bin/./output-mnist/nsys_profile.sqlite”
[DLProf-11:34:23] DLprof completed system call successfully
[DLProf-11:34:23] Initializing Nsight Systems database
[DLProf-11:34:23] Reading System Information from Nsight Systems database
[DLProf-11:34:23] Reading Domains from Nsight Systems database
[DLProf-11:34:23] Error Occurred:
[DLProf-11:34:23] Nsight Systems did not detect any NVTX traces. Please check your script and try again.
cmd line:
dlprof --mode=tensorrt --output_path ./output-mnist/ ./sample_onnx_mnist
But the sample char-rnn can be profiled using dlprof, so my question is whether need user to annotate source code manually using NVTX for tensorrt?
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
