There is no device (GeForce 8800)
Hi all,
I am trying to have CUDA working on the system that has NVIDIA GeForce 8800 (driver version: 1.0.9755), Fedora Core 6 (multi-arch based on x86_64).
Actually, this machine has two graphics hardware, one on-board and GF8800. The primary xserver runs on the on-board graphics hardware (DISPLAY=localhost:0.0) and the secondary on GF8800 (DISPLAY=localhost:1.0)
I’ve successfully installed CUDA and SDK, and comipled the sample projects without any problem. However, when I try to run those samples, I get this error message “There is no device”.
~/NVIDIA_CUDA_SDK/bin/linux32/release$ ./matrixmul
There is no device.
Of course, DISPLAY environment variable is set to “localhost:1.0”, and glxinfo shows me the correct output.
~$ glxinfo
name of display: localhost:1.0
display: localhost:1  screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
    GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,
    GLX_EXT_texture_from_pixmap, GLX_ARB_multisample, GLX_NV_float_buffer,
    GLX_ARB_fbconfig_float, GLX_EXT_framebuffer_sRGB
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
    GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
    GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float,
    GLX_EXT_fbconfig_packed_float, GLX_EXT_texture_from_pixmap,
GLX version: 1.3
GLX extensions:
    GLX_ARB_fbconfig_float, GLX_EXT_framebuffer_sRGB,
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 8800 GTS/PCI/SSE2
OpenGL version string: 2.1.0 NVIDIA 97.55
OpenGL extensions:
    GL_ARB_color_buffer_float, GL_ARB_depth_texture, GL_ARB_draw_buffers,
    GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
    GL_ARB_fragment_shader, GL_ARB_half_float_pixel, GL_ARB_imaging,
    GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
    GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
    GL_ARB_shadow, GL_ARB_shader_objects, GL_ARB_shading_language_100,
    GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3, GL_ARB_texture_float,
    GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_rectangle, GL_ARB_transpose_matrix,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_texture_float,
    GL_ATI_texture_mirror_once, GL_S3_s3tc, GL_EXT_texture_env_add,
    GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
    GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
    GL_EXT_Cg_shader, GL_EXT_depth_bounds_test, GL_EXT_draw_buffers2,
    GL_EXT_draw_instanced, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
    GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
    GL_EXT_framebuffer_object, GL_EXTX_framebuffer_mixed_formats,
    GL_EXT_framebuffer_sRGB, GL_EXT_gpu_program_parameters,
    GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
    GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
    GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
    GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_texture3D,
    GL_EXT_texture_array, GL_EXT_texture_buffer_object,
    GL_EXT_texture_compression_latc, GL_EXT_texture_compression_s3tc,
    GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,
    GL_EXT_texture_lod, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
    GL_EXT_texture_object, GL_EXT_texture_sRGB,
    GL_EXT_texture_shared_exponent, GL_EXT_timer_query, GL_EXT_vertex_array,
    GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
    GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_copy_depth_to_color,
    GL_NV_depth_buffer_float, GL_NV_depth_clamp, GL_NV_fence,
    GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_program,
    GL_NV_fragment_program_option, GL_NV_fragment_program2,
    GL_NV_framebuffer_multisample_coverage, GL_NV_gpu_program4,
    GL_NV_half_float, GL_NV_light_max_exponent, GL_NV_multisample_filter_hint,
    GL_NV_occlusion_query, GL_NV_packed_depth_stencil,
    GL_NV_parameter_buffer_object, GL_NV_pixel_data_range, GL_NV_point_sprite,
    GL_NV_primitive_restart, GL_NV_register_combiners,
    GL_NV_register_combiners2, GL_NV_texgen_reflection,
    GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
    GL_NV_texture_expand_normal, GL_NV_texture_rectangle,
    GL_NV_texture_shader, GL_NV_texture_shader2, GL_NV_texture_shader3,
    GL_NV_transform_feedback, GL_NV_vertex_array_range,
    GL_NV_vertex_array_range2, GL_NV_vertex_program, GL_NV_vertex_program1_1,
    GL_NV_vertex_program2, GL_NV_vertex_program2_option,
    GL_NV_vertex_program3, GL_NVX_conditional_render,
    GL_OES_conditional_query, GL_SGIS_generate_mipmap, GL_SGIS_texture_lod,
    GL_SGIX_depth_texture, GL_SGIX_shadow, GL_SUN_slice_accum
  visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
 id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x21 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x22 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x23 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x24 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x25 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x26 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x27 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x28 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x29 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x2a 24 tc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x2b 24 tc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x2c 24 tc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x2d 24 tc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x2e 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x2f 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x30 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x31 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x32 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x33 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x34 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x35 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x36 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x37 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x38 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x39 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x3a 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x3b 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x3c 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x3d 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x3e 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x3f 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x40 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x41 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x42 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x43 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x44 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x45 24 dc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x46 24 dc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x47 24 dc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x48 24 dc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x49 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x4a 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x4b 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x4c 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x4d 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x4e 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x4f 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x50 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x51 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x52 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x53 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x54 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x55 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x56 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x57 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x58 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x101 32 tc  1  0  0 c  .  .  0  0  0  0  0  0  0  0  0  0  0  0 0 None
I am wondering what makes the sample CUDA applications fail to execute.
Does anyone have any idea?
I appreciate your help in advance.
Have you installed the beta driver (97.51)?
It seems like you are using a different one:
Massimiliano
My understanding was that, at the moment at least, CUDA will not run on x86_64, even in 32 bit mode.
Brian
9755 won’t work. 9751 is required.
