i installed the drivers and SDK (Geforce GF7950GT, Gigabyte) but when i started the demos: NVIDIA_CUDA_SDK/bin/linux32/release/matrixmul, i got the messages
There is no device.
ls -l /dev/nvidia*
crw-rw---- 1 root video 195, 0 7. Mär 09:12 /dev/nvidia0
crw-rw---- 1 root video 195, 255 7. Mär 09:12 /dev/nvidiactl
glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,
GLX_EXT_texture_from_pixmap, GLX_ARB_multisample, GLX_NV_float_buffer,
GLX_ARB_fbconfig_float
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float,
GLX_EXT_fbconfig_packed_float, GLX_EXT_texture_from_pixmap,
GLX_EXT_framebuffer_sRGB
GLX extensions:
GLX_ARB_fbconfig_float, GLX_ARB_get_proc_address
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 7950 GT/PCI/SSE2
OpenGL version string: 2.1.0 NVIDIA 97.51
OpenGL extensions:
GL_ARB_color_buffer_float, GL_ARB_depth_texture, GL_ARB_draw_buffers,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_half_float_pixel, GL_ARB_imaging,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shadow, GL_ARB_shader_objects, GL_ARB_shading_language_100,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3, GL_ARB_texture_float,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_transpose_matrix,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_texture_float,
GL_ATI_texture_mirror_once, GL_S3_s3tc, GL_EXT_texture_env_add,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_Cg_shader, GL_EXT_depth_bounds_test, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_object, GL_EXT_gpu_program_parameters,
GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_texture3D,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_sRGB, GL_EXT_timer_query,
GL_EXT_vertex_array, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_KTX_buffer_region, GL_NV_blend_square,
GL_NV_copy_depth_to_color, GL_NV_depth_clamp, GL_NV_fence,
GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_program,
GL_NV_fragment_program_option, GL_NV_fragment_program2,
GL_NV_framebuffer_multisample_coverage, GL_NV_half_float,
GL_NV_light_max_exponent, GL_NV_multisample_filter_hint,
GL_NV_occlusion_query, GL_NV_packed_depth_stencil, GL_NV_pixel_data_range,
GL_NV_point_sprite, GL_NV_primitive_restart, GL_NV_register_combiners,
GL_NV_register_combiners2, GL_NV_texgen_reflection,
GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
GL_NV_texture_expand_normal, GL_NV_texture_rectangle,
GL_NV_texture_shader, GL_NV_texture_shader2, GL_NV_texture_shader3,
GL_NV_vertex_array_range, GL_NV_vertex_array_range2, GL_NV_vertex_program,
GL_NV_vertex_program1_1, GL_NV_vertex_program2,
GL_NV_vertex_program2_option, GL_NV_vertex_program3,
GL_NVX_conditional_render, GL_SGIS_generate_mipmap, GL_SGIS_texture_lod,
GL_SGIX_depth_texture, GL_SGIX_shadow, GL_SUN_slice_accum
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x21 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x22 24 dc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x23 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x24 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x25 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x26 24 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x27 24 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x28 24 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x29 24 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x2a 24 tc 0 32 0 r y . 8 8 8 0 4 16 0 16 16 16 16 0 0 None
0x2b 24 tc 0 32 0 r y . 8 8 8 8 4 16 0 16 16 16 16 0 0 None
0x2c 24 tc 0 32 0 r . . 8 8 8 0 4 16 0 16 16 16 16 0 0 None
0x2d 24 tc 0 32 0 r . . 8 8 8 8 4 16 0 16 16 16 16 0 0 None
0x2e 24 tc 0 32 0 r y . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x2f 24 tc 0 32 0 r y . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x30 24 tc 0 32 0 r . . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x31 24 tc 0 32 0 r . . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x32 24 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 2 1 Ncon
0x33 24 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 2 1 Ncon
0x34 24 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 4 1 Ncon
0x35 24 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 4 1 Ncon
0x36 24 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 2 1 Ncon
0x37 24 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 2 1 Ncon
0x38 24 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 4 1 Ncon
0x39 24 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 4 1 Ncon
0x3a 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 2 1 Ncon
0x3b 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 2 1 Ncon
0x3c 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 4 1 Ncon
0x3d 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 4 1 Ncon
0x3e 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 2 1 Ncon
0x3f 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 2 1 Ncon
0x40 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 4 1 Ncon
0x41 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 4 1 Ncon
0x42 24 tc 0 32 0 r y . 8 8 8 0 4 16 0 16 16 16 16 2 1 Ncon
0x43 24 tc 0 32 0 r y . 8 8 8 8 4 16 0 16 16 16 16 2 1 Ncon
0x44 24 tc 0 32 0 r y . 8 8 8 0 4 16 0 16 16 16 16 4 1 Ncon
0x45 24 tc 0 32 0 r y . 8 8 8 8 4 16 0 16 16 16 16 4 1 Ncon
0x46 24 tc 0 32 0 r . . 8 8 8 0 4 16 0 16 16 16 16 2 1 Ncon
0x47 24 tc 0 32 0 r . . 8 8 8 8 4 16 0 16 16 16 16 2 1 Ncon
0x48 24 tc 0 32 0 r . . 8 8 8 0 4 16 0 16 16 16 16 4 1 Ncon
0x49 24 tc 0 32 0 r . . 8 8 8 8 4 16 0 16 16 16 16 4 1 Ncon
0x4a 24 dc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x4b 24 dc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x4c 24 dc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x4d 24 dc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x4e 24 dc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x4f 24 dc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x50 24 dc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x51 24 dc 0 32 0 r y . 8 8 8 0 4 16 0 16 16 16 16 0 0 None
0x52 24 dc 0 32 0 r y . 8 8 8 8 4 16 0 16 16 16 16 0 0 None
0x53 24 dc 0 32 0 r . . 8 8 8 0 4 16 0 16 16 16 16 0 0 None
0x54 24 dc 0 32 0 r . . 8 8 8 8 4 16 0 16 16 16 16 0 0 None
0x55 24 dc 0 32 0 r y . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x56 24 dc 0 32 0 r y . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x57 24 dc 0 32 0 r . . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x58 24 dc 0 32 0 r . . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x59 24 dc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 2 1 Ncon
0x5a 24 dc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 2 1 Ncon
0x5b 24 dc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 4 1 Ncon
0x5c 24 dc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 4 1 Ncon
0x5d 24 dc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 2 1 Ncon
0x5e 24 dc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 2 1 Ncon
0x5f 24 dc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 4 1 Ncon
0x60 24 dc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 4 1 Ncon
0x61 24 dc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 2 1 Ncon
0x62 24 dc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 2 1 Ncon
0x63 24 dc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 4 1 Ncon
0x64 24 dc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 4 1 Ncon
0x65 24 dc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 2 1 Ncon
0x66 24 dc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 2 1 Ncon
0x67 24 dc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 4 1 Ncon
0x68 24 dc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 4 1 Ncon
0x69 24 dc 0 32 0 r y . 8 8 8 0 4 16 0 16 16 16 16 2 1 Ncon
0x6a 24 dc 0 32 0 r y . 8 8 8 8 4 16 0 16 16 16 16 2 1 Ncon
0x6b 24 dc 0 32 0 r y . 8 8 8 0 4 16 0 16 16 16 16 4 1 Ncon
0x6c 24 dc 0 32 0 r y . 8 8 8 8 4 16 0 16 16 16 16 4 1 Ncon
0x6d 24 dc 0 32 0 r . . 8 8 8 0 4 16 0 16 16 16 16 2 1 Ncon
0x6e 24 dc 0 32 0 r . . 8 8 8 8 4 16 0 16 16 16 16 2 1 Ncon
0x6f 24 dc 0 32 0 r . . 8 8 8 0 4 16 0 16 16 16 16 4 1 Ncon
0x70 24 dc 0 32 0 r . . 8 8 8 8 4 16 0 16 16 16 16 4 1 Ncon
