I compiler file SPE fw but I couldnt’ find anywhere Linux_for_Tegra/bootloader/ this directory. I want flash my compiled file but there is no it on my tx2 device.
How could Linux_for_Tegra/bootloader/ be created ?
I just want to following command. But there is no anywhere ./flash.sh or Linux_for_Tegra/bootloader/ directory
# FLASH
1. Back up the original copies of `spe.bin` and `spe_t194.bin` located in the
following directory:
2. Copy the generated `${OUTDIR}/spe.bin` to the following locating, depending on your target.
- For Jetson TX2, copy it to:
Linux_for_Tegra/bootloader/spe.bin
- For the Jetson AGX target, copy it to:
Linux_for_Tegra/bootloader/spe_t194.bin
The `Linux_for_Tegra` directory is part of the extracted L4T build that
you used to flash the Jetson device.
3. Use the command below to just flash this firmware for Cortex-R5 partition:
sudo ./flash.sh -k spe-fw jetson-<tx2 or xavier> mmcblk0p1
I would be grateful if you could help me.
