There is no video display when open the video device
Hi teams
When I use the system cheese aplication open the video,there is nothing display.
There is some error as below:
[ 518.597551] tegra194-vi5 15c10000.vi: corr_err: discarding frame 71, flags: 0, err_data 64
[ 518.666075] tegra194-vi5 15c10000.vi: corr_err: discarding frame 72, flags: 0, err_data 64
[ 518.734591] tegra194-vi5 15c10000.vi: corr_err: discarding frame 73, flags: 0, err_data 64
[ 518.803054] tegra194-vi5 15c10000.vi: corr_err: discarding frame 74, flags: 0, err_data 64
[ 518.871555] tegra194-vi5 15c10000.vi: corr_err: discarding frame 75, flags: 0, err_data 64
[ 518.940115] tegra194-vi5 15c10000.vi: corr_err: discarding frame 76, flags: 0, err_data 64
[ 519.008604] tegra194-vi5 15c10000.vi: corr_err: discarding frame 77, flags: 0, err_data 64
[ 519.077089] tegra194-vi5 15c10000.vi: corr_err: discarding frame 78, flags: 0, err_data 64
[ 519.145625] tegra194-vi5 15c10000.vi: corr_err: discarding frame 79, flags: 0, err_data 64
[ 519.214174] tegra194-vi5 15c10000.vi: corr_err: discarding frame 80, flags: 0, err_data 64
[ 519.282640] tegra194-vi5 15c10000.vi: corr_err: discarding frame 81, flags: 0, err_data 64
[ 519.351173] tegra194-vi5 15c10000.vi: corr_err: discarding frame 82, flags: 0, err_data 64
[ 519.419679] tegra194-vi5 15c10000.vi: corr_err: discarding frame 83, flags: 0, err_data 64
[ 519.488207] tegra194-vi5 15c10000.vi: corr_err: discarding frame 84, flags: 0, err_data 64
[ 519.556730] tegra194-vi5 15c10000.vi: corr_err: discarding frame 85, flags: 0, err_data 64
[ 519.625216] tegra194-vi5 15c10000.vi: corr_err: discarding frame 86, flags: 0, err_data 64
The detailed log is attached
open-dev-video-error.txt (22.0 KB)
Could you help me have a check?
BRs
thanks
If your source is a v4l2 source, please follow steps in
and see if you can launch it successfully.
Hi DaneLLL
The result is as below:
BRs
thanks
Please try
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY,width=480,height=264,framerate=15/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvoverlaysink
If you run the command and cannot see preview, it is more like an issue in the source. You would need to check the sensor driver first.
Hi DaneLLL
I can capture the video image after change the sensor driver
thanks for your help
