There was a power outage during the OTA upgrade process, causing subsequent upgrade failures forever
There was a power outage during the OTA upgrade process, causing subsequent upgrade failures forever.
The following is the log:
faillog.txt (8.7 KB)
The upgrade was successful before, but I suspected that the content was lost during backup, and then the power was cut off.
Then you can only re-flash the device from scratch.
  1. Is there a solution to this problem?
  2. What should I do if the power is cut off during the OTA process? The current problem is that the power is cut off during the OTA upgrade process, resulting in the inability to upgrade again later, even restarting the power.
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3274/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/updating_jetson_and_host.html#wwpID0E05I0HA
機器應該會開進recovery kernel,讓你可以再重新跑一次OTA的流程
