Hi, we are working on the new camera project where we are going to use the Flir Tau2 thermal camera having BT.656 output.
To connect this thermal camera on CSI0 port of NVIDIA Jetson Xavier NX, we are considering TC358746A Camera Interface bridge IC.
Block Diagram is attached. Please confirm, whether this approach work?
If the tc358746a follow the MIPI spec and the output format was support by the VI driver that would be worked.
