I need your help to understand an issue.
When flashing my TX2i with the DTB that enables Display Port on dp0 instead of HDMI (tegra186-quill-p3489-1000-a00-00-dsi-dp.dtb) 3 thermal sensors are not working anymore : https://www.noelshack.com/2019-03-2-1547553782-tx2i-dp.png
When decompiling the DTB to see the differences I see that the thermal sensors zone is 0x37 in dsi-dp.dts while it is 0x33 in ucm1.dts. I tried to change it and recompile but still no change. Maybe something else I didn’t saw ?
Also, in bpmpthermal there is no handle defined. But I can’t modify this point by hand on the decompiled DTB : https://www.noelshack.com/2019-03-2-1547554628-diff1.png https://www.noelshack.com/2019-03-2-1547554628-diff2.png
Got the same issue with a commercial TX2 and base.dtb / dsi-dp.dtb
I am a little confused here and need your answer. Do you create “tegra186-quill-p3489-1000-a00-00-dsi-dp.dtb” by yourself? I don’t see it in my kernel source.
Also, you said “Got the same issue with a commercial TX2 and base.dtb / dsi-dp.dtb”. Did you mean besides TX2i, TX2 also can see such issue?
If so, could you use official dts which enables dsi and dp on TX2 and see if this issue is still?
I did not create this DTB, it is already available in L4T 3.3 under 64_TX2/Linux_For_Tegra/kernel/dtb. Also the DTS is available in sources/hardware/nvidia/platform/t18x/quill/kernel-dts/.
Yes I mean that with the TX2 I have the same issue. Base DTB (tegra186-quill-p3310-1000-c03-00-base.dtb) make all sensors working whereas with dsi-dp DTB (tegra186-quill-p3310-1000-c03-00-dsi-dp.dtb) only three are working.
Could you also share how you flash this dtb? In fact, the change between dsi-dp and base device tree only has display related node. There should be no thermal changes.
I can also try to verify it on my side.
Also, I want to make sure that what is the platform that can hit this issue? TX2, TX2i? or both?
Ok sorry I was totally wrong … I re-downloaded all the DTB and DTS files. I don’t see those dsi-dp DTB files now, I think I created them months ago to make the Display Port working.
I don’t have p3489 dsi-dp source file (TX2i) but I have p3310 one (TX2).
Let’s take the problem from a TX2 board then, I remember what I have done until now…
I tried to compile “tegra186-quill-p3310-1000-c00-00-dsi-dp.dts” file but I had an error :
ERROR (phandle_references): Reference to non-existent node or label "/bpmp/bpmpthermal"
So in other words there is no DTB file for DisplayPort, only one source for TX2 but can’t compile it.
Sorry for the inconvenience, it has been a long time I did that and didn’t remembered.
By the way, the post I linked talks about a “dtc supplied with the kernel” (last reply) because “standard” creates this error. But if it is the one in “64_TX2/Linux_for_Tegra/kernel” it outputs the same error.
But this is another subject, I must reply to the other post or create a new one.
Can you close this post please ?
Thank you for your help !
