Hi. I have a Jetson TX2, which is part of a long running system. Unfortunately, we encounter problems after running for some time. While investigating, if heat could be the source of the problem, I noticed
The way it’s been explained to me is that the PMIC doesn’t have a thermometer, only certain “trip points.” The lowest “trip point” is above 100 degrees, so when no point is tripped, all the system knows is “it’s 100 centigrade or lower,” so that’s what it displays.
It makes sense, I guess, but it’s somewhat confusing :-)
