I have a laptop that I use exclusively for work. When I bring it to the office, I plug a second screen in, via the HDMI port directly on the laptop itself, and I try to plug in a third screen via the HDMI port that is on the USB-C hub that I use.
That third screen is never detected, and never turned on when plugged via the hub. It works well if I plug it in directly via the HDMI port on the laptop, so it is neither the screen or the cable. I also tried with other USB-C hubs and it does not work either, so it is unlikely that the hub itself is at fault.
nvidia-bug-report.log.gz (355.3 KB)
After reading how to generate the report log file, I read that I should start the X server with specific parameters. So I tried, and this is what I got:
$ startx -- -logverbose 6
/usr/lib/xorg/Xorg.wrap: Only console users are allowed to run the X server
^Cxinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: unexpected signal 2
Couldn't get a file descriptor referring to the console.
So I tried again with sudo:
$ sudo startx -- -logverbose 6
X.Org X Server 1.21.1.4
X Protocol Version 11, Revision 0
Current Operating System: Linux PortableAwoobuntu 6.5.0-44-generic #44~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Tue Jun 18 14:36:16 UTC 2 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.5.0-44-generic root=UUID=2e51964a-d9e4-43bb-9cac-0da2b87df8b6 ro quiet splash vt.handoff=7
xorg-server 2:21.1.4-2ubuntu1.7~22.04.10 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.40.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Aug 5 10:52:31 2024
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
xf86EnableIO: failed to enable I/O ports 0000-03ff (Operation not permitted)
MESA-LOADER: failed to open evdi: /usr/lib/dri/evdi_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
kmsro: driver missing
MESA-LOADER: failed to retrieve device information
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Error: Key <MDSW> added to map for multiple modifiers
> Using Mod3, ignoring Mod5.
Errors from xkbcomp are not fatal to the X server
xinit: connection to X server lost
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
