This change takes effect in the commercial module, but not in the industrial module. why and how ?
1.I disable superspeed clock by modifying tegra194-a02-bpmp-p2888-a04.dts(Convert tegra194-a02-bpmp-p2888-a04.dtb to dts).
2.I add the following.
	clocks {
			clock@plle {
				clk-id = <0x64>;
				pll_freq_table = <38400000 100000000 2 125 24 (-1) (-1) (-1) (-1)>;
			clock@pllnvhs {
				clk-id = <0xf3>;
				pll_freq_table = <0x249f000 0x5f5e100 0x02 0x7d 0x18 0xffffffff 0xffffffff 0xffffffff 0xffffffff>;
  1. Board is Xavier. Mirror version is Linux_for_tegra 2.6.
  2. Industry board./flash jetson-agx-xavier-industrial mmcblk0p1. Commercial board cmd is “./flash jetson-agx-xavier-devkit mmcblk0p1”.
    QUESTION:
Please deal with it as soon as possible。 Thank you。
Are you sure you modify the correct bpmp dtb?
So you mean is that it should be modified other palce?
Or do you have any some other suggestions.
which dtb to change on industrial board?and how to find?
Thank you
Check the board config you used to flash the AGXi board
