This is a design experience: IDT’s PCIE Switch is BUGGY in term of its DMA function
the DMA speed is insanely slow.
the TLPs emitted by DMA function maybe silently discarded, and no AER gets triggered.
As a result, a DMA based memory copy operation maybe incomplete.
I tried to copy a source buffer to the same dest buffer for quite a number of times,
the outcome is like this:
for example, src buffer is, src[1024] = {0, 1, 2, …, 15, 0, 1, 2, …, 15 …, 0, 1, 2, …, 15 } ;
for the 1st time of dma copy, you will find that the dst buffer holds nothing:
dst[1024] = {0, 0, 0, …, 0 };
but, as the times of dma copies increases, you will find that dst buffer will gradually
hold everything expected, until finally, dst buffer is fully loaded:
dst[1024] = {0, 1, 2, …, 15, 0, 1, 2, …, 15 …, 0, 1, 2, …, 15 } ;
IDT’s PCIE Switch functions well only with its NTB port.
But, its DMA engine is so buggy, totally shit !
Anyone want’s to connect 2 or more GPU(s), like, TX2(i) and Xavier, Please NEVER NEVER consider
the choice of IDT’s PCIE Switch.
A good alternative maybe PLX product (already acquired by Broadcom), like PEX**** series.
