I have a .cu file that creates an instance of a class which is implmented in a different .cu file. Here is a very simplified version. My code is much larger, but if this is not enough, I can include it. The issue is that once I get into the implementation of my class, the “this” pointer increments with every line of code executed.
//initializer.cu
MyClass initialize(int i)
MyClass m(i);
return m;
//MyClass.h
public class MyClass
int var;
int* myarray;
public:
MyClass(int i);
//MyClass.cu
__global__ void g_myfunc(int* array, int val)
//some code
MyClass::MyClass(int i)
var = i;
myarray = 0; //this pointer increments
cudaMalloc((void**)&myarray,1000 * sizeof(int)); //this pointer increments
//this pointer is off and myarray and val are incorrect values
g_myfunc<<<1,1>>>(myarray, val);
This used to not occur in my code and I have done very similar things in other projects and not encountered this error. Is there a way to stop this, or am I doing something wrong?
