Thor Address map
I downloaded TRM Thor-Soc-TRM_DP-11881-002_v1.1.pdf, which has only 619 pages. I tried to search "System Address Map " to find the address space for spi controller, but could nor find it.
And in Orin-TRM_DP10508002_v1.2p.pdf which has 8783 pages, there is a chapter named “System Address Map”. It specified the address scope for each controller including spi.
What is the System Address Map for thor, is there another document for thor System Address Map?
This snapshot is orin System Address Map.
Hi ycl,
The Thor TRM does not currently include the System Address Map section like the Orin TRM.
We are checking internally whether there is separate Thor address map document can be shared.
Hi ycl,
We checked with our internal team. Access to the System Address Map information requires an NDA.
Thank you,
