[Thor DevKit] Inquiring on Current Monitoring Architecture: Threshold levels, alert mechanisms, and trigger currents
Hi ,
Following up on our carrier board design for the Jetson AGX Thor SOM, we would like to better understand the detailed operating mechanism and threshold limits of the onboard current/power monitor ICs (e.g., INA series).
Specifically, we want to understand how current spikes and continuous loads are detected, and at what levels the system is notified or throttled. Could you please clarify the following:
  1. Current Sensing Architecture & Notification Flow:
    • How does the current monitoring circuit notify the system? Does it use a multi-tiered approach (e.g., an ALERT line for software throttling/DVFS via BPMP, and a CRITICAL line for hardware emergency power cutoff)?
    • Are the alert lines connected to SoC GPIOs, BPMP, or directly to the carrier board power sequencer/PMIC?
  2. Trigger Current Thresholds & Values:
    • What are the default trip current values (in Amperes) or sense voltage thresholds configured on the Thor DevKit for the main input rail (e.g., VDD_IN)?
    • Specifically:
      * At what current draw does the system trigger Warning / Dynamic Throttling (EDP / DVFS)?
      * At what current draw does the system trigger Critical Emergency Shutdown (OCP)?
  3. Sampling Rate & Transient Spike Tolerance:
    • What are the register configurations for the current meter (e.g., shunt resistor value, conversion time, and averaging mode)?
    • How does the hardware/driver distinguish between benign short-duration GPU/NVDLA current spikes (transients) and genuine sustained overcurrent events to prevent nuisance tripping?
  4. Custom Carrier Implementation:
    • If we replicate this sensing circuit on our custom carrier board, are these threshold parameters configured purely via Device Tree (DTS / power-supply nodes) or programmed via BPMP firmware / hardware resistor dividers?
Thank you for your valuable support!
Best regards
Thank you for the detailed questions regarding the current monitoring architecture on the Thor DevKit.
Before we proceed, could you help us understand the use case behind this inquiry? For example:
  • Are you experiencing overcurrent shutdowns or unexpected throttling on the DevKit?
  • Are you designing a custom power monitoring circuit on your carrier board and need to replicate the DevKit behavior?
  • Or are you trying to tune the OCP/throttling thresholds for a specific workload profile?
Understanding your goal will help us provide the most relevant guidance.
Please refer to the section in developer guide:
Jetson Thor Product Family — NVIDIA Jetson Linux Developer Guide
On AGX Thor developer kit, we have INA3221 in Thor module and INA238 on carrier board. You can flash developer kit to Jetpack 7.2.1 r39.2.1 and check the script:
/etc/systemd/nvpower.sh
To check configuration to the power monitors.
